Was ist Teredo?
DonSerious
Captain
Aug. 2010
ich habe mir gestern für gemeinsames Minecraftspielen hamachi geladen. Seitdem kamen diese Einträge im Protokolllog:
Code:
Sun, 2012-12-30 17:43:28 - Upnp set event: redirecting port from 52092 to 192.168.0.6:52092 protocol UDP for: Teredo
Sun, 2012-12-30 17:43:28 - UPnP set event:AddPortMapping from source 192.168.0.6
Sun, 2012-12-30 17:43:39 - Administrator login successful - IP:192.168.0.6
Sun, 2012-12-30 17:44:12 - UPnP set event: removing redirect rule port, port:52092 protocol:UDP
Sun, 2012-12-30 17:44:12 - UPnP set event:DeletePortMapping from source 192.168.0.6
Sun, 2012-12-30 17:44:12 - Upnp set event: redirecting port from 52092 to 192.168.0.6:52092 protocol UDP for: Teredo
Sun, 2012-12-30 17:44:12 - UPnP set event:AddPortMapping from source 192.168.0.6
Sun, 2012-12-30 17:44:48 - UPnP set event: removing redirect rule port, port:52092 protocol:UDP
Sun, 2012-12-30 17:44:48 - UPnP set event:DeletePortMapping from source 192.168.0.6
Sun, 2012-12-30 17:44:48 - Upnp set event: redirecting port from 52092 to 192.168.0.6:52092 protocol UDP for: Teredo
Sun, 2012-12-30 17:44:48 - UPnP set event:AddPortMapping from source 192.168.0.6
Sun, 2012-12-30 17:45:20 - UPnP set event: removing redirect rule port, port:52092 protocol:UDP
Sun, 2012-12-30 17:45:20 - UPnP set event:DeletePortMapping from source 192.168.0.6
Sun, 2012-12-30 17:45:20 - Upnp set event: redirecting port from 52092 to 192.168.0.6:52092 protocol UDP for: Teredo
Sun, 2012-12-30 17:45:20 - UPnP set event:AddPortMapping from source 192.168.0.6
Sun, 2012-12-30 17:45:59 - UPnP set event: removing redirect rule port, port:52092 protocol:UDP
Sun, 2012-12-30 17:45:59 - UPnP set event:DeletePortMapping from source 192.168.0.6
Sun, 2012-12-30 17:45:59 - Upnp set event: redirecting port from 52092 to 192.168.0.6:52092 protocol UDP for: Teredo
Sun, 2012-12-30 17:45:59 - UPnP set event:AddPortMapping from source 192.168.0.6
Sun, 2012-12-30 17:46:44 - UPnP set event: removing redirect rule port, port:52092 protocol:UDP
Sun, 2012-12-30 17:46:44 - UPnP set event:DeletePortMapping from source 192.168.0.6
Sun, 2012-12-30 17:46:44 - Upnp set event: redirecting port from 52092 to 192.168.0.6:52092 protocol UDP for: Teredo
Sun, 2012-12-30 17:46:44 - UPnP set event:AddPortMapping from source 192.168.0.6
Sun, 2012-12-30 17:47:20 - UPnP set event: removing redirect rule port, port:52092 protocol:UDP
Sun, 2012-12-30 17:47:20 - UPnP set event:DeletePortMapping from source 192.168.0.6
Sun, 2012-12-30 17:47:20 - Upnp set event: redirecting port from 52092 to 192.168.0.6:52092 protocol UDP for: Teredo
Sun, 2012-12-30 17:47:20 - UPnP set event:AddPortMapping from source 192.168.0.6
Sun, 2012-12-30 17:48:00 - UPnP set event: removing redirect rule port, port:52092 protocol:UDP
Sun, 2012-12-30 17:48:00 - UPnP set event:DeletePortMapping from source 192.168.0.6
Sun, 2012-12-30 17:48:00 - Upnp set event: redirecting port from 52092 to 192.168.0.6:52092 protocol UDP for: Teredo
Sun, 2012-12-30 17:48:00 - UPnP set event:AddPortMapping from source 192.168.0.6
Sun, 2012-12-30 17:48:31 - UPnP set event: removing redirect rule port, port:52092 protocol:UDP
Sun, 2012-12-30 17:48:31 - UPnP set event:DeletePortMapping from source 192.168.0.6
Sun, 2012-12-30 17:48:31 - Upnp set event: redirecting port from 52092 to 192.168.0.6:52092 protocol UDP for: Teredo
Sun, 2012-12-30 17:48:31 - UPnP set event:AddPortMapping from source 192.168.0.6
Sun, 2012-12-30 17:49:15 - UPnP set event: removing redirect rule port, port:52092 protocol:UDP
Sun, 2012-12-30 17:49:15 - UPnP set event:DeletePortMapping from source 192.168.0.6
Sun, 2012-12-30 17:49:15 - Upnp set event: redirecting port from 52092 to 192.168.0.6:52092 protocol UDP for: Teredo
Sun, 2012-12-30 17:49:15 - UPnP set event:AddPortMapping from source 192.168.0.6
Sun, 2012-12-30 17:49:55 - UPnP set event: removing redirect rule port, port:52092 protocol:UDP
