config
Hallo, hier meine config.
Es sind 2 gleiche Standard Billigkarten mit Realtek Chip drin.
## base.txt - fli4l configuration parameters 2.0.7
## Creation: 26.06.2001 fm
## Last Update: $Id: base.txt,v 1.20.2.8 2002/12/02 15:21:02 rresch Exp $
## Copyright (c) 2001-2002 Frank Meyer <frank@fli4l.de>
# General settings:
HOSTNAME='fli4l' #name of fli4l router
PASSWORD= #password for telnetd, ftpd and sshd
MOUNT_BOOT='rw' #mount boot device (floppy): ro, rw, no
RAMSIZE='2048' #size of ramdisk for unzipped opt.tgz
# the variables MOUNT_OPT, PART_OPT and UPDATE_MODE will be ignored if
# RAMSIZE is not empty. see docu
MOUNT_OPT='ro' #mount opt device: ro, rw
PART_OPT='hda2' #location of opt-files? ram1 or disk-partition
UPDATE_MODE='full' #add, cfg, full, none, see documentation
# Ethernet card drivers:
# uncomment your ethernet card
ETH_DRV_N='1' #number of ethernet drivers to load, usually 1
#ETH_DRV_1='3c505' # ISA: 3COM Etherlink Plus (3c505)
#ETH_DRV_1='3c507' # ISA: 3COM Etherlink 16 (3c507)
#ETH_DRV_1='3c509' # ISA: 3COM EtherLinkIII (3c509)
#ETH_DRV_1='3c515' # ISA: 3COM EtherLink XL ISA (3c515)
#ETH_DRV_1='3c59x' # PCI: 3COM Vortex/Boomerang 3c59x,3c900,3c905
#ETH_DRV_1='82596' # Apricot Xen-II on board Ethernet
#ETH_DRV_1='3c503' # ISA: 3COM EtherLinkII (3c503)
#ETH_DRV_1='e2100' # ISA: Cabletron E21xx ISA
#ETH_DRV_1='hp' # ISA: HP PCLAN (27245, 27xxx) ISA
#ETH_DRV_1='hp-plus' # ISA: HP PCLAN+ (27247B and 27252A) ISA
ETH_DRV_1='8139too' #ISA: NE2000 ISA clone (eg. Realtek 8019,
# Accton 16xx, NatSemi 8390, UMC 9003/9008)
#ETH_DRV_1='ne2k-pci' # PCI: NE2000 PCI clone (eg. Realtek 8029,
# Winbond 89c940)
#ETH_DRV_1='smc-ultra' # ISA: SMC ULTRA
#ETH_DRV_1='smc-ultra32' # EISA: SMC ULTRA32 (NEW)
#ETH_DRV_1='wd' # ISA: SMC WD80*3
#ETH_DRV_1='at1700' # ISA: AT1700 (Fujitsu 86965) ISA
#ETH_DRV_1='cs89x0' # ISA: IBM Etherjet, cs89x0 based Cards (Option io=0xnnn necessary!)
