Bluescreen Fehler
robinh95
Apr. 2009
Habe mal wieder einen Bluescreen:
A problem has been detected and Windows has been shut down to prevent damage
to your computer.
The problem seems to be caused by the following file: dxgmms1.sys
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
If this is the first time you've seen this stop error screen,
restart your computer. If this screen appears again, follow
these steps:
Check to make sure any new hardware or software is properly installed.
If this is a new installation, ask your hardware or software manufacturer
for any Windows updates you might need.
If problems continue, disable or remove any newly installed hardware
or software. Disable BIOS memory options such as caching or shadowing.
If you need to use safe mode to remove or disable components, restart
your computer, press F8 to select Advanced Startup Options, and then
select Safe Mode.
Technical Information:
*** STOP: 0x1000007e (0xffffffffc0000005, 0xfffff880047cbcf7, 0xfffff88005794568,
0xfffff88005793dc0)
*** dxgmms1.sys - Address 0xfffff880047c8ed3 base at 0xfffff880047ab000 DateStamp
0x4ce799c1
- Windows 7 Ultimate 64bit
