Zu bzw Abschalten der Overdrive Funktion bei Dell Monitor
Hallo ich hab einen Dell u2414h Monitor . Bei dem Dell u2412h soll es möglich sein durch das drücken bestimmter Tasten in ein Menü zu kommen wo man den Overdrive abstellen kann.
Gibt es diese Möglichkeit auch bei meinem Modell und wenn ja, was muss ich machen um in das Menü zu kommen.
You can access the monitors factory menu as well but be careful not to change anything without knowing what you've done or how to change it back. Use the menu at your own risk! To access the factory menu, hold the top two buttons down while powering the monitor on. Once it is on, press the top button to bring up the menu. You can define the RGB levels for each of the colour temp preset modes here and there are a few other settings relating to the operation of the display. Perhaps of some interest here is the ability to turn the overdrive ("OD") function on and off. By default it is turned on, but we will test both settings later on in the review out of interest.
