Fireplace April 2026
Monitor get signal later than normal after booting pc.
sew333
Juli 2017
Hi my pc: 10850K stock 4800mhz
2x16 GB DDR4 GSKILL 3000mhz XMP
Seasonic Tx-850 Ultra Titanium
Gigabyte Rtx 3090 Gaming
Aorus Z490 Pro Gaming
1 TB SSD
Aorus FI27Q-P monitor
I have a question. Always when i am booting pc and turning on monitor, i am getting screen and signal +- before Windows 10 <post screen>. Yesterday ( orange light in monitor was ) i was waiting much longer for signal, till Windows 10 fully loaded. Happened once. Is this a sign of something wrong or its fine? Thank you. Thats all.
I mean if you want to be sure you could stress your system and monitor your temperature & load meanwhile.
But on a gut level, I would say no. Maybe Fastboot? Or a different DisplayPort connector of your 3090?
Is there a chance that the mainboard / vendor boot screen was never visible so far? In such a case you could try-out another port from the gfx card and check is the mainboard / vendor screen gets visible. Maybe your observation is correlated with an update finalization of Windows on boot.
Since it happened only once, i wouldn't worry about it.
