epson stylus 1520...
apokalypse
Apr. 2003
.... wollte mal wissen ob jemand weiß wie man diesen drucker aufbekomnt oder die druckköpfe reinigen kann ?! die sind hier eingetrocknet und den drucker bekomme ich einfach nicht auf....!
Habe hier was egefunden....
Q:
The printer is not producing any black or color ink. How can I resolve this problem?
A:
From the Utility section found in the EPSON printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Perform up to 6 cycles if necessary. If the nozzle check is not printing completely, and if the head cleanings do not help the nozzle check pattern to print completely, try replacing the ink cartridge. Any ink cartridge installed into the printer must have a white label on top of it. If the white label has been removed from the ink cartridge, do not install the cartridge. Using an ink cartridge which does not have the white label on it may damage the printer. If you have already installed a cartridge which is missing the white label, or if a previously installed ink cartridge was missing its white label at the time it was installed, and now head cleanings do not help the nozzle check pattern to print completely, your printer may require service and you should contact the EPSON Connection for further assistance.
ABer ich verstehe dieses englisch nicht! kann mir das jemadn übersetzen? das is das problem er druckt keine farbe mehr aus...!
Auch mit Hilfe des treibers ( druckkopfreinigung) wird er nicht freier... habe das mindestens 30 oder 40 x durchgemacht
