D.S.i.u.S.
- Feb. 2003
Also es tritt plötzlich auf, wenn ich z.B. rar datei entpacke oder cd brenne oder film encodiere oder spiele, man kann nie wissen wann es kommt.
Habe Windows xp sp1, mit sicherheits updates, Windows läuft schon seit märz 2003 ohne formatierung ohne probleme, vor 1-2 wochen fing es an
Voran ligt es ?
BLUESCREEN
A problem has been detected and windows has been shut down to prevent damage to your computer.
A device driver attempling to corrupt the system has been cought.The faulty driver corrently on the kernel stack must be replaced with a working version.
If this is the first time you've seen this stop error screen, restart your computer.If this screen appears again,follow these steps:
Check to make sure any new hardware or software is properly installed.Of this a new installation, ask your hardware or software manufacturer for any windows updates you might need.
If problems continue,disable or remove any newly installed hardware or software.Disable BIOS Memory options such as caching or shadowing.If you need to use safe mode to remove or disable components,restart your computer,press F8 to select Advanced startup Options and then select safe Mode.
Technical information:
***STOP 0x000000C4 (0x00000081, 0x85E7CA88, 0x0000008A, 0x00000000)
Beginning dump of phisical memory
physical memory dump complete.
Contact your system administrator or thechnical support group for further assistance.
Voran ligt es ?
BLUESCREEN
