Patriot Extreme Performance 2x2GB DDR2 Ram
CrazyTurgeon
Banned
Dez. 2006
Gibt es wirklich Ram, welche auf Intel Chipssätzen nicht funktioniert und mit nvidia Chipssätzen problemlos?
Patriot Extreme Performance (EP) Enhanced Latency line is engineered to expand your gaming options. These modules are designed to operate at 1066MHz at 5-5-5-15 timings and are available in 4GB kit capacity. Equipped with Patriot ACC (Aluminum Copper Composite) technology, these modules are designed for maximum performance and stability under extreme overclocking conditions. Engineered with quality and Performance in mind, Patriot Extreme Performance line is the ultimate solution for extreme overclockers, gamers, and PC enthusiasts.
Features
* Extreme Performance PC2-8500 (1066MHz)
* Enhanced Latency (5-5-5-15)
* Equipped Patriot Viper Heat Shields with integrated ACC Aluminum Copper Composite) technology
* 100% Tested and Verified
* Lifetime Warranty
* RoHS Compliant
* EPP Ready
* Tested and compatible with Nvidia 680I and 780I
es gibt ramriegel die sind nicht kompatibel mit nvidia - chipsätzen oder intel - chipsätzen.
die kompatibelitätsliste ist meist im boardbuch zu finden.
