Mobile
Logfile von CoreTemp auslesen: Wie geht das?
Spadefr0g
Cadet 1st Year
Sep. 2013
Wie lese ich die Excel File die Core Temp beim loggen anlegt? Als erstes Uhrzeit, dann Datum, aber was bedeuten die Zahlen danach? Das muss ja die Temperatur sein, sieht aber komisch aus:
21:21:14 11/13/13,66,,,41,68,46,4118.19,
21:21:24 11/13/13,67,,,41,68,37,4118.19,
21:21:34 11/13/13,67,,,41,68,51,4118.19,
21:21:44 11/13/13,68,,,41,68,65,4118.19,
21:21:54 11/13/13,66,,,41,68,51,4118.19,
21:22:04 11/13/13,66,,,41,68,59,4118.19,
21:22:14 11/13/13,67,,,41,68,55,4118.19,
21:22:24 11/13/13,66,,,41,68,46,4118.19,
21:22:34 11/13/13,67,,,41,68,57,4118.19,
21:22:44 11/13/13,67,,,41,69,58,4118.19,
21:22:54 11/13/13,68,,,41,69,52,4118.19,
21:23:04 11/13/13,69,,,41,69,62,4118.19,
21:23:14 11/13/13,68,,,41,69,51,4118.19,
21:23:24 11/13/13,68,,,41,69,62,4118.19,
21:23:34 11/13/13,67,,,41,69,63,4118.19,
21:23:44 11/13/13,68,,,41,69,43,4118.19,
21:23:54 11/13/13,66,,,41,69,46,4118.19,
21:24:04 11/13/13,67,,,41,69,54,4118.19,
21:24:14 11/13/13,69,,,41,69,57,4118.19,
21:24:24 11/13/13,68,,,41,69,46,4118.19,
21:24:34 11/13/13,67,,,41,69,52,4118.19,
21:24:44 11/13/13,67,,,41,69,58,4118.19,
21:24:54 11/13/13,67,,,41,69,37,4118.19,
21:25:04 11/13/13,69,,,41,69,62,4118.19,
21:25:14 11/13/13,68,,,41,69,59,4118.19,
21:25:24 11/13/13,67,,,41,69,52,4118.19,
21:25:34 11/13/13,67,,,41,69,60,4118.19,
21:25:44 11/13/13,69,,,41,69,57,4118.19,
21:25:54 11/13/13,69,,,41,69,42,4118.19,
21:26:04 11/13/13,67,,,41,69,51,4118.19,
21:26:14 11/13/13,69,,,41,69,62,4118.19,
21:26:24 11/13/13,67,,,41,69,57,4118.19,
21:26:34 11/13/13,67,,,41,69,51,4118.19,
21:26:44 11/13/13,69,,,41,69,54,4118.19,
21:26:54 11/13/13,68,,,41,69,51,4118.19,
21:27:04 11/13/13,69,,,41,69,49,4118.19,
Danke
Schau in die Datei. Steht alles als Überschriften drin. Mit LibreOffice Calc kann man das auch sauber importieren. Dann ist es übersichtlich betrachtbar.
Möglicherweise geht das in Excel ja auch mit Komma als Trennzeichen...
Coretemp erstellt übrigens keine Excel Datei, sondern eine CSV. Insofern kannst du nicht erwarten, dass Excel das ohne weiteres so darstellt wie du es erwarten würdest.
Gamescom
