Was hast du jetzt gemacht, damit dein Stick funktioniert?
Dec 28 22:30:00 gentoo kernel: usb 3-3: new full speed USB device using address 4
Dec 28 22:30:01 gentoo kernel: scsi2 : SCSI emulation for USB Mass Storage devices
Ich bin eigentlich auch alle anleitungen durchgegangen. Das ist ein MP3-Player von DNT der unter Knoppix und unter dem Live Gentoo ohne Probleme funktioniert.
prophet@gentux /boot $ grep USB config-2.6.9-gentoo-r11
# ALSA USB devices
# CONFIG_SND_USB_AUDIO is not set
# CONFIG_SND_USB_USX2Y is not set
# USB support
CONFIG_USB=y
CONFIG_USB_DEBUG=y
# Miscellaneous USB options
CONFIG_USB_DEVICEFS=y
# CONFIG_USB_BANDWIDTH is not set
# CONFIG_USB_DYNAMIC_MINORS is not set
CONFIG_USB_SUSPEND=y
# CONFIG_USB_OTG is not set
# USB Host Controller Drivers
CONFIG_USB_EHCI_HCD=y
CONFIG_USB_EHCI_SPLIT_ISO=y
CONFIG_USB_EHCI_ROOT_HUB_TT=y
CONFIG_USB_OHCI_HCD=y
CONFIG_USB_UHCI_HCD=y
# USB Device Class drivers
# CONFIG_USB_AUDIO is not set
# CONFIG_USB_BLUETOOTH_TTY is not set
# CONFIG_USB_MIDI is not set
# CONFIG_USB_ACM is not set
# CONFIG_USB_PRINTER is not set
CONFIG_USB_STORAGE=y
CONFIG_USB_STORAGE_DEBUG=y
CONFIG_USB_STORAGE_RW_DETECT=y
# CONFIG_USB_STORAGE_DATAFAB is not set
# CONFIG_USB_STORAGE_FREECOM is not set
# CONFIG_USB_STORAGE_ISD200 is not set
# CONFIG_USB_STORAGE_DPCM is not set
# CONFIG_USB_STORAGE_HP8200e is not set
# CONFIG_USB_STORAGE_SDDR09 is not set
# CONFIG_USB_STORAGE_SDDR55 is not set
# CONFIG_USB_STORAGE_JUMPSHOT is not set
# USB Human Interface Devices (HID)
CONFIG_USB_HID=y
CONFIG_USB_HIDINPUT=y
CONFIG_USB_HIDDEV=y
# CONFIG_USB_AIPTEK is not set
# CONFIG_USB_WACOM is not set
# CONFIG_USB_KBTAB is not set
# CONFIG_USB_POWERMATE is not set
# CONFIG_USB_MTOUCH is not set
# CONFIG_USB_EGALAX is not set
# CONFIG_USB_XPAD is not set
# CONFIG_USB_ATI_REMOTE is not set
# USB Imaging devices
# CONFIG_USB_MDC800 is not set
# CONFIG_USB_MICROTEK is not set
# CONFIG_USB_HPUSBSCSI is not set
# USB Multimedia devices
# CONFIG_USB_DABUSB is not set
# Video4Linux support is needed for USB Multimedia device support
# USB Network adaptors
# CONFIG_USB_CATC is not set
# CONFIG_USB_KAWETH is not set
# CONFIG_USB_PEGASUS is not set
# CONFIG_USB_RTL8150 is not set
# CONFIG_USB_USBNET is not set
# USB port drivers
# USB Serial Converter support
# CONFIG_USB_SERIAL is not set
# USB Miscellaneous drivers
# CONFIG_USB_EMI62 is not set
# CONFIG_USB_EMI26 is not set
# CONFIG_USB_TIGL is not set
# CONFIG_USB_AUERSWALD is not set
# CONFIG_USB_RIO500 is not set
# CONFIG_USB_LEGOTOWER is not set
# CONFIG_USB_LCD is not set
# CONFIG_USB_LED is not set
# CONFIG_USB_CYTHERM is not set
# CONFIG_USB_PHIDGETSERVO is not set
# CONFIG_USB_TEST is not set
# USB Gadget Support
# CONFIG_USB_GADGET is not set
vfat
Code:
# CONFIG_X86_MCE_NONFATAL is not set
# DOS/FAT/NT Filesystems
CONFIG_FAT_FS=y
CONFIG_VFAT_FS=m <-- wichtig
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
scsci
Code:
prophet@gentux /boot $ grep SCSI config-2.6.9-gentoo-r11
# CONFIG_BLK_DEV_IDESCSI is not set
# SCSI device support
CONFIG_SCSI=y
CONFIG_SCSI_PROC_FS=y
# SCSI support type (disk, tape, CD-ROM)
# Some SCSI devices (e.g. CD jukebox) support multiple LUNs
# CONFIG_SCSI_MULTI_LUN is not set
# CONFIG_SCSI_CONSTANTS is not set
# CONFIG_SCSI_LOGGING is not set
# SCSI Transport Attributes
# CONFIG_SCSI_SPI_ATTRS is not set
# CONFIG_SCSI_FC_ATTRS is not set
# SCSI low-level drivers
# CONFIG_SCSI_3W_9XXX is not set
# CONFIG_SCSI_ACARD is not set
# CONFIG_SCSI_AACRAID is not set
# CONFIG_SCSI_AIC7XXX is not set
# CONFIG_SCSI_AIC7XXX_OLD is not set
# CONFIG_SCSI_AIC79XX is not set
# CONFIG_SCSI_DPT_I2O is not set
# CONFIG_SCSI_SATA is not set
# CONFIG_SCSI_BUSLOGIC is not set
# CONFIG_SCSI_DMX3191D is not set
# CONFIG_SCSI_EATA is not set
# CONFIG_SCSI_EATA_PIO is not set
# CONFIG_SCSI_FUTURE_DOMAIN is not set
# CONFIG_SCSI_GDTH is not set
# CONFIG_SCSI_IPS is not set
# CONFIG_SCSI_INIA100 is not set
# CONFIG_SCSI_SYM53C8XX_2 is not set
# CONFIG_SCSI_IPR is not set
# CONFIG_SCSI_QLOGIC_ISP is not set
# CONFIG_SCSI_QLOGIC_FC is not set
# CONFIG_SCSI_QLOGIC_1280 is not set
CONFIG_SCSI_QLA2XXX=y
# CONFIG_SCSI_QLA21XX is not set
# CONFIG_SCSI_QLA22XX is not set
# CONFIG_SCSI_QLA2300 is not set
# CONFIG_SCSI_QLA2322 is not set
# CONFIG_SCSI_QLA6312 is not set
# CONFIG_SCSI_QLA6322 is not set
# CONFIG_SCSI_DC395x is not set
# CONFIG_SCSI_DC390T is not set
# CONFIG_SCSI_NSP32 is not set
# CONFIG_SCSI_DEBUG is not set
# PCMCIA SCSI adapter support
# CONFIG_PCMCIA_NINJA_SCSI is not set
Das Module vfat lädst du am besten über /etc/modules.autoload.d/kernel-2.6
Dort einfach vfat eintragen...dann mounten wie bisher im Thread beschrieben.