#ETH_DRV_1='de4x5' # PCI/EISA: Digital DE425, DE434, DE435, DE450, DE500
#ETH_DRV_1='depca' # ISA: DEPCA, DE10x, DE200, DE201, DE202, DE422
#ETH_DRV_1='dgrs' # PCI: Digi International RightSwitch PCI/EISA
#ETH_DRV_1='dmfe' # PCI: DM9102 compatible PCI cards from Davicom
#ETH_DRV_1='lp486e' # ISA: Intel Professional Workstation/panther 82596
#ETH_DRV_1='eepro' # ISA: Intel EtherExpress Pro/10
#ETH_DRV_1='eepro100' # PCI: Intel EtherExpressPro PCI 10+/100B/100+
#ETH_DRV_1='eexpress' # ISA: EtherExpress16 ISA
#ETH_DRV_1='epic100' # PCI: SMC EPIC/100 (EtherPower II) PCI
#ETH_DRV_1='eth16i' # ISA/EISA: ICL EtherTeam 16i/32
#ETH_DRV_1='ewrk3' # ISA: EtherWORKS 3 ISA (DE203, DE204, DE205)
#ETH_DRV_1='fa3xx' # PCI: NETGEAR FA3XX PCI Ethernet Controller
#ETH_DRV_1='fealnx' # PCI: ASOUND LAN 8139 card - not RTL8139 (NEW)
#ETH_DRV_1='hp100' # ISA/EISA/PCI: HP 10/100VG PCLAN (ISA, EISA, PCI)
#ETH_DRV_1='lance' # ISA: AMD LANCE and PCnet (AT1500, NE2100) ISA
#ETH_DRV_1='old_tulip' # PCI: Old DECchip Tulip (dc21x4x) PCI
#ETH_DRV_1='pcnet32' # PCI: AMD PCI PCnet32
#ETH_DRV_1='rtl8139-orig' # PCI: RealTek 8129/8139 (not 8019/8029!)
#ETH_DRV_1='rtl8139' # PCI: RealTek 8129/8139 (not 8019/8029!) (NEW)
#ETH_DRV_1='8139too' # PCI: RealTek 8139 10/100 MB (NEW)
#ETH_DRV_1='sis900' # PCI: SiS 900/7016
#ETH_DRV_1='sundance' # PCI: DFE-550FX or DFE-530TXS (NEW)
#ETH_DRV_1='tlan' # PCI: TI ThunderLAN (Compaq Netelligent ...)
#ETH_DRV_1='tulip' # PCI: DECchip Tulip (dc21x4x) PCI
#ETH_DRV_1='natsemi' # PCI: Nat Semi
#ETH_DRV_1='starfire' # PCI: Starfire
#ETH_DRV_1='via-rhine' # PCI: VIA Rhine PCI (3043, VT86c100A, dfe-530tx)
#ETH_DRV_1='winbond-840' # PCI: Winbond 840
#ETH_DRV_1='lanstreamer' # Token Ring: IBM Auto LANStreamer PCI Adapter
#ETH_DRV_1='olympic' # Token Ring: IBM cards (Pit/Pit-Phy/Olympic)
#ETH_DRV_1='ibmtr' # Token Ring: IBM 16/4
#ETH_DRV_1='pcnet_cs' # PCMCIA: NS8390-based cards (NE2000, DLINK etc)
#ETH_DRV_1='3c574_cs' # PCMCIA: 3Com 574
#ETH_DRV_1='3c575_cb' # PCMCIA: 3Com 575
#ETH_DRV_1='3c589_cs' # PCMCIA: 3Com 589
#ETH_DRV_1='airo' # PCMCIA: Airo 4500 & 4800 series cards
#ETH_DRV_1='airo_cs' # PCMCIA: Airo 4500 & 4800 series cards
#ETH_DRV_1='eepro100_cb' # PCMCIA: EtherExpress Pro 100
#ETH_DRV_1='epic_cb' # PCMCIA: SMC 83c170 EPIC/100
#ETH_DRV_1='ibmtr_cs' # PCMCIA: IBM Token Ring
#ETH_DRV_1='netwave_cs' # PCMCIA: Netwave AirSurfer Wireless LAN
#ETH_DRV_1='nmclan_cs' # PCMCIA: New Media Ethernet LAN
#ETH_DRV_1='ray_cs' # PCMCIA: Raylink wireless cards
#ETH_DRV_1='smc91c92_cs' # PCMCIA: SMC91c92-based cards
#ETH_DRV_1='tulip_cb' # PCMCIA: DEC 21040-family cards
#ETH_DRV_1='wavelan_cs' # PCMCIA: WaveLAN
#ETH_DRV_1='wavelan2_cs' # PCMCIA: WaveLAN2
#ETH_DRV_1='wvlan_cs' # PCMCIA: Lucent WaveLAN/IEEE 802.11
#ETH_DRV_1='xirc2ps_cs' # PCMCIA: Xircom: CE2, CEM28, CEM33, or CE3
#ETH_DRV_1='wl24_cs' # PCMCIA: ELSA Airlancer MC-2
#ETH_DRV_1='cs89x0_cs' # PCMCIA: IBM EtherJet Ethernet Adapter
#ETH_DRV_1='orinoco_cs' # PCMCIA: Orinoco Based WLAN Cards (NEW)
#ETH_DRV_1='axnet_cs' # PCMCIA: Asix AX88190 Fast Ethernet (NEW)
ETH_DRV_1_OPTION=''
# Ether networks used with IP protocol:
IP_ETH_N='1' #number of ip ethernet networks, usually 1
IP_ETH_1_NAME='' #optional: other device name than ethX
IP_ETH_1_IPADDR='10.10.10.1' #IP address of your nth ethernet card
IP_ETH_1_NETWORK='10.10.10.0' #network of your LAN
IP_ETH_1_NETMASK='255.255.255.0' #netmask of your LAN
# Additional routes, optional
IP_DEFAULT_GATEWAY='' #normally not used, read documentation!
