~ > cat /var/log/Xorg.0.log trax@manjaro
[ 32.192] (--) Log file renamed from "/var/log/Xorg.pid-921.log" to "/var/log/Xorg.0.log"
[ 32.196]
X.Org X Server 1.21.1.18
X Protocol Version 11, Revision 0
[ 32.196] Current Operating System: Linux manjaro 6.12.48-1-MANJARO #1 SMP PREEMPT_DYNAMIC Fri, 19 Sep 2025 16:11:04 +0000 x86_64
[ 32.196] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-6.12-x86_64 root=UUID=fb300de3-0a4e-4755-8849-67a0a22ed4a5 rw rootflags=subvol=@ quiet splash udev.log_priority=3
[ 32.196]
[ 32.196] Current version of pixman: 0.46.4
[ 32.196] Before reporting problems, check
http://wiki.x.org
to make sure that you have the latest version.
[ 32.196] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 32.196] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Oct 21 12:53:30 2025
[ 32.198] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 32.198] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 32.199] (==) ServerLayout "Layout0"
[ 32.199] (**) |-->Screen "Screen0" (0)
[ 32.199] (**) | |-->Monitor "Monitor0"
[ 32.199] (**) | |-->Device "Device0"
[ 32.199] (**) |-->Input Device "Keyboard0"
[ 32.199] (**) |-->Input Device "Mouse0"
[ 32.199] (**) Allowing byte-swapped clients
[ 32.199] (==) Automatically adding devices
[ 32.199] (==) Automatically enabling devices
[ 32.199] (==) Automatically adding GPU devices
[ 32.199] (==) Automatically binding GPU devices
[ 32.199] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 32.200] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 32.200] Entry deleted from font path.
[ 32.200] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 32.200] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 32.200] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 32.200] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 32.200] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 32.200] (**) Extension "COMPOSITE" is enabled
[ 32.200] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 32.200] (WW) Disabling Keyboard0
[ 32.200] (WW) Disabling Mouse0
[ 32.200] (II) Module ABI versions:
[ 32.200] X.Org ANSI C Emulation: 0.4
[ 32.200] X.Org Video Driver: 25.2
[ 32.200] X.Org XInput driver : 24.4
[ 32.200] X.Org Server Extension : 10.0
[ 32.200] (++) using VT number 2
[ 32.200] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 32.202] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 32.202] (II) Platform probe for /sys/devices/pci0000:00/0000:00:1e.0/0000:08:01.0/drm/card0
[ 32.202] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 32.202] (II) Platform probe for /sys/devices/pci0000:80/0000:80:02.0/0000:84:00.0/drm/card1
[ 32.210] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 32.230] (--) PCI:*(8@0:1:0) 102b:0532:15d9:0626 rev 10, Mem @ 0xdc000000/16777216, 0xdf800000/16384, 0xdf000000/8388608, BIOS @ 0x????????/131072
[ 32.230] (--) PCI: (132@0:0:0) 10de:2504:1043:881d rev 161, Mem @ 0xfa000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[ 32.230] (II) LoadModule: "glx"
[ 32.232] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 32.247] (II) Module glx: vendor="X.Org Foundation"
[ 32.247] compiled for 1.21.1.18, module version = 1.0.0
[ 32.247] ABI class: X.Org Server Extension, version 10.0
[ 32.247] (II) Applying OutputClass "nvidia" to /dev/dri/card1
[ 32.247] loading driver: nvidia
[ 32.770] (==) Matched mga as autoconfigured driver 0
[ 32.770] (==) Matched nvidia as autoconfigured driver 1
[ 32.770] (==) Matched nouveau as autoconfigured driver 2
[ 32.770] (==) Matched nv as autoconfigured driver 3
[ 32.770] (==) Matched modesetting as autoconfigured driver 4
[ 32.770] (==) Matched fbdev as autoconfigured driver 5
[ 32.770] (==) Matched vesa as autoconfigured driver 6
