Jackery IFA Fireplace
nach windows neuinstallation stürzt rechner immer ab
Trooper20
Juni 2007
wie schon erwähnt stürzt mein computer nach einer windows neuinstallation immer wieder mit einem blue screen ab.
ich habe keine ahnung an was es liegt
debugger auch schon drüber laufen lasse werde aber daraus nicht schlau
WARNING: Whitespace at start of path element
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\Fabian\Desktop\020710-32015-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is: c:\windows\System32; c:\windows\system\System32; http://www.alexander.com/SymServe
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.16385.amd64fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0xfffff800`02c4d000 PsLoadedModuleList = 0xfffff800`02e8ae50
Debug session time: Sun Feb 7 23:02:47.109 2010 (GMT+1)
System Uptime: 0 days 0:00:12.609
Loading Kernel Symbols
Loading User Symbols
Mini Kernel Dump does not contain unloaded driver list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 124, {0, fffffa8007a278f8, 0, 0}
Probably caused by : hardware
Followup: MachineOwner
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa8007a278f8, Address of the WHEA_ERROR_RECORD structure.
Arg3: 0000000000000000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000000000, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
BUGCHECK_STR: 0x124_AuthenticAMD
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: System
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`031c46f0 fffff800`02f07a89 : fffffa80`07a278d0 fffffa80`06a3cb60 fffff8a0`00000011 00000000`00000001 : nt!WheapCreateLiveTriageDump+0x6c
fffff880`031c4c10 fffff800`02de9547 : fffffa80`07a278d0 fffff800`02e625f8 fffffa80`06a3cb60 00000000`00000282 : nt!WheapCreateTriageDumpFromPreviousSession+0x49
fffff880`031c4c40 fffff800`02d51b95 : fffff800`02ec4360 fffffa80`07a70828 fffffa80`07a70820 fffffa80`06a3cb60 : nt!WheapProcessWorkQueueItem+0x57
fffff880`031c4c80 fffff800`02ccc161 : fffff880`00d9ce00 fffff800`02d51b70 fffffa80`06a3cb60 00000000`0000055a : nt!WheapWorkQueueWorkerRoutine+0x25
fffff880`031c4cb0 fffff800`02f62166 : 00000560`00000000 fffffa80`06a3cb60 00000000`00000080 fffffa80`06a29b30 : nt!ExpWorkerThread+0x111
fffff880`031c4d40 fffff800`02c9d486 : fffff880`02f64180 fffffa80`06a3cb60 fffff880`02f6efc0 00000560`00000000 : nt!PspSystemThreadStartup+0x5a
fffff880`031c4d80 00000000`00000000 : fffff880`031c5000 fffff880`031bf000 fffff880`031c4280 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: hardware
IMAGE_NAME: hardware
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: X64_0x124_AuthenticAMD_PROCESSOR_BUS_PRV
kann mir da wer helfen?
Mein System:
windows7 ultimate x64
8gig ddr2 ram
amd phenom 2 x4
msi k9n2 sli platinum
1. Hast du für alle Komponenten, besonders die Grafikkarte, aktuelle Treiber installiert?
2. Ist das BIOS aktuell? Ich würde sicherheitshalber mal das BIOS updaten und auf Werkseinstellungen zurücksetzen.
3. Da recht oft der Prozessor erwähnt wird, könnte es laut dieser Seite hier auch ein Hardwareproblem sein - dass es erst nach einer Neuinstallation auftritt, ist da natürlich merkwürdig. Kommst du irgendwo leihweise an 'ne kompatible CPU dran?
er stürzt an unterschiedlichsten stellen ab, manchmal im spiel aber auch bei normalem desktop betrieb, sogar wenn ich mal nicht am pc bin und er einfach nur an ist und nix arbeiten muss stürzt er ab.
habe von allem die aktuellen treiber instaliert.
nach dem neustart den ich durch den blue screen durchführen muss kommt der sound der immer kommt wenn usb geräte angeschlossen wurden.
bios ist auch aktuell und an eine kompatible cpu komme ich nicht dran
Kommen da verschiede Bluescreens mit unterschiedlichen Stopfehlern?
Teste mal den PC in einer minimalen Konfig, sprich weniger RAM, etc.
es ist immer wieder derselbe
nochmal nen bugreport gemacht
Loading Dump File [C:\Windows\Minidump\021710-21937-01.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols;C:\Symbols
Machine Name:
Kernel base = 0xfffff800`02e15000 PsLoadedModuleList = 0xfffff800`03052e50
Debug session time: Wed Feb 17 21:55:15.375 2010 (GMT+1)
System Uptime: 0 days 0:00:08.859
BugCheck 124, {0, fffffa8007e1c038, 0, 0}
2: kd> !analyze -v
Arguments:
Arg2: fffffa8007e1c038, Address of the WHEA_ERROR_RECORD structure.
Debugging Details:
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`031a16f0 fffff800`030cfa89 : fffffa80`07e1c010 fffffa80`06a3e680 00000000`0000000c 00000000`00000001 : nt!WheapCreateLiveTriageDump+0x6c
fffff880`031a1c10 fffff800`02fb1547 : fffffa80`07e1c010 fffff800`0302a5f8 fffffa80`06a3e680 00000002`00000005 : nt!WheapCreateTriageDumpFromPreviousSession+0x49
fffff880`031a1c40 fffff800`02f19b95 : fffff800`0308c360 fffffa80`07a82828 fffffa80`07a82820 fffffa80`06a3e680 : nt!WheapProcessWorkQueueItem+0x57
fffff880`031a1c80 fffff800`02e94161 : fffff880`01065e00 fffff800`02f19b70 fffffa80`06a3e680 0000052a`00000000 : nt!WheapWorkQueueWorkerRoutine+0x25
fffff880`031a1cb0 fffff800`0312a166 : 0000052a`00000000 fffffa80`06a3e680 00000000`00000080 fffffa80`06a29b30 : nt!ExpWorkerThread+0x111
fffff880`031a1d40 fffff800`02e65486 : fffff880`02f64180 fffffa80`06a3e680 fffff880`02f6efc0 0000052a`00000000 : nt!PspSystemThreadStartup+0x5a
fffff880`031a1d80 00000000`00000000 : fffff880`031a2000 fffff880`0319c000 fffff880`037ec540 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND: kb
2: kd> !analyze -v
Arguments:
Debugging Details:
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
2: kd> !analyze -v
Arguments:
Debugging Details:
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
2: kd> !analyze -v
Arguments:
Debugging Details:
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
2: kd> !analyze -v
Arguments:
Debugging Details:
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
2: kd> !analyze -v
Arguments:
Debugging Details:
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
2: kd> !analyze -v
Arguments:
Debugging Details:
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
bios war schon auf der neusten version bevor das problem auftrat und werkseinstellungen sind auch getätigt, muss man ja nach nem update
Da es laut Bugreport in Richtung eines Hardwarefehlers zu laufen scheint würde ich in Verbindung mit dem Plugin-Geräusch nach solchen Fehlern mal die Version von Jigsaw ausprobieren und Minimalkonfig fahren. Das heißt auch: alle Peripheriegeräte und Hardwarekomponenten, die nicht unbedingt gebraucht werden, rausziehen. Tastatur und Maus (die braucht man ja nunmal) durch andere Geräte ersetzen und an andere Schnittstellen anschließen - beispielsweise wenn sie bisher per USB dran sind, PS/2-Eingabegeräte auftreiben.