Sun, 2012-12-30 17:49:55 - UPnP set event:DeletePortMapping from source 192.168.0.6
Sun, 2012-12-30 17:49:55 - Upnp set event: redirecting port from 52092 to 192.168.0.6:52092 protocol UDP for: Teredo
Sun, 2012-12-30 17:49:55 - UPnP set event:AddPortMapping from source 192.168.0.6
Sun, 2012-12-30 17:50:30 - UPnP set event: removing redirect rule port, port:52092 protocol:UDP
Sun, 2012-12-30 17:50:30 - UPnP set event:DeletePortMapping from source 192.168.0.6
Sun, 2012-12-30 17:50:31 - Upnp set event: redirecting port from 52092 to 192.168.0.6:52092 protocol UDP for: Teredo
Sun, 2012-12-30 17:50:31 - UPnP set event:AddPortMapping from source 192.168.0.6
Sun, 2012-12-30 17:51:12 - UPnP set event: removing redirect rule port, port:52092 protocol:UDP
Sun, 2012-12-30 17:51:12 - UPnP set event:DeletePortMapping from source 192.168.0.6
Sun, 2012-12-30 17:51:12 - Upnp set event: redirecting port from 52092 to 192.168.0.6:52092 protocol UDP for: Teredo
Sun, 2012-12-30 17:51:12 - UPnP set event:AddPortMapping from source 192.168.0.6
Sun, 2012-12-30 17:51:48 - UPnP set event: removing redirect rule port, port:52092 protocol:UDP
Sun, 2012-12-30 17:51:48 - UPnP set event:DeletePortMapping from source 192.168.0.6
Sun, 2012-12-30 17:51:48 - Upnp set event: redirecting port from 52092 to 192.168.0.6:52092 protocol UDP for: Teredo
Sun, 2012-12-30 17:51:48 - UPnP set event:AddPortMapping from source 192.168.0.6
Sun, 2012-12-30 17:52:26 - UPnP set event: removing redirect rule port, port:52092 protocol:UDP
Sun, 2012-12-30 17:52:26 - UPnP set event:DeletePortMapping from source 192.168.0.6
Sun, 2012-12-30 17:52:26 - Upnp set event: redirecting port from 52092 to 192.168.0.6:52092 protocol UDP for: Teredo
Sun, 2012-12-30 17:52:26 - UPnP set event:AddPortMapping from source 192.168.0.6
Sun, 2012-12-30 17:53:10 - UPnP set event: removing redirect rule port, port:52092 protocol:UDP
Sun, 2012-12-30 17:53:10 - UPnP set event:DeletePortMapping from source 192.168.0.6
Sun, 2012-12-30 17:53:10 - Upnp set event: redirecting port from 52092 to 192.168.0.6:52092 protocol UDP for: Teredo
Sun, 2012-12-30 17:53:10 - UPnP set event:AddPortMapping from source 192.168.0.6
Sun, 2012-12-30 17:53:53 - UPnP set event: removing redirect rule port, port:52092 protocol:UDP
Sun, 2012-12-30 17:53:53 - UPnP set event:DeletePortMapping from source 192.168.0.6
Sun, 2012-12-30 17:53:53 - Upnp set event: redirecting port from 52092 to 192.168.0.6:52092 protocol UDP for: Teredo
Sun, 2012-12-30 17:53:53 - UPnP set event:AddPortMapping from source 192.168.0.6
192.168.0.6 ist mein PC. Leider kann ich nicht sicher sagen, dass das Hamachi ist. Selbst nachdem ich es gerade eben gelöscht habe kommen weiterhin diese Einträge. Leider war das gestern nach schon der Fall, bevor ich heruntergefahren habe und heute geht es weiter. Was ist das? Datenverkehr herrscht nicht wirklich, sprich nur selten mal 8-24 kbit/s upload und 48 kbit/s download,
danke und mfg
mfg
hat mit Googeln nix zu tun. Das mit Hamachi hab ich gestern schon gefunden, deshalb beziehe ich das doch darauf Oo?
Warum kommen diese Ruquests aber auch noch nach dem Deinstallieren von Hamachi? Ich hatte es btw. nichtmal im Autostart. Kann aber auch sein, dass die Kollegen in meinem Cluster on waren und zugreifen wollten, ich aber nicht online war. Irgendwer ne Idee?
mfg
Sent from my Windows 8 device using Board Express
schau mal in deine Netzwerkadapter, ob da evtl noch die Hamachi Adapter drin sind. Oder es einen Teredo Adapter gibt.
Wenn ja dann manuell deaktivieren / löschen. Dann hat hamatchi nicht alles deinstalliert.
hab nun ne weile lang hamachi benutzt und da kam sowas nicht mehr. Nach Deinstallation und Neustart spammt es wieder das Protokoll zu. Haben auf einen Server gewechselt daher hamachi unnötig.
mir ist aufgefallen, dass diese Logs immer nur die ersten 30 Minuten nach dem Hochfahren passiert. Könnte das von Microsoft sein? Habe Windows 8 aber bei dem PCs meines Bruders gabs solche Logs nicht. Jedoch hat dieser auch Win 7,
mfg
