WarumAuchNicht
- Apr. 2008
Samsonxxx hat es eher schon verlinkt:
Löst meine Probleme.
Unable to boot to desktop. Tried Safe Mode, LKGC, System restore, Start up Repair from win RE still unable to Boot.
Try to perform a Manual System Restore to fix the issue.
· Boot from Vista DVD also try get in to inbuilt WIN RE for OEM computrers
· Get in to WINRE
· Open command prompt
· Enter the following commands to create a Manual System Restore to fix the issue.
C:
cd windows\system32\config
C:\windows\system32\config>ren default default.old
C:\windows\system32\config>ren sam sam.old
C:\windows\system32\config>ren security security.old
C:\windows\system32\config>ren software software.old
C:\windows\system32\config>ren system system.old
C:\windows\system32\config>cd regback
C:\windows\system32\config\regback>copy default c:\windows\system32\config
C:\windows\system32\config\regback>copy sam c:\windows\system32\config
C:\windows\system32\config\regback>copy security c:\windows\system32\config
C:\windows\system32\config\regback>copy software c:\windows\system32\config
C:\windows\system32\config\regback>copy system c:\windows\system32\config
Thanks .
Arun.
