Manual Install
This section assumes to use Internet Explorer and Windows Explorer.
Downloading file
1. Click once on the underlined file name. Once this is done, some pop-up
windows will appear.
2. Follow the instructions on the screen.
3. In the window to choose Run or Save, click Save.
4. Choose the folder you would like to download the file to and click Save.
A different window will appear and the download will begin and complete.
Once the download has completed, there may or may not be a message stating
that the download completed successfully.
Extracting file
5. Make sure to be logged on with an administrator account.
6. Locate the folder where the file was downloaded.
7. Locate the file that was downloaded and double-click it.
8. Follow the instructions on the screen.
9. In the Select Destination Location window, click Next. If you would like to
select a different folder, click Browse.
10. In the Ready to Install window, click Install. All the necessary files will
be extracted to the folder selected in the step 9.
Installing files
11. Make sure the checkbox next to "Install ..... now" is checked and click
Finish.
12. Follow the instructions on the screen.
Note:
If you use ThinkVantage Access Connections, Intel PROSet/Wireless component
needs to be installed as pre-selected during the above procedure.
13. Follow the instructions on the screen to complete installation and restart
the computer.
Finally delete the file saved in the step 4.
