HP Monitor Z24n 24" Standfuß abnehmbar?
Invader
März 2015
Ja, wenn man dem Datasheet glauben kann, allerdings scheint es einen Adapter von HP zu benötigen (zumindest ist nirgends von VESA die Rede):
"Work comfortably with adjustable tilt, height adjustment, and swivel settings. Use pivot rotation
to customize portrait or landscape views when using multiple displays. An integrated HP Quick
Release Bracket supports wall mounting"
"4
Mounting hardware sold separately."
http://h20195.www2.hp.com/v2/GetDocument.aspx?docname=4AA5-7912ENUC&doctype=data sheet&doclang=EN_US&searchquery=&cc=us&lc=en
Hoffe du kannst damit was anfangen :)
LG
HP Quick Release Bracket
HP Quick Release is an easy to use, 100 mm VESA-compliant, LCD monitor mounting solution that allows you to quickly
and securely attach a flat panel monitor to a variety of stands, brackets, arms or wall mounts. HP Quick Release can also
be used for mounting any combination of devices that are compatible with the 100 mm VESA Flat Display Mounting
Interface Standard. The failsafe "Sure-Lock" mechanism snaps the monitor (or mounted device) securely in place, and can
be further secured with a theft-deterrent security screw.
Product number: EM870AA
Findest du am Ende des Doks
ja das ist sehr hilfreich, danke.
Wir haben davon 300+ in der Firma. Standfuß ist annehmbar und VESA passt auch.
Ist G2 das Folgemodell?
Wie ist es bei dem?
