http://wiki.ubuntuusers.de/Systeminformationen_ermitteln
ubuntu@noname:~$ sudo su
root@noname:/home/ubuntu# sudo dmidecode -s system-manufacturer
FUJITSU SIEMENS
root@noname:/home/ubuntu# sudo dmidecode -s system-product-name
D2470-A1
root@noname:/home/ubuntu# sudo dmidecode -s system-version
root@noname:/home/ubuntu# sudo dmidecode | grep -A3 'BIOS Information'
BIOS Information
Vendor: FUJITSU SIEMENS // Phoenix Technologies Ltd.
Version: 6.00 R1.04.2470.A1
Release Date: 07/16/2007
root@noname:/home/ubuntu# lshw -C cpu
PCI (sysfs)
*-cpu:0
description: CPU
product: AMD Athlon(tm) 64 X2 Dual Core Processor 4000+
vendor: Advanced Micro Devices [AMD]
physical id: 3
bus info: cpu@0
version: 15.11.1
slot: Socket AM2
capacity: 1GHz
width: 64 bits
clock: 133MHz
capabilities: boot fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt rdtscp x86-64 3dnowext 3dnow extd_apicid pni cx16 lahf_lm cmp_legacy svm extapic cr8_legacy 3dnowprefetch lbrv cpufreq
*-cpu:1
physical id: 4
bus info: cpu@1
version: 15.11.1
capacity: 1GHz
capabilities: cpufreq
root@noname:/home/ubuntu# cat /proc/cpuinfo
processor : 0
vendor_id : AuthenticAMD
cpu family : 15
model : 107
model name : AMD Athlon(tm) 64 X2 Dual Core Processor 4000+
stepping : 1
cpu MHz : 1000.000
cache size : 512 KB
physical id : 0
siblings : 2
core id : 0
cpu cores : 2
apicid : 0
initial apicid : 0
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 1
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt rdtscp lm 3dnowext 3dnow extd_apicid pni cx16 lahf_lm cmp_legacy svm extapic cr8_legacy 3dnowprefetch lbrv
bogomips : 2010.36
clflush size : 64
cache_alignment : 64
address sizes : 40 bits physical, 48 bits virtual
power management: ts fid vid ttp tm stc 100mhzsteps
processor : 1
cpu family : 15
model : 107
stepping : 1
cpu MHz : 1000.000
cache size : 512 KB
physical id : 0
siblings : 2
core id : 1
cpu cores : 2
apicid : 1
initial apicid : 1
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 1
wp : yes
bogomips : 2010.36
clflush size : 64
root@noname:/home/ubuntu# free
total used free shared buffers cached
Mem: 2059964 1402148 657816 0 187140 783092
-/+ buffers/cache: 431916 1628048
Swap: 6142972 0 6142972
root@noname:/home/ubuntu# sudo lshw -C memory
*-firmware
description: BIOS
vendor: FUJITSU SIEMENS // Phoenix Technologies Ltd.
physical id: 0
version: 6.00 R1.04.2470.A1 (07/16/2007)
capacity: 448KiB
capabilities: pci pnp upgrade shadowing escd cdboot bootselect int13floppynec int13floppytoshiba int13floppy360 int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer int10video acpi usb ls120boot zipboot biosbootspecification
*-cache:0
description: L1 cache
physical id: 5
slot: L1 Cache
capabilities: asynchronous internal write-back
*-cache:1
description: L2 cache
physical id: 6
slot: L2 Cache
capacity: 512KiB
capabilities: synchronous internal write-through unified
*-memory:0
description: System Memory
physical id: 25
slot: System board or motherboard
*-bank:0
description: DIMM DDR2 Synchronous 133 MHz (7.5 ns)
physical id: 0
slot: Slot-1
width: 64 bits
clock: 133MHz (7.5ns)
*-bank:1
physical id: 1
slot: Slot-3
width: 64 bits
*-bank:2
description: DIMM DDR2 133 MHz (7.5 ns)
physical id: 2
slot: Slot-2
width: 64 bits
*-bank:3
physical id: 3
slot: Slot-4
width: 64 bits
*-cache:0
physical id: 0
*-cache:1
physical id: 1
*-memory:1 UNCLAIMED
description: RAM memory
product: MCP55 Memory Controller
vendor: nVidia Corporation
physical id: 7
bus info: pci@0000:00:00.0
version: a1
width: 32 bits
clock: 66MHz (15.2ns)
capabilities: bus_master cap_list
configuration: latency=0
