Win7 Bluescreen + alleiniger Neustart
angusfaaan
Sep. 2011
ich glaube das Thema wurde hier schon x-mal angeschnitten, aber irgendwie hab ich noch keine Problemlösung für mich gefunden.
Bin auch kein PC-Freak, sodass ich froh bin, jetzt endlich mal es geschafft zu haben die Minidump-Datei auszulesen:
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [D:\090511-22994-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*C:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 7601.17640.amd64fre.win7sp1_gdr.110622-1506
Machine Name:
Kernel base = 0xfffff800`02a52000 PsLoadedModuleList = 0xfffff800`02c97670
Debug session time: Mon Sep 5 17:34:01.197 2011 (UTC + 2:00)
System Uptime: 0 days 0:05:10.054
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1A, {41287, 30, 0, 0}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+46485 )
Followup: MachineOwner
2: kd> !analyze -v
MEMORY_MANAGEMENT (1a)
# Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 0000000000041287, The subtype of the bugcheck.
Arg2: 0000000000000030
Arg3: 0000000000000000
Arg4: 0000000000000000
Debugging Details:
BUGCHECK_STR: 0x1a_41287
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: mscorsvw.exe
CURRENT_IRQL: 0
TRAP_FRAME: fffff880027dc6e0 -- (.trap 0xfffff880027dc6e0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000000 rbx=0000000000000000 rcx=0000000000000002
rdx=0000000000000002 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80002bacbc5 rsp=fffff880027dc870 rbp=fffff880027dc8c0
r8=fffff80002a52000 r9=0000000000000001 r10=0000058000000000
r11=0000000fffffffff r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl nz ac po nc
nt!MiResolvePageFileFault+0x1115:
fffff800`02bacbc5 8b4830 mov ecx,dword ptr [rax+30h] ds:00000000`00000030=????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff80002a61d7e to fffff80002acec40
STACK_TEXT:
fffff880`027dc578 fffff800`02a61d7e : 00000000`0000001a 00000000`00041287 00000000`00000030 00000000`00000000 : nt!KeBugCheckEx
fffff880`027dc580 fffff800`02accd6e : 00000000`00000000 00000000`00000030 fffffa80`0684f800 00000000`21d00000 : nt! ?? ::FNODOBFM::`string'+0x46485
fffff880`027dc6e0 fffff800`02bacbc5 : 00000000`00001018 00000000`00000000 fffff8a0`088f0af8 fffff800`02afffaf : nt!KiPageFault+0x16e
fffff880`027dc870 fffff800`02b416b0 : 000007fe`f60143c6 fffff683`ff7b00a0 fffffa80`03d1eb08 fffffa80`03d1eb11 : nt!MiResolvePageFileFault+0x1115
fffff880`027dc9b0 fffff800`02adbf19 : 00000000`00000000 ffffffff`ffffffff 00000000`00000000 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x399d4
fffff880`027dcac0 fffff800`02accd6e : 00000000`00000000 000007fe`f60143c6 000007ff`011c3201 00000000`0000000c : nt!MmAccessFault+0x359
fffff880`027dcc20 00000000`77028fe4 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x16e
00000000`001cba20 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x77028fe4
STACK_COMMAND: kb
FOLLOWUP_IP:
fffff800`02a61d7e cc int 3
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: nt! ?? ::FNODOBFM::`string'+46485
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 4e02aaa3
FAILURE_BUCKET_ID: X64_0x1a_41287_nt!_??_::FNODOBFM::_string_+46485
Bin für jeden Tipp sehr dankbar!!
Bug Check 0x1A: MEMORY_MANAGEMENT ein schwerer Speicherverwaltungsfehler ist aufgetreten.
Parameter1: 0x41287: interne Speicherverwaltungsstrukturen sind korrumpiert.
Wie schon Pentium schrieb, mit Memtest86+ den RAM prüfen, lade die ISO herunter, brenn sie auf eine CD und boote mit dieser, empfohlen werden 7 vollständige Durchgänge, das kann einige Stunden dauern.
Treten Fehler auf, kann der Test abgebrochen werden, dann die Tests mit jeweils nur 1 RAM Modul wiederholen, bis das defekte gefunden ist.
vielen Dank für die Tipps schonmal.
Hatte Memtest über Nacht durchlaufen lassen. 9 Scans und 0 Fehler gefunden.
Was nun?
Hatte in der Zwischenzeit schon wieder 1 Bluescreen und 1x eingefrorenes Bild.
Das ist ungünstig, möglicherweise hast du Probleme mit den Timings oder der Spannung des RAM, das muß aber ein RAM Spezialist hier feststellen. Um das zu ermöglichen mache bitte Screenshots von CPU-Z mit den Reitern Mainboard, Memory und SPD (hier von jedem RAM-Modul extra) und poste sie hier als Anhang.
Download hier:https://www.computerbase.de/downloads/systemtools/cpu-z/
hatte mal ein ähnliches problem.
ich hab lange rum gespielt und habe jetzt keine bs mehr.
ich hab im bios alle optionen für den ram an gemacht auch wenns dafault aus war.
zb suspend to ram oder so auf "controler" gestellt und alles andere auf enabeld.
wenn das alles nicht wirkt mal comandrate auf T2 stellen und gucken wie es läuft.
zusätzlich wie oben schon geschrieben wurde mit cpu z timings auslesen und manuell setzen im bios.
spannung als anfänger erst mal nicht ändern ausser du bist dir sicher was du machst, dann stellste die spannung ein die auf den riegeln steht.
wenn am ende keine kombination hilft spannung ein hoch setzen.
sollte das nicht helfen wieder runter setzen ;)
alles testen kann tage dauern schätze ich wenns random bs sind, dann schreib hier einfach wieder rein wenns wieder passiert :D
poste auch mal bitte deine hardware, dann kann man immer besser gucken was man machen kann;)
Das Problem wird duch Speicherzugriffsfehler ausgelöst. Speicher i.d.S. ist insbes. RAM, VRAM, CPU-Cache, Festplatte. Im weiteren Sinne können auch andere Komponenten wie z.B. das Motherboard derartige Probleme verursachen.
Auch eine softwarebedingte Ursache ist nicht auszuschließen, auch wenn im Stackverlauf kein Gerätetreiber als Ursache zu finden ist (und daher ein Softwareproblem etwas unwahrscheinlicher ist).
Der RAM (Defekt, fehlerhafte Einstellungen) ist die wohl häufigste Ursache für die Probleme. Wenn die RAM unter Memtest keine Fehler bringen, würde sich als nächster Schritt die manuelle Einstellung der Timings bzw. Spannung anbieten.
Poste wie schon bereits geschrieben wurde die CPU-Z Screens und eine Auflistung deiner Hardware.
Treiber sind alle aktuell (insbes. Motherbardtreiber -Chipsatz, Sound, Lan, etc; Grafikkartentreiber)?
