Gerne, hier der DirectX Log ....
System Information
Time of this report: 3/30/2013, 15:36:49
Machine name: XXX
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: German (Regional Setting: German)
System Manufacturer: HPPAV
System Model: D9954A-ABA
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon(tm) 64 Processor 3500+, MMX, 3DNow, ~2.2GHz
Memory: 1022MB RAM
Page File: 623MB used, 1836MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: RADEON X600 Series
Manufacturer: ATI Technologies Inc.
Chip type: RADEON X600 PRO (0x5B62)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_5B62&SUBSYS_0450174B&REV_00
Display Memory: 256.0 MB
Current Mode: 1024 x 768 (32 bit) (70Hz)
Monitor: Plug und Play-Monitor
Monitor Max Res: 1600,1200
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6483 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 9/29/2004 08:22:42, 216576 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: Nicht zutreffend
Mini VDD: ati2mtag.sys
Mini VDD Date: 9/29/2004 08:22:22, 800256 bytes
Device Identifier: {D7B71EE2-1822-11CF-A86D-5A24A1C2CB35}
Vendor ID: 0x1002
Device ID: 0x5B62
SubSys ID: 0x0450174B
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: C-Media Wave Device
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1002&DEV_4370&SUBSYS_71241462&REV_00
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: cmuda.sys
Driver Version: 5.12.0001.0046 (English)
Driver Attributes: Final Debug
WHQL Logo'd: Yes
Date and Size: 10/26/2004 13:45:00, 822272 bytes
Other Files:
Driver Provider: C-Media Inc.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 100, 100000
Static/Strm HW Mix Bufs: 33, 32
Static/Strm HW 3D Bufs: 33, 32
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): Yes
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xCC0
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
C-Media Wave Device, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI-Mapper [Emuliert], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emuliert], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Maus
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Tastatur
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: SideWinder Joystick
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x003C
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB-Root-Hub
| Vendor/Product ID: 0x1002, 0x4375
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/4/2004 13:00:00, 57600 bytes
| Driver: usbd.sys, 8/4/2004 13:00:00, 4736 bytes
+-+ USB-HID (Human Interface Device)
| | Matching Device ID: usb\class_03
| | Service: HidUsb
| | OEMData: 01 00 00 10 08 00 00 00
| | Driver: hidclass.sys, 8/4/2004 13:00:00, 36224 bytes
| | Driver: hidparse.sys, 8/4/2004 13:00:00, 24960 bytes
| | Driver: hid.dll, 8/4/2004 13:00:00, 20992 bytes
| | Driver: hidusb.sys, 8/4/2004 13:00:00, 9600 bytes
| +-+ HID-konformer Gamecontroller
| | | Matching Device ID: hid_device_system_game
Gameport Devices
PS/2 Devices
+ HP PS2 Keyboard (2K - 3)
| Matching Device ID: acpi\pnp0303
| Upper Filters: PS2
| Service: i8042prt
| Driver: i8042prt.sys, 8/4/2004 00:42:26, 53248 bytes
| Driver: kbdclass.sys, 8/4/2004 00:46:10, 25216 bytes
| Driver: PS2.sys, 6/4/2001 06:00:00, 14112 bytes
| Driver: ps2.bat, 10/16/2002 08:57:00, 81920 bytes
+ Terminalserver-Tastaturtreiber
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 00:58:36, 40840 bytes
+ PS/2-kompatible Maus
| Matching Device ID: *pnp0f13
| Service: i8042prt
| Driver: mouclass.sys, 8/4/2004 13:00:00, 23552 bytes
+ Terminalserver-Maustreiber
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Modem Service Provider: ZTE Proprietary USB Modem
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM3
DirectPlay8 TCP/IP Service Provider: 1&1 - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1,4 KBit/s
Voxware SC06 6,4 KBit/s
Voxware SC03 3,2 KBit/s
MS-PCM 64 KBit/s
MS-ADPCM 32,8 KBit/s
Microsoft GSM 6.10 13 KBit/s
TrueSpeech(TM) 8,6 KBit/s
DirectPlay Lobbyable Apps
Flight Simulator (DX8) - Registry: OK, ExeFile: FS9.Exe (9.01.0000.40901) LauncherFile: (<Fehlende Datei>)
Age of Empires (DX7) - Registry: OK, ExeFile: Empires.Exe (0.09.0013.1115)
