Gurgulio
- Dez. 2001
Hab mal ein Prob,
nach dem Installieren von NIS(Norton Internet Security) 2003
Neustart
BSOD
0x0000035 Oben besagte Fehlermeldung
Hab schon alles Probiert war auch mit Google Zugange
aber kam nicht was gescheites bei raus:
Hä
Wollte doch nur NIS auf WXPSP1 installieren,
IM KB von M$ wird die Schuld auf Intellipoint geschoben hab sowas garnicht
Neustart
BSOD
Quelle:http://www.osr.com/DDK/ddtools/bccodes_4opz.htmThe NO_MORE_IRP_STACK_LOCATIONS bug check has a value of 0x00000035. This bug check occurs when the IoCallDriver packet has no more stack locations remaining.
Parameters
The following parameters are displayed on the blue screen.
Parameter Description
1 Address of the IRP
2 Reserved
3 Reserved
4 Reserved
Cause
A higher-level driver has attempted to call a lower-level driver through the IoCallDriver interface, but there are no more stack locations in the packet. This will prevent the lower-level driver from accessing its parameters.
This is a disastrous situation, since the higher level driver is proceeding as if it has filled in the parameters for the lower level driver (as required). But since there is no stack location for the latter driver, the former has actually written off the end of the packet. This means that some other memory has been corrupted as well.
Built on Thu, 05 September 2002
Hä
