Ich wollte mal fragen ob, meine Werte so ok sind unter Furmark/Prime95 last. Leistungsaufnahme vom System beträgt so 350-370 Watt (schwankt recht stark)
CPUID Hardware Monitor 1.1.4.0
Mainboard Vendor MICRO-STAR INTERNATIONAL CO.,LTD
Mainboard Model MS-7345 (0x1A0 - 0x5F1CB5)
LPCIO
Vendor Fintek
Model F71882F
Vendor ID 0x1934
Chip ID 0x541
Config Mode I/O address 0x4E
Dump config mode register space, LDN = 0x4
0 1 2 3 4 5 6 7 8 9 A B C D E F
00 FF FF 00 FF FF FF FF 04 FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
20 05 41 20 19 34 00 00 10 40 00 40 60 08 0E 00 00
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 0A 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor
Fintek F71882F hardware monitor
Voltage sensor 0 3.31 Volts [0xCF] (+3.3V)
Voltage sensor 1 1.19 Volts [0x95] (CPU VCORE)
Voltage sensor 2 1.95 Volts [0x7A] (VIN2)
Voltage sensor 3 1.02 Volts [0x57] (VIN3)
Voltage sensor 4 4.92 Volts [0x75] (+5V)
Voltage sensor 5 12.06 Volts [0x89] (+12V)
Voltage sensor 6 1.74 Volts [0x6D] (VIN6)
Voltage sensor 7 3.30 Volts [0xCE] (VSB3V)
Voltage sensor 8 3.22 Volts [0xC9] (VBAT)
Temperature sensor 0 51°C (123°F) [0x33] (TMPIN0)
Temperature sensor 1 49°C (120°F) [0x31] (TMPIN1)
Fan sensor 0 1532 RPM [0x3D3] (FANIN0)
Fan sensor 1 1201 RPM [0x4E1] (FANIN1)
Fan sensor 2 1146 RPM [0x51D] (FANIN2)
Fan PWM sensor 0 100 [0xFF] (CPU)
Fan PWM sensor 1 100 [0xFF] (System Fan 1)
Fan PWM sensor 2 100 [0xFF] (System Fan 2)
Fan PWM sensor 3 50 [0x80] (System Fan 3)
Dump hardware monitor
LPC Register space, base address = 0x0A00
00 FF 03 00 00 FF FF FF FF FF FF 00 00 55 4C 00 00
10 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF
20 CF 96 7A 57 76 89 6D CE C9 FF FF FF FF FF FF FF
30 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF 03 04 10 19 34 FF
60 00 00 00 00 FF FF 02 00 00 00 FF 0E 40 24 FF 08
70 FF FF 33 FF 30 FF 80 FF FF FF FF FF FF FF FF FF
80 FF FF 64 55 64 55 55 46 FF FF FF FF FF FF A8 FF
90 00 08 08 00 16 FF 7F FF 41 24 FF AA 55 55 FF 1A
A0 03 D3 00 FF 03 B9 3C 32 28 1E FF E5 CE B7 A0 0D
B0 04 DF 00 FF 03 FF 3C 32 28 1E FF D9 B2 99 80 0E
C0 04 EB 00 FF 03 FF 3C 32 28 1E FF D9 B2 99 80 0F
D0 0F FF 00 80 03 FF 3C 32 28 1E FF D9 B2 99 80 0F
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 00 00 00 00 00 00 37 FF 03 20 FF 00 FF FF FF FF
Hardware monitor
Intel Core 2 Duo E8400 hardware monitor
Temperature sensor 0 42°C (107°F) [0x3A] (Core #0)
Temperature sensor 1 52°C (125°F) [0x30] (Core #1)
Hardware monitor
GeForce GTX 275 hardware monitor
Temperature sensor 0 91°C (195°F) [0x5B] (GPU Core)
Hardware monitor
SAMSUNG HD401LJ hardware monitor
Temperature sensor 0 30°C (86°F) [0x1E] (HDD)
Hardware monitor
ST375033 0AS hardware monitor
Temperature sensor 0 36°C (96°F) [0x24] (HDD)
Hardware monitor
WDC WD10 01FALS-00J7B hardware monitor
Temperature sensor 0 37°C (98°F) [0x25] (HDD)
LPCIO
Vendor Fintek
Model F71882F
Vendor ID 0x1934
Chip ID 0x541
Hardware monitor
Hardware monitor
Hardware monitor
Hardware monitor
Hardware monitor
Hardware monitor
