Wiederholt Bluescreens
L
LightFlash
Ich hatte mit meinem 'alten' System ständig irgendwelche Bluescreens..
Jetzt habe ich aufgerüstet, weil ich es leid war.
Doch jetzt habe ich schon wieder einen verdammten Bluescreen.
Hoffe es kann mir jemand dabei helfen..
Windows 7 64Bit Professional
Intel i5 2500K
ASRock Z68 Extreme3 Gen3
8Gb RAM
ATI HD 4890
Ocz Vertex 2 120Gb
WD Digital 640Gb
Use !analyze -v to get detailed debugging information.
BugCheck 116, {fffffa8008091440, fffff880071e667c, 0, 2}
Unable to load image \SystemRoot\system32\DRIVERS\VirtuWDDM.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for VirtuWDDM.sys
*** ERROR: Module load completed but symbols could not be loaded for VirtuWDDM.sys
Probably caused by : VirtuWDDM.sys ( VirtuWDDM+867c )
Followup: MachineOwner
1: kd> !analyze -v
* Bugcheck Analysis *
VIDEO_TDR_FAILURE (116)
Attempt to reset the display driver and recover from timeout failed.
Arguments:
Arg1: fffffa8008091440, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff880071e667c, The pointer into responsible device driver module (e.g. owner tag).
Arg3: 0000000000000000, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 0000000000000002, Optional internal context dependent data.
Debugging Details:
FAULTING_IP:
VirtuWDDM+867c
fffff880`071e667c 4c8bc2 mov r8,rdx
DEFAULT_BUCKET_ID: GRAPHICS_DRIVER_TDR_FAULT
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0x116
PROCESS_NAME: System
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`02362888 fffff880`074fb000 : 00000000`00000116 fffffa80`08091440 fffff880`071e667c 00000000`00000000 : nt!KeBugCheckEx
fffff880`02362890 fffff880`074fad0a : fffff880`071e667c fffffa80`08091440 fffffa80`0a4a5d50 fffffa80`0a425410 : dxgkrnl!TdrBugcheckOnTimeout+0xec
fffff880`023628d0 fffff880`075a1fb3 : fffffa80`08091440 00000000`00000000 fffffa80`0a4a5d50 fffffa80`0a425410 : dxgkrnl!TdrIsRecoveryRequired+0x1a2
fffff880`02362900 fffff880`075cbb75 : 00000000`ffffffff 00000000`0009e745 00000000`00000000 00000000`00000002 : dxgmms1!VidSchiReportHwHang+0x40b
fffff880`023629e0 fffff880`075ca2bb : 00000000`00000102 00000000`00000000 00000000`0009e745 00000000`00000000 : dxgmms1!VidSchiCheckHwProgress+0x71
fffff880`02362a10 fffff880`0759d2da : ffffffff`ff676980 fffffa80`0a425410 00000000`00000000 00000000`00000000 : dxgmms1!VidSchiWaitForSchedulerEvents+0x1fb
fffff880`02362ab0 fffff880`075c9e7a : 00000000`00000000 fffffa80`0b3aa8d0 00000000`00000080 fffffa80`0a425410 : dxgmms1!VidSchiScheduleCommandToRun+0x1da
fffff880`02362bc0 fffff800`03930fee : 00000000`fffffc32 fffffa80`0a168b60 fffffa80`0790e040 fffffa80`0a168b60 : dxgmms1!VidSchiWorkerThread+0xba
fffff880`02362c00 fffff800`036875e6 : fffff800`0380be80 fffffa80`0a168b60 fffff800`03819cc0 6c72506f`6865652b : nt!PspSystemThreadStartup+0x5a
fffff880`02362c40 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND: .bugcheck ; kb
FOLLOWUP_IP:
VirtuWDDM+867c
SYMBOL_NAME: VirtuWDDM+867c
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: VirtuWDDM
IMAGE_NAME: VirtuWDDM.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4e15a939
FAILURE_BUCKET_ID: X64_0x116_IMAGE_VirtuWDDM.sys
Hast Du das Betriebssytem nach dem Hardware Einbau neu installiert?
Habe das Programm deinstalliert, brauchte es sowieso nicht.
Nein, noch habe ich mein System nicht neu aufgesetzt. Werde ich aber machen.
Allerdings hatte ich jetzt wieder einen Bluescreen atikmpag.sys...
Und JEDER Bluescreen zeigt bei mir extreme Grafikfehler auf, Bild im Anhang.
Das sieht ganz nach einem Hardware Problem aus. Prüfe nochmal, ob die Grafikkarte und deren Stromversorgung (falls vorhanden) korrekt sitzt. Ansonsten probiere es mal ohne die zusätzliche Grafikkarte und benutze nur mal die vom Prozessor.
Also, alles funktioniert.
Ich habe aus unerklärlichen Gründen lediglich einen Stecker in die Grafikkarte eingesteckt, obwohl ich ein zweites hätte einstecken müssen.
Problem war wohl, dass ich die Kabel meines Netzteiles gesleevt habe und dabei das Kabel in die anderen gedrückt habe... :/
Und dafür extra neue Teile gekauft :/
