Technical Specifications
24-bit Analog-to-Digital conversion of analog inputs at 96kHz sample rate
24-bit Digital-to-Analog conversion of digital sources at 96kHz to analog 7.1 speaker output
24-bit Digital-to-Analog conversion of stereo digital sources at 192kHz to stereo output
16-bit to 24-bit recording sampling rates: 8, 11.025, 16, 22.05, 24, 32, 44.1, 48 and 96kHz
ASIO 2.0 support at 16-bit/44.1kHz, 16-bit/48kHz, 24-bit/44.1kHz 24-bit/48kHz and 24-bit/96kHz with direct monitoring
Enhanced SoundFont support at up to 24-bit resolution
Audio Performance (Rated Output @ 2Vrms, Typical Value)
Signal-to-Noise Ratio (20kHz Low-pass filter, A-Weighted)
Stereo Output : 109dB
Front and Rear Channels: 109dB
Center, Subwoofer and Side Channels : 109dB
Total Harmonic Distortion + Noise at 1kHz (20kHz Low-pass filter) = 0.004%
Frequency Response (-3dB, 24-bit/96kHz input ) 10Hz to 46kHz
Frequency Response (-3dB, 24-bit/192kHz input) 10Hz to 88kHz (Stereo only)
Connectivity
Speaker and Headphone connections for stereo to 7.1 (Line Out via three 3.5mm mini jacks)
Line In / Microphone In / Optical Out* (shared 3.5mm FlexiJack)
Auxiliary Line level Input (via 4-pin Molex connector)
Intel HD Audio Compatible Front Panel Header (2x5pin)
* Optical Out supports stereo SPDIF out and pass through of multichannel DVD sound
Product Warranty:
Creative offers a twelve (12) month(s) limited hardware warranty.
