Intel X25-M Lebensdauer
Medione
Feb. 2008
Ich habe eine Intel X25-M in einem XenServer. In der dom0 läuft ja Linux und da gibt es leider kein Tool ala SSD Life. Ich kann jedoch mit smartctl die SMART Werte auslesen.
Kann mir jemand sagen, wieviel Lebenszeit die SSD noch hat? Wenn ich das richtig sehe, ist ein Sector ja schon kaputt.
smartctl version 5.38 [i686-redhat-linux-gnu] Copyright (C) 2002-8 Bruce Allen
Home page is http://smartmontools.sourceforge.net/
=== START OF INFORMATION SECTION ===
Device Model: INTEL SSDSA2M080G2GC
Serial Number: CVPO0065022G080BGN
Firmware Version: 2CV102HD
User Capacity: 80,026,361,856 bytes
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 7
ATA Standard is: ATA/ATAPI-7 T13 1532D revision 1
Local Time is: Tue Aug 30 15:19:13 2011 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 1) seconds.
capabilities: (0x75) SMART execute Offline immediate.
No Auto Offline data collection support.
Abort Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
Conveyance self-test routine
SMART Attributes Data Structure revision number: 5
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
3 Spin_Up_Time 0x0020 100 100 000 Old_age Offline - 0
4 Start_Stop_Count 0x0030 100 100 000 Old_age Offline - 0
5 Reallocated_Sector_Ct 0x0032 100 100 000 Old_age Always - 1
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 11693
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 31
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 12
225 Load_Cycle_Count 0x0030 200 200 000 Old_age Offline - 48094
226 Load-in_Time 0x0032 100 100 000 Old_age Always - 39
227 Torq-amp_Count 0x0032 100 100 000 Old_age Always - 1
228 Power-off_Retract_Count 0x0032 100 100 000 Old_age Always - 3697514583
232 Unknown_Attribute 0x0033 099 099 010 Pre-fail Always - 0
233 Unknown_Attribute 0x0032 098 098 000 Old_age Always - 0
184 Unknown_Attribute 0x0033 100 100 099 Pre-fail Always - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective Self-Test Log Data Structure Revision Number (0) should be 1
SMART Selective self-test log data structure revision number 0
Warning: ATA Specification requires selective self-test log data structure revision number = 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Bei meiner Platte waren schon kurz nach der Inbetriebnahme drei Blöcke defekt, seitdem läuft die SSD ohne Probleme. Bei den Festplatten ist ja auch so, dass diese bereits mit defekten Sektoren aufgeliefert werden, nur verheimlicht man bei denen dem Kunden, dass da bereits ein Defektspurliste (Sektoren) gefüllt ist.
Bei den SSDs ist es halt die "Kunst" des Controllers defekte Blöcke so auszugrenzen, dass nichts verloren geht. Man sollte allerdings die Liste beobachten, ob Sie wächst. Ich starte jeden Tag automatisch CyrtalDiskInfo. Mal sehen ob es irgendwann ein Tool gibt, was den Wert beobachtet und bei einer Erhöhung Alarm schlägt - nur wird das dann wahrscheinlich nicht für Linux verfügbar sein.
Der vorletzte Punkt ist die Abnutzung. die SSD ist bei 98%, allerdings ist der Reservespeicher angeknackst (99%, darüber). Ist aber nicht tragisch. Die macht noch ein paar Jahre.
Wie Heen schon sagt, noch ewig ;)