[ 32.770] (==) Assigned the driver to the xf86ConfigLayout
[ 32.770] (II) LoadModule: "mga"
[ 32.771] (WW) Warning, couldn't open module mga
[ 32.771] (EE) Failed to load module "mga" (module does not exist, 0)
[ 32.771] (II) LoadModule: "nvidia"
[ 32.772] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 32.789] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 32.789] compiled for 1.6.99.901, module version = 1.0.0
[ 32.789] Module class: X.Org Video Driver
[ 32.789] (II) LoadModule: "nouveau"
[ 32.789] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 32.798] (II) Module nouveau: vendor="X.Org Foundation"
[ 32.798] compiled for 1.21.1.14, module version = 1.0.18
[ 32.798] Module class: X.Org Video Driver
[ 32.798] ABI class: X.Org Video Driver, version 25.2
[ 32.798] (II) LoadModule: "nv"
[ 32.798] (WW) Warning, couldn't open module nv
[ 32.798] (EE) Failed to load module "nv" (module does not exist, 0)
[ 32.798] (II) LoadModule: "modesetting"
[ 32.799] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 32.800] (II) Module modesetting: vendor="X.Org Foundation"
[ 32.800] compiled for 1.21.1.18, module version = 1.21.1
[ 32.800] Module class: X.Org Video Driver
[ 32.800] ABI class: X.Org Video Driver, version 25.2
[ 32.800] (II) LoadModule: "fbdev"
[ 32.801] (WW) Warning, couldn't open module fbdev
[ 32.801] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 32.801] (II) LoadModule: "vesa"
[ 32.801] (WW) Warning, couldn't open module vesa
[ 32.801] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 32.801] (II) NVIDIA dlloader X Driver 580.82.09 Fri Aug 29 17:13:41 UTC 2025
[ 32.801] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 32.801] (II) NOUVEAU driver
[ 32.801] (II) NOUVEAU driver for NVIDIA chipset families :
[ 32.801] RIVA TNT (NV04)
[ 32.801] RIVA TNT2 (NV05)
[ 32.801] GeForce 256 (NV10)
[ 32.801] GeForce 2 (NV11, NV15)
[ 32.801] GeForce 4MX (NV17, NV18)
[ 32.801] GeForce 3 (NV20)
[ 32.801] GeForce 4Ti (NV25, NV28)
[ 32.801] GeForce FX (NV3x)
[ 32.801] GeForce 6 (NV4x)
[ 32.801] GeForce 7 (G7x)
[ 32.801] GeForce 8 (G8x)
[ 32.801] GeForce 9 (G9x)
[ 32.801] GeForce GTX 2xx/3xx (GT2xx)
[ 32.801] GeForce GTX 4xx/5xx (GFxxx)
[ 32.802] GeForce GTX 6xx/7xx (GKxxx)
[ 32.802] GeForce GTX 9xx (GMxxx)
[ 32.802] GeForce GTX 10xx (GPxxx)
[ 32.802] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 32.939] (II) modeset(0): using drv /dev/dri/card0
[ 32.939] (II) Loading sub module "fb"
[ 32.939] (II) LoadModule: "fb"
[ 32.939] (II) Module "fb" already built-in
[ 32.939] (II) Loading sub module "wfb"
[ 32.939] (II) LoadModule: "wfb"
[ 32.939] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 32.941] (II) Module wfb: vendor="X.Org Foundation"
[ 32.941] compiled for 1.21.1.18, module version = 1.0.0
[ 32.941] ABI class: X.Org ANSI C Emulation, version 0.4
[ 32.942] (**) modeset(0): Depth 24, (--) framebuffer bpp 32
[ 32.942] (==) modeset(0): RGB weight 888
[ 32.942] (==) modeset(0): Default visual is TrueColor
[ 32.942] (II) Loading sub module "glamoregl"
[ 32.942] (II) LoadModule: "glamoregl"
[ 32.942] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 32.950] (II) Module glamoregl: vendor="X.Org Foundation"
[ 32.950] compiled for 1.21.1.18, module version = 1.0.1
[ 32.950] ABI class: X.Org ANSI C Emulation, version 0.4
[ 33.772] (II) modeset(0): Refusing to try glamor on llvmpipe
[ 33.775] (II) modeset(0): glamor initialization failed
[ 33.775] (II) modeset(0): ShadowFB: preferred NO, enabled NO
[ 33.810] (II) modeset(0): Output VGA-1 using monitor section Monitor0
[ 33.845] (II) modeset(0): EDID for output VGA-1
[ 33.845] (II) modeset(0): Manufacturer: DEL Model: a054 Serial#: 808603212
[ 33.845] (II) modeset(0): Year: 2010 Week: 45
