guten tag,
ich wollte gerade bad company 2 im multiplayer zocken. es kommt immer die meldung das punkbuster nicht läuft...
habe es schon neu installiert, das hat aber nichts gebracht.
(habe die .exe als admin ausgeführt)
weiss jemand was ich da machen kann ?
mfg
(habe windows 7)
Starting PunkBuster Service Tests (v0.988) (06/30/11 16:33:53)
Checking OS
Windows NT 6.1 (build 7601, Service Pack 1) 64-bit
Checking PnkBstrA service status RUNNING
Checking PnkBstrA Version OK (1032)
Extracting "PnkBstrB.exe" to:
"C:\Users\yellowJ7\AppData\Roaming\PnkBstrB.exe"
OK
Checking firewall settings OFF
Is PnkBstrA explicitly allowed?
C:\Windows\system32\PnkBstrA.exe NO
Is PnkBstrB explicitly allowed?
C:\Windows\system32\PnkBstrB.exe NO
Checking if PnkBstrB is running STOPPED
Getting port for PnkBstrA OK (44301)
Opening socket for packet send OK
Sending version packet to PnkBstrA SENT
Receiving version from PnkBstrA OK
Received 6 bytes from 127.0.0.1:44301
Response = 7067 (ms) Version = v1032
Getting PnkBstrB install instance OK
Sending start packet to PnkBstrA SENT
Waiting for packet from PnkBstrA OK
Received 3 bytes from 127.0.0.1:44301
Response = 14071 (ms) PnkBstrB started.
Load SUCCESSFUL.
Watching for PnkBstrB instance change (1) CHANGED (2)
Getting port for PnkBstrB OK (45301)
Sending version packet to PnkBstrB SENT
Receiving version from PnkBstrB OK
Received 5 bytes from 127.0.0.1:45301
Response = 2995 (ms) Version = 2202
Checking PnkBstrK driver status NOT FOUND
Manually stopping PnkBstrB STOPPED
Removing test PnkBstrB file OK
mfg
(habe windows 7)
Checking OS
OK
Load SUCCESSFUL.