IP_ROUTE_N='0' #number of additional routes
IP_ROUTE_1='192.168.7.0 255.255.255.0 192.168.6.99'# network netmask gateway
# Masquerading:
MASQ_NETWORK='10.10.10.0/24' #networks to masquerade (e.g. our LAN)
MASQ_MODULE_N='1' #load n masq modules (default: only ftp)
MASQ_MODULE_1='ftp' #ftp
MASQ_MODULE_2='h323' #h323 (netmeeting)
MASQ_MODULE_3='icq' #icq (use with caution!)
MASQ_MODULE_4='irc' #irc
MASQ_MODULE_5='raudio' #raudio
MASQ_MODULE_6='vdolive' #vdolive
MASQ_MODULE_7='quake' #quake
MASQ_MODULE_8='cuseeme' #cuseeme
MASQ_MODULE_9='mms' #MSN-Filetransfer
MASQ_MODULE_10='pptp' #pptp
MASQ_MODULE_11='ipsec' #ipsec
MASQ_MODULE_12='dplay' #dplay (direct play)
MASQ_MODULE_13='msn-0.02' #msn zone (use version 0.01 or 0.02)
MASQ_MODULE_14='udp_dloose' #pseudo mod: some internet games need it
MASQ_FTP_PORT_N='0' #using ftp masq-module on different ports
MASQ_FTP_PORT_1='21' #standard ftp port
MASQ_FTP_PORT_2='2021' #additional port
# Optional package: PORTFW
# If you set OPT_PORTFW='yes', you can also edit opt/etc/portfw.sh
OPT_PORTFW='yes' #install port forwarding tools/modules
PORTFW_N='8' #how many portforwardings to set up
PORTFW_1='4661 10.10.10.100:4661 tcp'
PORTFW_2='4662 10.10.10.100:4662 tcp'
PORTFW_3='4665 10.10.10.100:4666 udp'
PORTFW_4='4672 10.10.10.100:4672 udp'
PORTFW_5='1020 10.10.10.100:1020 tcp'
PORTFW_6='1022 10.10.10.100:1022 udp'
PORTFW_7='20 10.10.10.100:20 tcp'
PORTFW_8='21 10.10.10.100:21 udp'
