x-polo
- Jan. 2005
Von MSI kommt bald eine HD 6850 Cyclone OC Power Edition
Techpowerup:
Quelle
Techpowerup:
The PCB draws power from just one 6-pin power connector, it uses a 6+1+1 phase VRM that makes use of high-grade components. .....
While MSI did not mention what clock speeds it ships with, it definitely put it through some OC tests. The card was able to achieve 1000/1200 MHz (core/memory) with a core voltage of 1.2V. The card was put through Furmark, where it settled down to 65 degrees Celsius. MSI will introduce this card to the market very soon.
Quelle
