> git --help
usage: git [--version] [--help] [-C <path>] [-c name=value]
[--exec-path[=<path>]] [--html-path] [--man-path] [--info-path]
[-p|--paginate|--no-pager] [--no-replace-objects] [--bare]
[--git-dir=<path>] [--work-tree=<path>] [--namespace=<name>]
<command> [<args>]
The most commonly used git commands are:
add Add file contents to the index
bisect Find by binary search the change that introduced a bug
branch List, create, or delete branches
checkout Checkout a branch or paths to the working tree
clone Clone a repository into a new directory
commit Record changes to the repository
diff Show changes between commits, commit and working tree, etc
fetch Download objects and refs from another repository
grep Print lines matching a pattern
init Create an empty Git repository or reinitialize an existing one
log Show commit logs
merge Join two or more development histories together
mv Move or rename a file, a directory, or a symlink
pull Fetch from and integrate with another repository or a local branch
push Update remote refs along with associated objects
rebase Forward-port local commits to the updated upstream head
reset Reset current HEAD to the specified state
rm Remove files from the working tree and from the index
show Show various types of objects
status Show the working tree status
tag Create, list, delete or verify a tag object signed with GPG
'git help -a' and 'git help -g' lists available subcommands and some
concept guides. See 'git help <command>' or 'git help <concept>'
to read about a specific subcommand or concept.
> git help -a
<command> [<args>]
available git commands in '/usr/libexec/git-core'
add merge-index
add--interactive merge-octopus
am merge-one-file
annotate merge-ours
apply merge-recursive
archimport merge-resolve
archive merge-subtree
bisect merge-tree
bisect--helper mergetool
blame mktag
branch mktree
bundle mv
cat-file name-rev
check-attr notes
check-ignore p4
check-mailmap pack-objects
check-ref-format pack-redundant
checkout pack-refs
checkout-index patch-id
cherry prune
cherry-pick prune-packed
citool pull
clean push
clone quiltimport
column read-tree
commit rebase
commit-tree receive-pack
config reflog
count-objects relink
credential remote
credential-cache remote-ext
credential-cache--daemon remote-fd
credential-store remote-ftp
daemon remote-ftps
describe remote-http
diff remote-https
diff-files remote-testsvn
diff-index repack
diff-tree replace
difftool request-pull
difftool--helper rerere
fast-export reset
fast-import rev-list
fetch rev-parse
fetch-pack revert
filter-branch rm
fmt-merge-msg send-pack
for-each-ref sh-i18n--envsubst
format-patch shell
fsck shortlog
fsck-objects show
gc show-branch
get-tar-commit-id show-index
grep show-ref
gui stage
gui--askpass stash
hash-object status
help stripspace
http-backend submodule
http-fetch symbolic-ref
http-push tag
imap-send unpack-file
index-pack unpack-objects
init update-index
init-db update-ref
instaweb update-server-info
log upload-archive
ls-files upload-pack
ls-remote var
ls-tree verify-commit
mailinfo verify-pack
mailsplit verify-tag
merge web--browse
merge-base whatchanged
merge-file write-tree
> git help -g
The common Git guides are:
attributes Defining attributes per path
glossary A Git glossary
ignore Specifies intentionally untracked files to ignore
modules Defining submodule properties
revisions Specifying revisions and ranges for Git
tutorial A tutorial introduction to Git (for version 1.5.1 or newer)
workflows An overview of recommended workflows with Git