[ 33.845] (II) modeset(0): EDID Version: 1.3
[ 33.845] (II) modeset(0): Analog Display Input, Input Voltage Level: 0.700/0.300 V
[ 33.845] (II) modeset(0): Sync: Separate Composite SyncOnGreen
[ 33.845] (II) modeset(0): Max Image Size [cm]: horiz.: 60 vert.: 34
[ 33.845] (II) modeset(0): Gamma: 2.20
[ 33.845] (II) modeset(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
[ 33.845] (II) modeset(0): First detailed timing is preferred mode
[ 33.845] (II) modeset(0): redX: 0.678 redY: 0.309 greenX: 0.202 greenY: 0.689
[ 33.845] (II) modeset(0): blueX: 0.148 blueY: 0.051 whiteX: 0.313 whiteY: 0.329
[ 33.845] (II) modeset(0): Supported established timings:
[ 33.845] (II) modeset(0): 720x400@70Hz
[ 33.845] (II) modeset(0): 640x480@60Hz
[ 33.845] (II) modeset(0): 640x480@75Hz
[ 33.845] (II) modeset(0): 800x600@60Hz
[ 33.845] (II) modeset(0): 800x600@75Hz
[ 33.845] (II) modeset(0): 1024x768@60Hz
[ 33.845] (II) modeset(0): 1024x768@75Hz
[ 33.845] (II) modeset(0): 1280x1024@75Hz
[ 33.845] (II) modeset(0): Manufacturer's mask: 0
[ 33.845] (II) modeset(0): Supported standard timings:
[ 33.845] (II) modeset(0): #0: hsize: 1280 vsize 800 refresh: 60 vid: 129
[ 33.846] (II) modeset(0): #1: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 33.846] (II) modeset(0): #2: hsize: 1920 vsize 1200 refresh: 60 vid: 209
[ 33.846] (II) modeset(0): #3: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 33.846] (II) modeset(0): #4: hsize: 1600 vsize 1200 refresh: 60 vid: 16553
[ 33.846] (II) modeset(0): #5: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 33.846] (II) modeset(0): Supported detailed timing:
[ 33.846] (II) modeset(0): clock: 156.8 MHz Image Size: 597 x 336 mm
[ 33.846] (II) modeset(0): h_active: 2048 h_sync: 2096 h_sync_end 2128 h_blank_end 2208 h_border: 0
[ 33.846] (II) modeset(0): v_active: 1152 v_sync: 1155 v_sync_end 1160 v_blanking: 1185 v_border: 0
[ 33.846] (II) modeset(0): Serial No: G606T0B302NL
[ 33.846] (II) modeset(0): Monitor name: DELL U2711
[ 33.846] (II) modeset(0): Ranges: V min: 49 V max: 86 Hz, H min: 29 H max: 94 kHz, PixClock max 185 MHz
[ 33.846] (II) modeset(0): EDID (in hex):
[ 33.846] (II) modeset(0): 00ffffffffffff0010ac54a04c4e3230
[ 33.846] (II) modeset(0): 2d1401030e3c2278ea8e05ad4f33b026
[ 33.846] (II) modeset(0): 0d5054a54b008100b300d100714fa940
[ 33.846] (II) modeset(0): 8180010101013b3d00a0808021403020
[ 33.846] (II) modeset(0): 350055502100001a000000ff00473630
[ 33.846] (II) modeset(0): 365430423330324e4c0a000000fc0044
[ 33.846] (II) modeset(0): 454c4c2055323731310a2020000000fd
[ 33.846] (II) modeset(0): 0031561d5e12000a202020202020001a
[ 33.846] (II) modeset(0): Printing probed modes for output VGA-1
[ 33.846] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 33.846] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 33.846] (II) modeset(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 33.846] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 33.846] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 33.846] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 33.846] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 33.846] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 33.846] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 33.846] (II) modeset(0): Output VGA-1 connected
[ 33.846] (II) modeset(0): Using exact sizes for initial modes
[ 33.846] (II) modeset(0): Output VGA-1 using initial mode 1152x864 +0+0
[ 33.846] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 33.846] (==) modeset(0): DPI set to (96, 96)
[ 33.846] (II) Loading sub module "fb"
[ 33.846] (II) LoadModule: "fb"
[ 33.846] (II) Module "fb" already built-in
[ 33.846] (**) NVIDIA(G0): Depth 24, (--) framebuffer bpp 32
