Wieder neuer Chipsatz Treiber AMD ab 17.08.23
Status
Mongoo
Feb. 2002
Wow, ein Update...
Wenn jetzt für jeden neuen Treiber ein Thread erstellt wird sehen wir hier bald nichts anderes mehr :lol:
Den "Chipsatz Treiber Wahn" verstehe eh wer will insbesondere bei den AMDler.
Und die "Intel Chipsatz Treiber" enthalten nicht mal ein einzigen Treiber.
Da werden wohl auch ein paar Verbesserungen eingepflegt und neue Treiber eingeführt.
AMD Updates Ryzen Chipset Drivers with Greater 3D V-cache Optimization?​
Zitat:
"AMD released updated Ryzen Chipset software, version 5.08.02.027. In addition to bug fixes for its various components, the drivers introduce application support for a "New program support and some new drivers added." The package now includes three new components—AMD SFH 1.1 driver, AMD PMF-7040Series driver, and a curiously named AMD Interface driver. SFH, or Sensor Fusion Hub, is a mobile-relevant component where various sensory devices, such as cameras, motion-sensors, etc., can be presented to the OS to drive applications that need them, such as Windows Hello. AMD PMF-7040 driver provides Platform Management Framework, and is specific to the Ryzen 7040-series "Phoenix" mobile processors. "AMD Interface driver" is a mystery."
https://www.techpowerup.com/312559/...-drivers-with-greater-3d-v-cache-optimization
Das könnte vielleicht auch hiermit zu tun haben:
AMD Releases Radeon GPU Detective (RGD) 1.0​
Zitat:
"The tool lets developers set the driver into Crash Analysis mode using the Radeon Developer Panel (RDP) before reproducing the crash. Upon crash, an analysis file is generated with details that can help shed light on the crash's cause:
  • Execution marker information indicating which render passes and draw calls were in progress during the crash. Custom markers can be added by the app developer using the AGS (AMD GPU Services) library.
  • If the crash was determined to be caused by a page fault:
    • offending virtual address.
    • Details about any resource (such as heaps, textures, and buffers) that resided in the offending virtual address, including resource names given by the developer.
    • Timeline of memory events (such as Create, Destroy and Evict) filtered only for the relevant resources.
    • The crash analysis file is generated in text format by default. The tool can also be configured to generate the analysis file in JSON format to support automated processing.
RGD is part of the Radeon Developer Tool Suite (RDTS) which is available for download here.
Please note that RGD v1.0 requires the latest Adrenalin drivers (minimum version 23.7.2). The latest Adrenalin drivers can be downloaded from here.
The code for the RGD command line tool is open source and can be found on the Radeon GPU Detective repository."
https://www.techpowerup.com/312562/amd-releases-radeon-gpu-detective-rgd-1-0
Status
