probier mal folgendes:
funktioniert zu 100% und ist nicht schwer und noch dazu selfmade:
erstelle irgendwo (desktop zB. eine .txt Datei mit dem titel "installedPrograms.vsd"
Ganz normal öffnen und einfach folgenden Code reinkopieren:
Option Explicit
Dim sTitle
sTitle = "Installierte Programme"
Dim StrComputer
strComputer = "."
Dim sCompName : sCompName = GetProbedID(StrComputer)
Dim sFileName
sFileName = sCompName & "_" & GetDTFileName() & "_Software.txt"
Dim s : s = GetAddRemove(strComputer)
If WriteFile(s, sFileName) Then
If MsgBox("Finished processing. Results saved to " & sFileName & _
vbcrlf & vbcrlf & "Do you want to view the results now?", _
4 + 32, sTitle) = 6 Then
WScript.CreateObject("WScript.Shell").Run sFileName, 9
End If
End If
Function GetAddRemove(sComp)
Dim cnt, oReg, sBaseKey, iRC, aSubKeys
Const HKLM = &H80000002 'HKEY_LOCAL_MACHINE
Set oReg = GetObject("winmgmts:{impersonationLevel=impersonate}!\\" & _
sComp & "/root/default:StdRegProv")
sBaseKey = "SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\"
iRC = oReg.EnumKey(HKLM, sBaseKey, aSubKeys)
Dim sKey, sValue, sTmp, sVersion, sDateValue, sYr, sMth, sDay
For Each sKey In aSubKeys
iRC = oReg.GetStringValue(HKLM, sBaseKey & sKey, "DisplayName", sValue)
If iRC <> 0 Then
oReg.GetStringValue HKLM, sBaseKey & sKey, "QuietDisplayName", sValue
End If
If sValue <> "" Then
iRC = oReg.GetStringValue(HKLM, sBaseKey & sKey, _
"DisplayVersion", sVersion)
If sVersion <> "" Then
sValue = sValue & vbTab & "Ver: " & sVersion
Else
End If
"InstallDate", sDateValue)
If sDateValue <> "" Then
sYr = Left(sDateValue, 4)
sMth = Mid(sDateValue, 5, 2)
sDay = Right(sDateValue, 2)
On Error Resume Next
sDateValue = DateSerial(sYr, sMth, sDay)
On Error GoTo 0
If sdateValue <> "" Then
sValue = sValue & vbTab & "Installed: " & sDateValue
End If
End If
sTmp = sTmp & sValue & vbcrlf
cnt = cnt + 1
End If
Next
sTmp = BubbleSort(sTmp)
GetAddRemove = "INSTALLED SOFTWARE (" & cnt & ") - " & sCompName & _
" - " & Now() & vbcrlf & vbcrlf & sTmp
End Function
Function BubbleSort(sTmp)
Dim aTmp, i, j, temp
aTmp = Split(sTmp, vbcrlf)
For i = UBound(aTmp) - 1 To 0 Step -1
For j = 0 to i - 1
If LCase(aTmp(j)) > LCase(aTmp(j+1)) Then
temp = aTmp(j + 1)
aTmp(j + 1) = aTmp(j)
aTmp(j) = temp
End if
Next
Next
BubbleSort = Join(aTmp, vbcrlf)
End Function
Function GetProbedID(sComp)
Dim objWMIService, colItems, objItem
Set objWMIService = GetObject("winmgmts:\\" & sComp & "\root\cimv2")
Set colItems = objWMIService.ExecQuery("Select SystemName from " & _
"Win32_NetworkAdapter",,48)
For Each objItem in colItems
GetProbedID = objItem.SystemName
Next
End Function
Function GetDTFileName()
dim sNow, sMth, sDay, sYr, sHr, sMin, sSec
sNow = Now
sMth = Right("0" & Month(sNow), 2)
sDay = Right("0" & Day(sNow), 2)
sYr = Right("00" & Year(sNow), 4)
sHr = Right("0" & Hour(sNow), 2)
sMin = Right("0" & Minute(sNow), 2)
sSec = Right("0" & Second(sNow), 2)
GetDTFileName = sMth & sDay & sYr & "_" & sHr & sMin & sSec
End Function
Function WriteFile(sData, sFileName)
Dim fso, OutFile, bWrite
bWrite = True
Set fso = CreateObject("Scripting.FileSystemObject")
Set OutFile = fso.OpenTextFile(sFileName, 2, True)
If Err = 70 Then
Wscript.Echo "Could not write to file " & sFileName & ", results " & _
"not saved." & vbcrlf & vbcrlf & "This is probably " & _
"because the file is already open."
bWrite = False
ElseIf Err Then
WScript.Echo err & vbcrlf & err.description
bWrite = False
End If
On Error GoTo 0
If bWrite Then
OutFile.WriteLine(sData)
OutFile.Close
End If
Set fso = Nothing
Set OutFile = Nothing
WriteFile = bWrite
End Function
Jetzt führst du den reg befehl aus und siehe da:
genau das was du wolltest ;-)
Greets
