Firestorm08
- März 2008
If the disk can read the sector of data a single time, and the damage is permanent, not transient, then the disk firmware will mark the sector as 'bad' and allocate a spare sector to replace it. But if the disk can't read the sector even once, then it won't reallocate the sector, in hopes of being able, at some time in the future, to read the data from it. A write to an unreadable (corrupted) sector will fix the problem. If the damage is transient, then new consistent data will be written to the sector. If the damange is permanent, then the write will force sector reallocation.
Normally when an uncorrectable sector is found, the disk puts this onto a 'pending sector list' to indicate that it should be replaced with a spare good sector. However this replacement won't take place until either the disk can read the data on the bad sector, or is commanded to write new data to that bad sector.
