Neuer PC geht einfach aus...
smartphoenix
Banned
Juni 2004
UPDATE!!! Neuer PC geht einfach aus...
EDIT: Es hat sich jetzt heruasgestellt dass anscheinend doch ein Softwareproblem besteht!
Ich habe heute die Programme BlueScreenView und WhoCrashed isnstalliert und dort wurden mir folgende Fehler angezeigt:
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Thu 06.03.2014 09:10:10 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030614-11871-01.dmp
This was probably caused by the following module: dxgkrnl.sys (dxgkrnl+0x8D0FF)
Bugcheck code: 0x116 (0xFFFFFFFFD280F510, 0xFFFFFFFF94EE670E, 0x0, 0xD)
Error: VIDEO_TDR_ERROR
file path: C:\Windows\system32\drivers\dxgkrnl.sys
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: DirectX Graphics Kernel
Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: dxgkrnl.sys (dxgkrnl!TdrIsTimeoutForcedFlip+0xF4)
On Sun 26.01.2014 13:39:40 GMT your computer crashed
crash dump file: C:\Windows\Minidump\012614-12573-01.dmp
Bugcheck code: 0x116 (0xFFFFFFFFBD66E448, 0xFFFFFFFF948ED80E, 0x0, 0xD)
Und bei BlueScreenView:
Created by using BlueScreenView
Filename Address In Stack From Address To Address Size Time Stamp Time String Product Name File Description File Version Company Full Path
atikmpag.sys atikmpag.sys+970e 0x94edd000 0x94f60000 0x00083000 0x530aadbc 24.02.2014 03:26:04 AMD driver AMD multi-vendor Miniport Driver 8.14.01.6367 Advanced Micro Devices, Inc. C:\Windows\system32\drivers\atikmpag.sys
dxgkrnl.sys dxgkrnl.sys+8d0ff 0x9723a000 0x972f2000 0x000b8000 0x51fa113c 01.08.2013 08:41:48 Microsoft® Windows® Operating System DirectX Graphics Kernel 6.1.7601.18228 (win7sp1_gdr.130731-2222) Microsoft Corporation C:\Windows\system32\drivers\dxgkrnl.sys
dxgmms1.sys dxgmms1.sys+692c 0x972f2000 0x9732b000 0x00039000 0x5164d8b5 10.04.2013 04:12:53 Microsoft® Windows® Operating System DirectX Graphics MMS 6.1.7601.18126 (win7sp1_gdr.130409-1534) Microsoft Corporation C:\Windows\system32\drivers\dxgmms1.sys
ntkrnlpa.exe ntkrnlpa.exe+a54ec90 0x83049000 0x8345c000 0x00413000 0x521e9cb6 29.08.2013 01:58:30 Microsoft® Windows® Operating System NT Kernel & System 6.1.7601.18247 (win7sp1_gdr.130828-1532) Microsoft Corporation C:\Windows\system32\ntkrnlpa.exe
watchdog.sys watchdog.sys+107e 0x940fb000 0x94108000 0x0000d000 0x4a5bc21a 14.07.2009 00:24:10 Microsoft® Windows® Operating System Watchdog Driver 6.1.7600.16385 (win7_rtm.090713-1255) Microsoft Corporation C:\Windows\system32\drivers\watchdog.sys
Urprünglicher Anfang des Threads!
Hi Leute,
vor ein paar Monaten habe ich Verwandten einen neuen PC zusammengestellt. Der alte PC war schon betagt und ging immer einfach aus und fuhr nicht mehr hoch.
Nach ca. 2 Monaten folgendes Phänomen....der neue PC geht nun ebenfalls einfach aus. Mal mehrmals täglich, mal nur 1x am Tag.
Da ich was Elektrotechnik angeht kaum Ahnung habe frage ich mich ob das Problem vielleicht am Hausstrom liegen kann? Keine Ahnung...Spannungsspitzen, irgendwas.
Hat hier jemand eine Idee?
"Ich hab n Auto und brauche einen neuen Motor, was haben Sie denn?" Merkste was?...
Dann poste mal bitte das komplette System - incl. Netzteil.
Der PC ist absolut einwandfrei. Technisch in Ordnung. Bei mir habe ich den jetzt 3 tage und er ist noch nie abgestürzt.
