* Created by M4r5.
* User: Mar5
* Date: 00.00.0000
* Time: 16:01
* To change this template use Tools | Options | Coding | Edit Standard Headers.
using System;
using System.Drawing;
using System.Windows.Forms;
namespace launcher
/// <summary>
/// Description of MainForm.
/// </summary>
public class MainForm : System.Windows.Forms.Form
private System.Windows.Forms.Button button1;
private System.Windows.Forms.PictureBox pictureBox1;
public MainForm()
// The InitializeComponent() call is required for Windows Forms designer support.
InitializeComponent();
// TODO: Add constructor code after the InitializeComponent() call.
[STAThread]
public static void Main(string[] args)
Application.Run(new MainForm());
#region Windows Forms Designer generated code
/// <summary>
/// This method is required for Windows Forms designer support.
/// Do not change the method contents inside the source code editor. The Forms designer might
/// not be able to load this method if it was changed manually.
/// </summary>
private void InitializeComponent() {
System.Resources.ResourceManager resources = new System.Resources.ResourceManager(typeof(MainForm));
this.pictureBox1 = new System.Windows.Forms.PictureBox();
this.button1 = new System.Windows.Forms.Button();
this.SuspendLayout();
// pictureBox1
this.pictureBox1.Image = ((System.Drawing.Image)(resources.GetObject("pictureBox1.Image")));
this.pictureBox1.Location = new System.Drawing.Point(-16, -64);
this.pictureBox1.Name = "pictureBox1";
this.pictureBox1.Size = new System.Drawing.Size(376, 184);
this.pictureBox1.TabIndex = 1;
this.pictureBox1.TabStop = false;
// button1
this.button1.FlatStyle = System.Windows.Forms.FlatStyle.System;
this.button1.Location = new System.Drawing.Point(-16, 240);
this.button1.Name = "button1";
this.button1.Size = new System.Drawing.Size(328, 32);
this.button1.TabIndex = 0;
this.button1.Text = "Start EXE";
this.button1.Click += new System.EventHandler(this.Button1Click);
// MainForm
this.AutoScaleBaseSize = new System.Drawing.Size(5, 13);
this.BackColor = System.Drawing.SystemColors.ControlText;
this.BackgroundImage = ((System.Drawing.Image)(resources.GetObject("$this.BackgroundImage")));
this.ClientSize = new System.Drawing.Size(292, 266);
this.Controls.Add(this.pictureBox1);
this.Controls.Add(this.button1);
this.FormBorderStyle = System.Windows.Forms.FormBorderStyle.FixedDialog;
this.Icon = ((System.Drawing.Icon)(resources.GetObject("$this.Icon")));
this.Name = "MainForm";
this.Text = "Launcher";
this.ResumeLayout(false);
#endregion
void Button1Click(object sender, System.EventArgs e)
System.Diagnostics.Process.Start("EXE.exe");