# Routing without masquerading
ROUTE_NETWORK='' #optional: route from/to network, no masq
# Routing: internal hosts to deny forwarding
FORWARD_DENY_HOST_N='0' #number of denied hosts
FORWARD_DENY_HOST_1='192.168.6.5' #optional: 1st denied host
FORWARD_DENY_HOST_2='192.168.6.6' #optional: 2nd denied host
# Routing: ports to reject/deny forwarding (from inside and outside!)
FORWARD_DENY_PORT_N='1' #no. of ports to reject/deny forwarding
FORWARD_DENY_PORT_1='137:139 REJECT' #deny/reject forwarding of netbios
FORWARD_TRUSTED_NETS='' #but allow forwarding between LANs
# Firewall: ports to reject/deny from outside (all served ports)
# here we leave two ports untouched:
# 53 dns
# 113 auth
FIREWALL_DENY_PORT_N='8' #no. of ports to reject/deny
FIREWALL_DENY_PORT_1='0:19 REJECT' #privileged ports: reject or deny
FIREWALL_DENY_PORT_2='24:52 REJECT' #privileged ports: reject or deny
FIREWALL_DENY_PORT_3='54:79 REJECT' #privileged ports: reject or deny
FIREWALL_DENY_PORT_4='81:112 REJECT' #privileged ports: reject or deny
FIREWALL_DENY_PORT_5='114:1019 REJECT' #privileged ports: reject or deny
FIREWALL_DENY_PORT_6='5000:5001 REJECT' #imond/telmond ports: reject or deny
FIREWALL_DENY_PORT_7='8000 REJECT' #proxy access: reject or deny
FIREWALL_DENY_PORT_8='20012 REJECT' #vbox server access: reject or deny
FIREWALL_DENY_ICMP='no' #deny icmp (ping): yes or no
FIREWALL_LOG='no' #log access to rejected/denied ports
# Domain configuration:
START_DNS='yes' #start dns server: yes or no
DNS_FORWARDERS='194.25.2.129' #DNS servers of your provider, e.g. MSN
DNS_VERBOSE='no' #log queries in /usr/local/ens/ens.log
DOMAIN_NAME='WIRELESS_M3' #your domain name
DNS_FORBIDDEN_N='0' #number of forbidden domains
DNS_FORBIDDEN_1='foo.bar' #1st forbidden domain
DNS_FORBIDDEN_2='bar.foo' #2nd forbidden domain
HOSTS_N='4' #number of hosts in your domain
HOST_1='10.10.10.1 fli4l' #1st host: ip and name
HOST_2='10.10.10.100 client2' #2nd host: ip and name
HOST_3='10.10.10.101 client3' #3rd host: ip and name
HOST_4='10.10.10.102 client4' #4th host: ip and name
# Special DNS configuration
DNS_N='0' #number of special dns servers, normally 0
#DNS_1='firma.de 192.168.1.12' # 1st special dns server for firma.de
#DNS_2='lan.firma.de 192.168.2.12' # 2nd special dns server for lan.firma.de
# imond configuration:
START_IMOND='yes' #start imond: yes or no
IMOND_PORT='5000' #TCP-Port, see also FIREWALL_DENY_PORT_x!
IMOND_PASS='' #imond-password, may be empty
IMOND_ADMIN_PASS='' #imond-admin-password, may be empty
IMOND_LED='' #tty for led: com1 - com4 or empty
IMOND_BEEP='no' #beep if connection going up/down
IMOND_LOG='no' #log /var/log/imond.log: yes or no
IMOND_LOGDIR='/var/log' #log-directory, e.g. /var/log
IMOND_ENABLE='yes' #accept "enable/disable" commands
IMOND_DIAL='yes' #accept "dial/hangup" commands
IMOND_ROUTE='yes' #accept "route" command
IMOND_REBOOT='yes' #accept "reboot" command
# Generic circuit configuration:
IP_DYN_ADDR='yes' #use dyn. ip addresses (most providers do)
DIALMODE='auto' #standard dialmode: auto, manual, or off