Age of Empires Expansion (DX7) - Registry: OK, ExeFile: EmpiresX.Exe (0.01.0006.1115)
Age of Empires II (DX7) - Registry: OK, ExeFile: Empires2.ICD (0.14.0022.0712)
Age of Empires II - The Conquerors Expansion (DX7) - Registry: OK, ExeFile: \age2_x1.icd (<Fehlende Datei>)
Microsoft Flight Simulator 2004 (DX7) - Registry: OK, ExeFile: FS9.Exe (9.01.0000.40901)
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 44.3 GB
Total Space: 92.5 GB
File System: NTFS
Model: ST3200822AS
Drive: D:
Free Space: 66.1 GB
Total Space: 95.8 GB
File System: NTFS
Model: ST3200822AS
Drive: E:
Free Space: 0.6 GB
Total Space: 2.5 GB
File System: FAT32
Model: ST3200822AS
Drive: J:
Model: HL-DT-ST DVDRRW GWA-4083B
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (German), 8/4/2004 13:00:00, 49536 bytes
Drive: K:
Model: PHILIPS DVDR1660P1
System Devices
Name: Creatix CTX404 WLAN 802.11b
Device ID: PCI\VEN_11C1&DEV_AB10&SUBSYS_200216BE&REV_00\4&1C88B56&0&10A4
Driver: C:\WINDOWS\system32\DRIVERS\wlags48d.sys, 7.86.0000.0619 (German), 7/9/2003 11:18:00, 153088 bytes
Driver: C:\WINDOWS\system32\wnags48d.cpl, 7.86.0000.0619 (German), 7/9/2003 11:19:00, 176128 bytes
Driver: C:\WINDOWS\system32\wcags48d.exe, 7.86.0000.0619 (German), 7/9/2003 11:19:00, 69632 bytes
Driver: C:\WINDOWS\system32\waags48d.dll, 7.86.0000.0619 (German), 7/9/2003 11:20:00, 204800 bytes
Driver: C:\WINDOWS\system32\wnags.hlp, 12/9/2002 14:30:00, 226226 bytes
Driver: C:\WINDOWS\system32\wnags.cnt, 12/9/2002 14:30:00, 729 bytes
Driver: C:\WINDOWS\system32\wdags48d.dll, 7.86.0000.0619 (German), 7/9/2003 11:21:00, 11776 bytes
Name: VIA Rhine III Fast Ethernet Adapter
Device ID: PCI\VEN_1106&DEV_3106&SUBSYS_124C1462&REV_8B\4&1C88B56&0&30A4
Driver: C:\WINDOWS\system32\DRIVERS\fetnd5b.sys, 3.32.0000.0417 (English), 4/15/2004 09:57:20, 42496 bytes
Name: VIA OHCI-konformer IEEE 1394-Hostcontroller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_124D1462&REV_80\4&1C88B56&0&20A4
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/4/2004 13:00:00, 61056 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/4/2004 13:00:00, 53248 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 8/4/2004 13:00:00, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 8/4/2004 13:00:00, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 13:46:40, 6400 bytes
Name: PCI Standard-Host-CPU-Brücke
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&61AAA01&0&C3
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&61AAA01&0&C2
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&61AAA01&0&C1
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&61AAA01&0&C0
Driver: n/a
Name: RADEON X600 Series Secondary
Device ID: PCI\VEN_1002&DEV_5B72&SUBSYS_0451174B&REV_00\4&123D6358&0&0110
Driver: C:\WINDOWS\system32\DRIVERS\ati2mtag.sys, 6.14.0010.6483 (German), 9/29/2004 08:22:22, 800256 bytes
Driver: C:\WINDOWS\system32\ati2dvag.dll, 6.14.0010.6483 (English), 9/29/2004 08:22:42, 216576 bytes
Driver: C:\WINDOWS\system32\ati2cqag.dll, 6.14.0010.0257 (English), 9/29/2004 07:29:00, 245760 bytes
Driver: C:\WINDOWS\system32\Ati2mdxx.exe, 6.14.0010.2494 (English), 9/29/2004 08:18:28, 65536 bytes
Driver: C:\WINDOWS\system32\ati3duag.dll, 6.14.0010.0263 (English), 9/29/2004 08:05:10, 2254560 bytes
Driver: C:\WINDOWS\system32\ativvaxx.dll, 6.14.0001.0033 (English), 9/29/2004 07:45:16, 479840 bytes
Driver: C:\WINDOWS\system32\ATIDDC.DLL, 6.14.0010.0005 (English), 9/29/2004 08:16:22, 81920 bytes
Driver: C:\WINDOWS\system32\atitvo32.dll, 6.14.0010.4100 (English), 9/29/2004 07:36:20, 17408 bytes
Driver: C:\WINDOWS\system32\ativcoxx.dll, 6.13.0010.0005 (English), 11/9/2001 11:01:04, 24064 bytes
Driver: C:\WINDOWS\system32\ati2evxx.exe, 6.14.0010.4107 (English), 9/29/2004 08:16:44, 405504 bytes
Driver: C:\WINDOWS\system32\ati2evxx.dll, 6.14.0010.4107 (English), 9/29/2004 08:18:08, 90112 bytes
Driver: C:\WINDOWS\system32\atipdlxx.dll, 6.14.0010.2492 (English), 9/29/2004 08:18:50, 131072 bytes
Driver: C:\WINDOWS\system32\Oemdspif.dll, 6.14.0001.0010 (English), 9/29/2004 08:18:36, 102400 bytes
Driver: C:\WINDOWS\system32\ati2edxx.dll, 6.14.0010.2495 (English), 9/29/2004 08:18:20, 30720 bytes
