tomato - Interessante Firmware für WRT54
- Ersteller kief
- Juli 2005
Frag doch mal bei Linksysinfo.org nach !peki schrieb:Unterstützt Tomato inzwischen SD-Karten Mods?
der_Kief
BTW.
Bitte alle tomato Benutzer bei Frappr mitmachen
- Juli 2005
Hi @ All,
tofu hat die neue Version 1.03 released.
Changelog
* Fixed using Wireless Survey if wireless was disabled made the power/diag led light up.
* Fixed Admin/Bandwidth Custom Path field validation error.
* Fixed DDNS may parse a custom DDNS incorrectly if @ is used in a URL with basic authentication.
* Fixed DDNS Force Update option wasn't working.
* Fixed wrong type detection for some routers.
* Removed -mips32 gcc switch which may be causing some random weirdness.
* Synced a few changes in Linksys WRT54GL 4.30.9: Fix for CVE-2006-0039, some changes resulting from CDRouter testing, a few prebuilt apps.
* Updated PPTP conntrack/NAT helper patch.
* Increased allowed length of router hostname and domain name.
* Default SSID is now "wireless" instead of "linksys".
* Updated iptables to 1.3.7.
* Updated L7 filters to 2007-01-14 release. New: Chikka, Radmin. Updated: BitTorrent, Battlefield 2, etc.
* Added option to disable wireless radio in Access Restriction.
* Added No-IP.com DDNS service, including support for groups.
Desweiteren gibts jetzt ne offizielle FAQ !
der_Kief
Changelog
der_Kief
- Juli 2005
Hi, hast Du von DD-WRT upgedatet ? Das Default Passwort lautet admin. --> http://www.polarcloud.com/tomatofaq#why_doesnt_my_password_workPete2007 schrieb:hallo,
hab mir auch die Tomato FW fraufgeflasht, aber komme nun leider nichtmehr ins Routermenü, wie lautet das PW ? Bitte helft mir...
der_Kief
- Juli 2005
Hi @ All,
neue Version 1.05 released !
Changelog:
* Removed several updates made during the last few versions which may have caused more problems for some.
* Fixed device list may not show all (again).
* Added weekly bandwidth usage page and reworked the daily and monthly pages. The weekly page uses the the daily data so no additional changes to the data file is needed.
* Time: Added more new DST, adjusted a few TZ, increased field size of servers, blocked servers (kiss-o-death/stratum=0) can be cleared in the GUI (shown only if there is a blocked server).
* Logging: Cron event logging can now be disabled, mark interval can now be adjusted, limit can now be disabled.
* PPTP, RTSP, H.323 NAT helper modules can now be disabled in Advanced/Firewall incase anyone has problems with these. These were always loaded in previous versions.
* Upgraded Dnsmasq to 2.38.
* Upgraded Dropbear to 0.49.
* Added support for Buffalo WZR-G54.
* Added support for Linksys WRTSL54GS without USB. There is absolutely no USB support built-in or installable! I was asked for this even without USB. Unfortunately, I don't think I'll be able to make a full version for this one anytime soon.
* etc.
der_Kief
Changelog:
* etc.
der_Kief
Gunman
Cadet 1st Year
- Apr. 2003
Hallo an alle,
es gibt mal wieder eine neue Software Version:
Tomato 1.06
* Fixed restore bandwidth doesn't work with IE.
* Fixed executing a script via AOSS/SES button leaves zombies lying around.
* Fixed scp to router not working.
* Fixed reset/ses button on WRTSL54GS not working.
* QOS htb burst does not use a fixed value anymore which may improve performance, especially for those with a high upload speed. If for some reason you want to use the old method: "nvram set qos_burst0=4; nvram set qos_burst1=2"
* Added time zone for South Australia.
* Added support for Asus WL-500G Premium without USB. Like the WRTSL54GS, this is a simple detection support without any additional USB goodies.
Sie läuft bei mir problemlos!
Gruß Gunman
Tomato 1.06
Gruß Gunman
- Juli 2005
Hi @ All,
tofu hat die Version 1.07 released !
Changelog Version 1.07:
* Added source address restriction for basic forwarding, DMZ and remote web/ssh admin. The IP address format for all are the same: "1.1.1.1", "1.1.1.0/24", "1.1.1.0/255.255.255.0" or "1.1.1.1-2.2.2.2". Note: This required some changes to Basic Forwarding's nvram format.
* Bandwidth graph changes: Selectable 24/18/12/6/4 hours, total downloaded/uploaded during the period is now shown, time is now shown on clicked spot and at the bottom, refresh time is now automatically calculated, etc. As usual, please backup your data if needed before upgrading.
* Added Motorola WR850G/GP support. Please see the warning in the readme before using.
* Added Buffalo WHR2-G54 support.
* Added support for wl_distance from OpenWRT. Pretty much untested at this point...
* L7 patterns updated to 2007-05-09 version.
* Dnsmasq upgraded to 2.39.
* Removed Logout option for IE7. No suitable work-around was found for BA.