# optional package: syslogd
OPT_SYSLOGD='no' #start syslogd: yes or no
SYSLOGD_DEST_N='1' #number of destinations
SYSLOGD_DEST_1='*.* /dev/console' #nth prio & destination of syslog msgs
SYSLOGD_DEST_2='*.* @192.168.6.2' #example: loghost 192.168.6.2
SYSLOGD_DEST_3='kern.info /var/log/dial.log'# example: log infos
# optional package: klogd
OPT_KLOGD='no' #start klogd: yes or no
# optional package: y2k correction
OPT_Y2K='no' #y2k correction: yes or no
Y2K_DAYS='' #correct hardware Y2K-Bug: add x days
# Optional package: PNP
OPT_PNP='no' #install isapnp tools: yes or no
PORTFW_1_SOURCE=''
PORTFW_1_TARGET=''
PORTFW_1_PROTOCOL=''
PORTFW_2_SOURCE=''
PORTFW_2_TARGET=''
PORTFW_2_PROTOCOL=''
PORTFW_3_SOURCE=''
PORTFW_3_TARGET=''
PORTFW_3_PROTOCOL=''
PORTFW_4_SOURCE=''
PORTFW_4_TARGET=''
PORTFW_4_PROTOCOL=''
PORTFW_5_SOURCE=''
PORTFW_5_TARGET=''
PORTFW_5_PROTOCOL=''
PORTFW_6_SOURCE=''
PORTFW_6_TARGET=''
PORTFW_6_PROTOCOL=''
PORTFW_7_SOURCE=''
PORTFW_7_TARGET=''
PORTFW_7_PROTOCOL=''
PORTFW_8_SOURCE=''
PORTFW_8_TARGET=''
PORTFW_8_PROTOCOL=''
PORTFW_9_SOURCE=''
PORTFW_9_TARGET=''
PORTFW_9_PROTOCOL=''
PORTFW_10_SOURCE=''
PORTFW_10_TARGET=''
PORTFW_10_PROTOCOL=''
PORTFW_11_SOURCE=''
PORTFW_11_TARGET=''
PORTFW_11_PROTOCOL=''
PORTFW_10=''
PORTFW_11=''
PORTFW_9=''
## dsl.txt - fli4l configuration parameters 2.0.7
## P L E A S E R E A D T H E D O C U M E N T A T I O N ,
## S E E R E A D M E . T X T
## B I T T E U N B E D I N G T D I E D O K U M E N T A T I O N
## L E S E N , S I E H E R E A D M E . T X T
## Last Update: $Id: dsl.txt,v 1.5 2002/02/04 01:04:27 fm Exp $
## This program is free software; you can redistribute it and/or modify
## it under the terms of the GNU General Public License as published by
## the Free Software Foundation; either version 2 of the License, or
## (at your option) any later version.
# Optional package: PPPoE
OPT_PPPOE='yes' #use ppp over ethernet: yes or no
PPPOE_NAME='DSL' #circuit name, dont write spaces
PPPOE_USEPEERDNS='no' #use dns server of your provider: yes or no
PPPOE_ETH='eth1' #eth card connected to ADSL modem, e.g. 2nd
PPPOE_USER='xxxxxx' #username
PPPOE_PASS='xxxxxx' #password
PPPOE_DEBUG='no' #enable pppd debugging, yes or no
PPPOE_HUP_TIMEOUT='600' #idle time after which to hangup
PPPOE_CHARGEINT='60' #value of charge interval (in seconds)
PPPOE_TIMES='Mo-Su:00-24:0.0:Y' #times/charges when LCR
# Optional package: PPTP - DSL in Austria/Netherlands
OPT_PPTP='no' #use PPP over ethernet: yes or no
PPTP_NAME='DSL' #circuit name, dont write spaces
PPTP_USEPEERDNS='no' #use dns server of your provider: yes or no
PPTP_ETH='eth1' #ethernet card connected to ADSL modem
PPTP_USER='anonymer' #username
PPTP_PASS='surfer' #password
PPTP_DEBUG='no' #enable pppd debugging, yes or no
PPTP_HUP_TIMEOUT='600' #idle time after which to hangup
PPTP_MODEM_TYPE='bcaa' #2 different types in Austria: bbaa / bcaa
# in the Netherlands use 'mxstream'
PPTP_CHARGEINT='60' #value of charge interval (in seconds)
PPTP_TIMES='Mo-Su:00-24:0.0:Y' #times/charges when LCR
# optional package: PPPoE-Status
OPT_POESTATUS='no' #show pppoe status on console #3