Driver: C:\WINDOWS\system32\ATIDEMGR.dll, 1.00.1733.17172 (German), 9/29/2004 10:32:34, 163840 bytes
Driver: C:\WINDOWS\system32\atifglpf.xml, 9/27/2004 14:38:48, 10055 bytes
Driver: C:\WINDOWS\system32\atioglxx.dll, 6.14.0010.4650 (English), 9/29/2004 08:44:00, 6553600 bytes
Driver: C:\WINDOWS\system32\atiiiexx.dll, 6.14.0010.4003 (English), 9/29/2004 10:58:44, 294912 bytes
Device ID: PCI\VEN_1002&DEV_5B62&SUBSYS_0450174B&REV_00\4&123D6358&0&0010
Name: PCI Standard-PCI-zu-PCI-Brücke
Device ID: PCI\VEN_1002&DEV_5A34&SUBSYS_00000000&REV_00\3&61AAA01&0&10
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (German), 8/4/2004 13:00:00, 68224 bytes
Device ID: PCI\VEN_1002&DEV_5950&SUBSYS_00000000&REV_00\3&61AAA01&0&00
Driver: n/a
Device ID: PCI\VEN_1002&DEV_4379&SUBSYS_43791002&REV_00\3&61AAA01&0&90
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (German), 8/3/2004 22:59:42, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:44, 95360 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (German), 8/18/2001 04:30:42, 3328 bytes
Name: PCI Standard-ISA-Brücke
Device ID: PCI\VEN_1002&DEV_4377&SUBSYS_00000000&REV_00\3&61AAA01&0&A3
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (German), 8/4/2004 13:00:00, 36224 bytes
Name: ATI IDE Controller
Device ID: PCI\VEN_1002&DEV_4376&SUBSYS_71241462&REV_00\3&61AAA01&0&A1
Name: Standard OpenHCD USB-Hostcontroller
Device ID: PCI\VEN_1002&DEV_4375&SUBSYS_43751002&REV_00\3&61AAA01&0&99
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.2180 (English), 8/4/2004 13:00:00, 17024 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/4/2004 13:00:00, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (German), 8/4/2004 00:57:38, 77312 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/4/2004 13:00:00, 57600 bytes
Device ID: PCI\VEN_1002&DEV_4374&SUBSYS_43741002&REV_00\3&61AAA01&0&98
Name: Standard erweiterter PCI-zu-USB universeller Hostcontroller
Device ID: PCI\VEN_1002&DEV_4373&SUBSYS_43731002&REV_00\3&61AAA01&0&9A
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/4/2004 13:00:00, 26624 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 13:00:00, 7168 bytes
Device ID: PCI\VEN_1002&DEV_4372&SUBSYS_71241462&REV_04\3&61AAA01&0&A0
Driver: n/a
Device ID: PCI\VEN_1002&DEV_4371&SUBSYS_00000000&REV_00\3&61AAA01&0&A4
Name: C-Media AC97 Audio Device
Device ID: PCI\VEN_1002&DEV_4370&SUBSYS_71241462&REV_00\3&61AAA01&0&A5
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (German), 8/4/2004 00:57:24, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (German), 8/4/2004 00:58:24, 130048 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (German), 8/3/2004 23:15:22, 140928 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:00, 60288 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/3/2004 23:15:50, 145792 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (German), 8/3/2004 23:08:04, 48640 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/4/2004 00:58:28, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\cmuda.sys, 5.12.0001.0046 (English), 10/26/2004 13:45:00, 822272 bytes
Driver: C:\WINDOWS\system32\udaprop.dll, 1.00.0002.0002 (English), 4/24/2003 13:29:08, 32768 bytes
Driver: C:\WINDOWS\system32\cmuda.dll, 5.12.0001.0157 (Chinese), 9/14/2004 19:06:10, 163840 bytes
Driver: C:\WINDOWS\system32\cmirmdrv.dll, 2/18/2003 18:26:28, 28672 bytes
Driver: C:\WINDOWS\system32\cmirmdrv.exe, 1.00.0000.0016 (English), 4/23/2004 15:02:10, 233472 bytes
Driver: C:\WINDOWS\system\cmids3d.dll, 1.00.0000.0000 (Chinese), 4/29/2002 15:04:40, 917504 bytes
Driver: C:\WINDOWS\system\cmicnfg.cpl, 1.00.0041.0016 (Chinese), 9/3/2004 12:31:00, 2596864 bytes
Driver: C:\WINDOWS\system\SmWizard.exe, 1.00.0002.0003 (English), 2/17/2004 10:51:56, 1458176 bytes
Driver: C:\WINDOWS\system32\a3d.dll, 4.12.0001.2008 (English), 11/23/2001 12:08:20, 712704 bytes
Driver: C:\WINDOWS\system32\Audio3D.dll, 4.12.0001.2008 (English), 11/23/2001 12:08:20, 712704 bytes
Ergänzung (7. April 2013 )
Hm .... zum Beispiel FS 2004 oder Call of Duty 1 und 2 starten nicht .... andere laufen teilweise mit Update .... vorher liefen alle.