* Fixed wl0_* may not get reset to the same value as wl_* in some cases.
der_Kief
der_Kief
Chefkoch
Fleet Admiral
- Juni 2002
Link im Linksys-Thread ergänzt -> https://www.computerbase.de/forum/t...e-1-post-beachten.145264/page-23#post-2825496
Cheffe
Cheffe
- Juli 2005
Hi @ All,
für alle Interessierten, jetzt gibts nen Tomato Mod mit OpenVPN -> http://www.linksysinfo.org/forums/sh...ad.php?t=53233
der_Kief
der_Kief
polloze
- Apr. 2005
hallo,
ich habe seit geraumer zeit die version 1.02 auf meinem router drauf. mittlerweile sind ja einige neuerungen und bugfixes dazu gekommen. daher wüsste ich gerne, wie sich das ganze verhält mit nem update der firmware.
ich hab bisher in der vergangenheit mit meinem wrt54g nicht viel rumprobiert. insofern weiß ich garnicht, wie das bei einer firmware ist, wenn man halt auf eine neuere version updatet, ob dann die ganzen einstellungen verloren gehen!?
denn mein router läuft absolut stabil. für meinen einsatz bräuchte ich eigentlich kein update. natürlich ist mir der spruch "never touch a running system" geläufig
ich möchte halt nur wissen, wie sich das verhalten würde bei nem update. alle daten noch da oder müssten die neu eingegeben werden?
danke
danke
L
Labtec
Es bleiben alle Einstellungen erhalten, nur die Sachen was temporär im Ram gespeichert werden ( Bandbreiten-Graph, Traffic-Logs, usw .... ) werden gelöscht!
DELIUS
- Feb. 2007
Tomato Firmware v1.09
Homapage und Download: http://www.polarcloud.com/tomatoChangelog
Version 1.09
- Fixed DDNS page error when using Internet Explorer.
Version 1.08
- Fixed forwarding a port with a source address and without a source address restriction at the same time may not work correctly. If you have this problem right now, please go to Forward/Basic and click Save to fix the entries.
- Fixed Keep Alive's "redial" was not restarted.
- Changed the keep alive "redial" method to a more simplier, safer way. Incase you experience a problem with this, please try "nvram set oldredial=1; nvram commit" and reboot. If that fixes the problem, then please let me know.
- Fixed DHCP lease time resets when Dnsmasq is restarted.
- Fixed UPnP may not start sometimes, changes made when deleting manually are not saved, connect may block for a long time.
- Added detection of WZR-HP-G54, WZR-RS-G54, WZR-RS-G54HP, WVR-G54-NF, WHR2-A54-G54, WHR3-AG54, RT390W, WX-6615GT. Thanks to piggy for adding most of these and to others who sent in data.
- Added Scott D's nice BlueGreen2 theme.
- New DDNS system adds 3322, FreeDNS, OpenDNS, custom https:// URLs, external check ip support, retry on error, refresh after 26 days on all services to prevent expiring.
- Added "Intercept DNS Port" option in Advanced/DNS which may be helpful when used with OpenDNS for parental control. When enabled, anything going out to UDP port 53 is redirected to Dnsmasq.
- The GUI's SSL certificate SN is now randomized, CN is now also set to the router's LAN IP address, and the certificate can now also be saved in nvram and re-generated more easily if needed in Admin/Access.
- The GUI's local HTTP/HTTPS port can now be changed.
- A list of NTP servers from pool.ntp.org can now be easily selected in Basic/Time.
- Updated dnsmasq 2.40, dropbear 0.50, iptables 1.3.8, l7-protocols-2007-07-27.
- Some merging of code and pre-built binaries from WRT54GL 4.30.11.
- Various minor changes.
- Juli 2005
Neue Version 1.10 -> http://www.polarcloud.com/tomato_110
* Fixed DDNS custom URL doesn't work correctly if "@" was used in the path.
* Fixed config backup download may be renamed/handled by the browser instead of just saving it. This seems to have been introduced when I corrected a content-type typo.
* SSL certificate CN is now editable in Admin/Access. The default didn't turn out to be useful, so I'll just let you guys decide what you need in there (your DDNS hostname maybe).
* Updated to l7-protocols-2007-10-03.
der_Kief
der_Kief
- Juli 2005
Hi @ All,
neue Version 1.11 -> http://www.polarcloud.com/tomato_111
Changelog:
* Fixed UPnP entries are lost when some settings are changed.
* Fixed RIP config causing distribution of indirect routes.
* FTP NAT helper can now be disabled in Advanced/CTNF.
* Bandwidth data can now be saved on reboot/shutdown.
* Added a reboot and reconnect scheduler (Admin/Scheduler).
* Decreased time interval from 30 mins to 15 mins for Access Restriction.
* Updated New Zealand timezone.
* Updated L7 patterns to l7-protocols-2007-10-10.
* Rolled back recent changes from 4.30.11 and iptables to fix a forwarding bug that some are experiencing. I've been unable to replicate the problem, but have received some good feedback on this, so hopefully this does fix it for everyone.
der_Kief
Changelog:
der_Kief
DELIUS
- Feb. 2007
Tomato 1.13.1252
Homepage und Download: http://www.polarcloud.com/tomato
FAQ: http://www.polarcloud.com/tomatofaq
Virtual Tomato GUI: http://lampiweb.com/tomato/status-index.htm
Tomato 1.13.1252
Fixed problem with L2TP, PPPoE, PPTP.
Changes in 1.12 in case you missed it:
Added WHR-HP-G54 transmit amplifier and enhanced receive options in Advanced/Wireless.
Added DNS-O-Matic and eNom DDNS support.
Added/fixed WBR-G54 support thanks to John M.
Updated South Australia TZ.
NAT loopback (Advanced/Firewall) now has more options: Enabled, Forwarded Only and Disabled.
Removed obsolete Telstra/heartbeat/bpalogin support.
Updated to l7-protocols-2007-11-22.
