Auf einmal Blue screens
sinus444
Okt. 2010
Hallo Zusammen,
hatte neuderings Bluescreens wenn ich ein spiel gespielt habe. Vorher war nie was...von ein auf den anderen Tag fings an.
Heute habe ich win 7 neu aufgesetzt, neue chipsatztreiber, graka und soundtreiber.
Spiel gestartet, nach 10 min wieder einen bluescreen.
Hab die Minidump Datei analysiert. Hier der Text:
* Bugcheck Analysis *
ATTEMPTED_WRITE_TO_READONLY_MEMORY (be)
An attempt was made to write to readonly memory. The guilty driver is on the
stack trace (and is typically the current instruction pointer).
When possible, the guilty driver's name (Unicode string) is printed on
the bugcheck screen and saved in KiBugCheckDriver.
Arguments:
Arg1: fffff88004169148, Virtual address for the attempted write.
Arg2: 000000013842a121, PTE contents.
Arg3: fffff80000ba2cd0, (reserved)
Arg4: 000000000000000a, (reserved)
Debugging Details:
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0xBE
PROCESS_NAME: Wow.exe
CURRENT_IRQL: 2
TRAP_FRAME: fffff80000ba2cd0 -- (.trap 0xfffff80000ba2cd0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=fffff88004169140 rbx=0000000000000000 rcx=fffff80002a56188
rdx=00000000000000f8 rsi=0000000000000000 rdi=0000000000000000
rip=fffff800028e4db2 rsp=fffff80000ba2e60 rbp=0000000000018ef8
r8=fffffa80061b7120 r9=00000000000000c8 r10=00000000000000f8
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz ac po cy
nt!KiTimerExpiration+0xf2:
fffff800`028e4db2 48894808 mov qword ptr [rax+8],rcx ds:5d20:fffff880`04169148=10782444c7000000
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff80002956718 to fffff800028d8f00
STACK_TEXT:
fffff800`00ba2b68 fffff800`02956718 : 00000000`000000be fffff880`04169148 00000001`3842a121 fffff800`00ba2cd0 : nt!KeBugCheckEx
fffff800`00ba2b70 fffff800`028d6fee : fffffa80`04a768d0 00000003`b7377f7b fffffa80`052d09e0 00000000`00000300 : nt! ?? ::FNODOBFM::`string'+0x40a84
fffff800`00ba2cd0 fffff800`028e4db2 : fffffa80`04d75050 fffff880`03e28d83 fffffa80`04d75050 fffffa80`0442e160 : nt!KiPageFault+0x16e
fffff800`00ba2e60 fffff800`028e4697 : fffff800`02a51ec8 fffffa80`00018ef8 fffffa80`04d75d38 00000000`000000f8 : nt!KiTimerExpiration+0xf2
fffff800`00ba2f00 fffff800`028df065 : 00000000`00000000 fffffa80`043a9060 00000000`00000000 fffff880`03e19db0 : nt!KiRetireDpcList+0x277
fffff800`00ba2fb0 fffff800`028dee7c : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxRetireDpcList+0x5
fffff880`08e5ebe0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDispatchInterruptContinue
STACK_COMMAND: kb
FOLLOWUP_IP:
nt! ?? ::FNODOBFM::`string'+40a84
fffff800`02956718 cc int 3
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: nt! ?? ::FNODOBFM::`string'+40a84
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 4a5bc600
FAILURE_BUCKET_ID: X64_0xBE_nt!_??_::FNODOBFM::_string_+40a84
Followup: MachineOwner
würde mich freuen wenn Ihr mir helfen könntet.
gruß
sinus
"ATTEMPTED_WRITE_TO_READONLY_MEMORY" bedeutet, dass versucht wurde in geschützte Speicherbereiche zu schreiben.
Die gute Nachricht daran ist, dass dieser Fehler durch eine Software und keine Hardware verursacht wird.
Am wahrscheinlichsten sind folgende defekte:
  • Treiber (De- und Neuinstallation und die zeitweise Deaktivierung von Hardware (Kartenleser, Drucker,...) im Gerätemanager könnte helfen)
  • Systemdateien (Fehlerprüfung geht per: Start -> ausführen -> sfc /scannow)
  • Festplattensektoren
Falls das nicht hilft (unwahrscheinlich!), ist hier noch ein Registry-Eintrag
