Doom Lord
- Dabei seit
- Apr. 2008
Es erscheint nur eine Fehlermeldung und danach geht nichts mehr und ich weiß jetzt nicht was ich noch machen kann -
Q3 1.31 win-x86 Dec 11 2001
----- FS_Startup -----
Current search path:
J:\games\Quake3\baseq3\ZZ_BOT~1.2258dbcf.pk3 (33 files)
J:\games\Quake3\baseq3\zz_bot_izverg.pk3 (25 files)
J:\games\Quake3\baseq3\TODDS.PK3 (25 files)
J:\games\Quake3\baseq3\pak7.pk3 (4 files)
J:\games\Quake3\baseq3\pak6.pk3 (64 files)
J:\games\Quake3\baseq3\pak5.pk3 (7 files)
J:\games\Quake3\baseq3\pak4.pk3 (272 files)
J:\games\Quake3\baseq3\PAK3.PK3 (4 files)
J:\games\Quake3\baseq3\PAK2.PK3 (148 files)
J:\games\Quake3\baseq3\PAK1.PK3 (26 files)
J:\games\Quake3\baseq3\PAK0.PK3 (3539 files)
J:\games\Quake3\baseq3\MD3-VADR.PK3 (52 files)
J:\games\Quake3\baseq3\md3-bravo.pk3 (53 files)
J:\games\Quake3\baseq3\EXOSUS.PK3 (42 files)
J:\games\Quake3\baseq3\BOT-VADR.PK3 (6 files)
J:\games\Quake3\baseq3\BLA.PK3 (28 files)
J:\games\Quake3/baseq3
4328 files in pk3 files
execing default.cfg
execing q3config.cfg
couldn't exec autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found AMD w/ 3DNow!
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\system32\opengl32.dll' ): succeeded
...setting mode 9: 1600 1200 FS
...using colorsbits of 32
...calling CDS: failed, bad mode
...trying next higher resolution: failed, bad mode
...restoring display settings
...registered window class
...created window@3,22 (1606x1232)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 0 )
...137 PFDs found
...hardware acceleration found
...PIXELFORMAT 7 selected
...creating GL context: succeeded
...making context current: succeeded
...WARNING: fullscreen unavailable in this mode
...using colorsbits of 16
...window already present, CreateWindowEx skipped
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
execing default.cfg
----- R_Init -----
...initializing QGL
...137 PFDs found
...initializing QGL
RE_Shutdown( 1 )