@rtechnobase: wenn du nicht helfen kannst oder möchtest, dann braucht man auch keine sinnlosen Kommentare schreiben...für wirkliche hoffe bin ich jedoch sehr dankbar
wenn du dir da so sicher bist, warum fragst du eigentlich?
dann musst du einen elektriker kommen lassen, wenns am stromkreis liegt.
Nunja wenn du in einem PC Forum Antworten zu einem PC Problem haben willst, dann musst du auch den PC hinschreiben. Vielleicht ist ja das Netzteil der letzte mist.
Punkto Elektrik kann ich nur fragen wie alt die Verkabelung im Haus ist.
Ok, war vllt wirklich etwas voreilig. Aber wie sollen wir helfen, wenn du so allgemeingültiges Zeug schreibst? Wir brauchen die verbauten Komponenten und evtl auch noch die Tätigkeit/Lastzustand bei dem er ausgeht.
Moselbärs Post war vorhin noch nicht zu sehen.
AMD ATHLON 750K
ASROCK FM2A75 PRO4-M
8GB RAM
AMD HD7770
BeQuiet! System Power 7 - BQ SU7-350W
128GB SSD VON SAMSUNG
Mich würde einfach interessieren ob es überhaupt möglich, oder reel sein kann dass der PC durch Spannungsspitzen, etc. einfacher aus geht. Oder gibt es sowas wie unregelmäßige Spannung nicht im Hausstrom? Ich habe keine Ahnung von Elektrik, deshalb die grundsätzliche Frage.
Mir ist schon klar dass hier keiner beantworten kann ob meine Hausstromversorgung eine Macke hat.
Ja kann er definitiv. Das Netzteil hat div. Schutzmechanismen für Überlastung, Unter bzw. Überspannung, falsche Frequenz. Daher können Spannungseinbrüche und Spannungsspitzen durchaus zum Ausschalten des PCs führen. Normal gibt es Spannungsschwankungen im Hausnetz eher weniger. Vor allem nicht so sehr, dass der PC ausgeht.
Die Komponenten können das Netzteil definitiv nicht überlasten. Die kommen zusammen auf max. 200 - 220W. Da sind die 350 Watt genau im richtigen Bereich.
Die Frage ob der Hausstrom ne macke hat kann dir nur ein Elektriker beantworten. Eine kurzfristige Abhilfe für solche Fälle würde Ihm ne USV bringen. Die besseren zeichnen den Spannungsverlauf auch auf und so könnte man es dann herausfinden.
Das nenne ich mal eine vernünftige Antwort. Das mit der USV ist ne gute Idee. Ich werde mal in der Firma nachfragen ob ich mir eine ausleihen kann.
Vielen Dank!
Es hat sich zu meinem Bedauern wohl doch ein Hardware/Softwareproblem herausgestellt.
Ich wäre weiterhin um Hilfe Dankbar und möchte mich für die vorherigen Posts entschuldigen. Manchmal irrt man sich halt -.-
Hatte den PC die ganze Nacht an und vorhin folgendes, offenes Fenster auf dem Desktop:
Fehlermeldung:
Windows wird nach unerwartetem herunterfahren wieder ausgeführt:
Problemsignatur:
Problemereignisname: BlueScreen
Betriebsystemversion: 6.1.7601.2.1.0.768.3
Gebietsschema-ID: 1031
Zusatzinformationen zum Problem:
BCCode: 116
BCP1: D280F510
BCP2: 94EE670E
BCP3: 00000000
BCP4: 0000000D
OS Version: 6_1_7601
Service Pack: 1_0
Product: 768_1
Dateien, die bei der Beschreibung des Problems hilfreich sind:
C:\Users\Familie\AppData\Local\Temp\WER-25864-0.sysdata.xml
Lesen Sie unsere Datenschutzbestimmungen online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0407
Wenn die Onlinedatenschutzbestimmungen nicht verfügbar sind, lesen Sie unsere Datenschutzbestimmungen offline:
C:\Windows\system32\de-DE\erofflps.txt
Ich habe den Startpost übrigens überarbeitet!
Guck in deine PN.
Ich habe jetzt erstmal die AMD Treiber komplett deinstalliert. Alle...also auch die Mainboard Treiber. Alles mit dem AMD Uninstall Tool.
Dann neustart und alles mit einem FINAL Release Treiber wieder installiert.
Dann Neustart und 6 Stunden Benchmarks laufen lassen. Bisher gibt es keine Probleme.
