NAS
ASM225CM
nikal
Juli 2021
Hallo!
sorry for using English but I'm not from Germany. I'm looking a firmware dump (backup) for the ASM225CM USB to SATA controller. I do have a Argon One M.2 down plate that has the aforementioned controller chip. I did a false FW update (I didn't check the chip version first) in order to support TRIM and now the USB-SATA bridge isn't working. I have a CH341a usb programmer and if someone has a similar enclosure or anything that has the ASM225CM onboard and willing to get a FW backup and share it with me, would be a great help.
Thanks in advance for your time and help
vielen dank
Maybe this link will help.
ASM-10xx/11xx/21xx/22xx/2360 (ASMT-xxxx) Sata/USB 3.x controllers
Reaktionen: nikal
yes I know this link / site but doesn't have anything related to 225CM and I'm not sure whether 235CM is the same hardware with different FW. Of course I can try to program the flash chip with the FW and see if it works or not. But I will wait if someone has the correct FW.
Thanks for your reply.
Lian Li O11 Vision-M
