Seit kurzem mehrere Bluescreesns
Juli 2014
Ich habe vor kurzer Zeit drei Bluescreens gehabt (SYSTEM_THREAD_EXCEPTION_NOT_HANDLED/0x1000007e) diese glaube ich aber mit einem Treiber Update behoben zu haben.
Nun habe ich aber zwei neu Bluescreens gehabt (REFERENCE_BY_POINTER/0x00000018) ich weis diese nicht zu beheben.
System:
AMD FX(tm)-8350 Eight-Core 4.00 GHz
msi R7850
16GB Ram (weis nicht welchen)
Asus M5 A97 R2.0
Minidump:
Anhang anzeigen 110514-17986-01.zip
Hatten wir das hier nicht schon öfter, das die 970er Boards Probleme mit dem 8350 haben?
Asus M5 A97 R2.0
BIOS-Version mindest "2301" ist aufgespielt ?
Command Rate = 2T im BIOS eingestellt >> bei 1333 ?
* Bugcheck Analysis *
REFERENCE_BY_POINTER (18)
Arguments:
Arg1: fffffa800ce4a920, Object type of the object whose reference count is being lowered
Arg2: fffffa8010ee91b0, Object whose reference count is being lowered
Arg3: 0000000000000001, Reserved
Arg4: 0000000000000001, Reserved
The reference count of an object is illegal for the current state of the object.
Each time a driver uses a pointer to an object the driver calls a kernel routine
to increment the reference count of the object. When the driver is done with the
pointer the driver calls another kernel routine to decrement the reference count.
Drivers must match calls to the increment and decrement routines. This bugcheck
can occur because an object's reference count goes to zero while there are still
open handles to the object, in which case the fourth parameter indicates the number
of opened handles. It may also occur when the object?s reference count drops below zero
whether or not there are open handles to the object, and in that case the fourth parameter
contains the actual value of the pointer references count.
Debugging Details:
TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\modclass.ini, error 2
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
BUGCHECK_STR: 0x18
PROCESS_NAME: System
CURRENT_IRQL: 2
LAST_CONTROL_TRANSFER: from fffff8000323adbd to fffff80003294bc0
STACK_TEXT:
fffff880`03195778 fffff800`0323adbd : 00000000`00000018 fffffa80`0ce4a920 fffffa80`10ee91b0 00000000`00000001 : nt!KeBugCheckEx
fffff880`03195780 fffff880`11030fc0 : 00000000`00000020 fffff880`0ef8a0e8 fffffa80`10ee91b0 00000000`00000000 : nt! ?? ::FNODOBFM::`string'+0x48d8a
fffff880`031957e0 00000000`00000020 : fffff880`0ef8a0e8 fffffa80`10ee91b0 00000000`00000000 fffff880`03172040 : atikmdag+0x26fc0
fffff880`031957e8 fffff880`0ef8a0e8 : fffffa80`10ee91b0 00000000`00000000 fffff880`03172040 00000000`00000022 : 0x20
fffff880`031957f0 fffffa80`10ee91b0 : 00000000`00000000 fffff880`03172040 00000000`00000022 fffff880`03195920 : 0xfffff880`0ef8a0e8
fffff880`031957f8 00000000`00000000 : fffff880`03172040 00000000`00000022 fffff880`03195920 fffff880`11032bf8 : 0xfffffa80`10ee91b0
STACK_COMMAND: kb
FOLLOWUP_IP:
atikmdag+26fc0
fffff880`11030fc0 ?? ???
SYMBOL_STACK_INDEX: 2
SYMBOL_NAME: atikmdag+26fc0
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: atikmdag
IMAGE_NAME: atikmdag.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 54176654
FAILURE_BUCKET_ID: X64_0x18_CORRUPT_REF_COUNT_atikmdag+26fc0
Followup: MachineOwner
Sieht nach einem Problem mit der Grafikkarte, bzw. dem Grafikkartentreiber aus.
Welche(n) Treiber hast du aktualisiert? Grafikkartentreiber? Treiber nur drüber gebügelt, oder eine Neuinstallation vorgenommen?
Poste mal bitte noch ein paar Screenshots von CPU-Z (Reiter Mainboard, CPU, Memory und SPD) und einen von GPU-Z.
Habe die Grafikkartentreiber geupdatet auf Catalyst 14.9 nur "drüber gebügelt"
Gpu-z
Wenn die BetaTreiber auch keine Besserung bringen, würde ich den Grafikkartentreiber erst mal deinstallieren und mit dem DisplayDriver Uninstaller (DDU Tool) die Treiberreste entfernen. Anschließend die aktuellsten BetaTreiber installieren.
