Regelmäßige abtürze Bluescreen
Marco1989
Mai 2013
Guten Tag ,
Also ich hab mir einen neuen Pc zusammen gestellt vor ca 2wochen
Daten zum system
Mainboard : Asus M5a78L-M/USB 3
Prozzesor : AMD FX 8120
Arbeitsspeicher:Corsair 16 Gb 2*8 GB 1600 Mhz
Grafikkarte : XFX Radeon HD 7970 Black edition
Netzteil ACTIVE PVC 650 Watt 80 Bronze
Windows 7 Ultimate 64 Bit
Ich habe die minidump datei auch schon ausgelesen:
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\050213-30108-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: http://msdl.microsoft.com/download/symbols
Executable search path is: C:\Windows\System32
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.18113.amd64fre.win7sp1_gdr.130318-1533
Machine Name:
Kernel base = 0xfffff800`02c12000 PsLoadedModuleList = 0xfffff800`02e55670
Debug session time: Thu May 2 03:58:07.100 2013 (GMT+2)
System Uptime: 0 days 0:00:07.208
Loading Kernel Symbols
Loading User Symbols
Mini Kernel Dump does not contain unloaded driver list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 124, {0, fffffa800dd19038, 0, 0}
Probably caused by : hardware
Followup: MachineOwner
1: kd> !analyze -v
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa800dd19038, Address of the WHEA_ERROR_RECORD structure.
Arg3: 0000000000000000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000000000, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
BUGCHECK_STR: 0x124_AuthenticAMD
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: System
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`033695b0 fffff800`02ed2ca9 : fffffa80`0dd19010 fffffa80`0cb39040 fffffa80`00000008 00000000`00000000 : nt!WheapCreateLiveTriageDump+0x6c
fffff880`03369ad0 fffff800`02db3e87 : fffffa80`0dd19010 fffff800`02e2d2d8 fffffa80`0cb39040 00000000`00000000 : nt!WheapCreateTriageDumpFromPreviousSession+0x49
fffff880`03369b00 fffff800`02d1b285 : fffff800`02e8eae0 00000000`00000001 fffffa80`0dcd37a0 fffffa80`0cb39040 : nt!WheapProcessWorkQueueItem+0x57
fffff880`03369b40 fffff800`02c91251 : fffff880`01121e00 fffff800`02d1b260 fffffa80`0cb39000 2f0d1b2e`0c1a2c0b : nt!WheapWorkQueueWorkerRoutine+0x25
fffff880`03369b70 fffff800`02f25ede : 1f524520`5144214f fffffa80`0cb39040 00000000`00000080 fffffa80`0ca5c040 : nt!ExpWorkerThread+0x111
fffff880`03369c00 fffff800`02c78906 : fffff880`03189180 fffffa80`0cb39040 fffff880`031940c0 3911463b`11473c11 : nt!PspSystemThreadStartup+0x5a
fffff880`03369c40 00000000`00000000 : fffff880`0336a000 fffff880`03364000 fffff880`03f5b740 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: hardware
IMAGE_NAME: hardware
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: X64_0x124_AuthenticAMD_PROCESSOR_BUS_PRV
und im anhang finden ihr alle reiter von cpu z als screenshot ,wer noch weitere fragen hat einfach fragen :D
Ich hoffe ihr könnt mir helfen :)
Achja bios ist auf den neusten stand :D
Stürzt der PC schon immer ab oder erst seit ein paar Tagen?
Hast du schon die RAM-Riegel einzeln entnommen bzw. getestet?
Hast du überhaupt schon irgendwas probiert?
Was ist das genau für ein Netzteil (Hersteller + Modell)? Hört sich nach nem Chinaböller an.
Auch wenn Windows den Arbeitsspeicher erkennt, kann er trotzdem defekt oder schlecht verbaut sein und zu Bluescreens führen.
Bestand das Problem von Anfang an?
Welche Meldung gibt der Bluescreen aus?
Kannst du direkt danach ohne Probleme wieder starten?
nein das problem tauchte auch erst nach 1 knappen monat auf ,dazu kommt auch noch die abstürze kommen nur wenn windows läuft bei zocken ist mir das noch nie passiert.
Ja der pc fährt dann von ganz alleine hoch wieder die meldung hab ich ausgewertet steht oben :)
könnte temperatur, Ram, Netzteil, Grafikkarte sein. Prüfen und ggf. tauschen. bzw mal auf verdacht tauschen.
hab ich schon gemacht an der temperatur kann es garnicht liegen weil beim zocken passiert es ja nicht ....^^
tippe mal !errrec fffffa800dd19038 in Windbg ein. Das zeigt dir mehr Details. Aber deine CPU hat wohl ein BUS Problem.
Common Platform Error Record @ fffffa800dd19038
Signature : *** INVALID ***
Revision : 0.0
Record Id : 0000000000000000
Severity : Recoverable (0)
Length : 0
Creator : {6ed48f83-0000-0000-2047-360000000000}
Notify Type : {6ed48f83-0000-0000-2047-360000000000}
Flags : 0x00000000
Das kamm dann dabei raus und wie krieg ich das behoben?