[ 33.846] (==) NVIDIA(G0): RGB weight 888
[ 33.846] (==) NVIDIA(G0): Default visual is TrueColor
[ 33.846] (==) NVIDIA(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 33.846] (II) Applying OutputClass "nvidia" options to /dev/dri/card1
[ 33.846] (**) NVIDIA(G0): Option "AllowEmptyInitialConfiguration"
[ 33.846] (**) NVIDIA(G0): Enabling 2D acceleration
[ 33.846] (II) Loading sub module "glxserver_nvidia"
[ 33.846] (II) LoadModule: "glxserver_nvidia"
[ 33.846] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 33.924] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 33.924] compiled for 1.6.99.901, module version = 1.0.0
[ 33.924] Module class: X.Org Server Extension
[ 33.924] (II) NVIDIA GLX Module 580.82.09 Fri Aug 29 17:16:50 UTC 2025
[ 33.924] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 33.932] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:132:0:0
[ 33.932] (--) NVIDIA(0): DFP-0
[ 33.932] (--) NVIDIA(0): DFP-1
[ 33.932] (--) NVIDIA(0): DFP-2
[ 33.932] (--) NVIDIA(0): DFP-3
[ 33.932] (--) NVIDIA(0): DFP-4
[ 33.932] (--) NVIDIA(0): DFP-5 (boot)
[ 33.932] (--) NVIDIA(0): DFP-6
[ 33.972] (II) NVIDIA(G0): NVIDIA GPU NVIDIA GeForce RTX 3060 (GA106-A) at PCI:132:0:0
[ 33.972] (II) NVIDIA(G0): (GPU-0)
[ 33.972] (--) NVIDIA(G0): Memory: 12582912 kBytes
[ 33.972] (--) NVIDIA(G0): VideoBIOS: 94.06.2f.00.cb
[ 33.972] (II) NVIDIA(G0): Detected PCI Express Link width: 16X
[ 34.048] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 34.048] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 34.048] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 34.048] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 34.048] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 34.048] (--) NVIDIA(GPU-0): DFP-1: 2670.0 MHz maximum pixel clock
[ 34.117] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 34.117] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 34.117] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 34.117] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 34.117] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 34.117] (--) NVIDIA(GPU-0): DFP-3: 2670.0 MHz maximum pixel clock
[ 34.184] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 34.184] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 34.184] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 34.192] (--) NVIDIA(GPU-0): DELL U4323QE (DFP-5): connected
[ 34.192] (--) NVIDIA(GPU-0): DELL U4323QE (DFP-5): Internal DisplayPort
[ 34.192] (--) NVIDIA(GPU-0): DELL U4323QE (DFP-5): 2670.0 MHz maximum pixel clock
[ 34.198] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 34.198] (--) NVIDIA(GPU-0): DFP-6: Internal TMDS
[ 34.198] (--) NVIDIA(GPU-0): DFP-6: 165.0 MHz maximum pixel clock
[ 34.263] (II) NVIDIA(G0): Validated MetaModes:
[ 34.263] (II) NVIDIA(G0): "NULL"
[ 34.263] (II) NVIDIA(G0): Virtual screen size determined to be 640 x 480
[ 34.604] (WW) NVIDIA(G0): Cannot find size of first mode for DELL U4323QE (DFP-5);
[ 34.604] (WW) NVIDIA(G0): cannot compute DPI from DELL U4323QE (DFP-5)'s EDID.
[ 34.604] (==) NVIDIA(G0): DPI set to (75, 75); computed from built-in default
[ 34.604] (II) UnloadModule: "nouveau"
[ 34.604] (II) Unloading nouveau
[ 34.605] (==) modeset(0): Backing store enabled
[ 34.605] (==) modeset(0): Silken mouse enabled
[ 34.605] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 34.605] (**) modeset(0): DPMS enabled
[ 34.605] (WW) modeset(0): Option "NoLogo" is not used
[ 34.609] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[ 34.609] (II) NVIDIA: access.
[ 34.627] (II) NVIDIA(G0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 34.627] (II) NVIDIA(G0): may not be running or the "AcpidSocketPath" X
[ 34.627] (II) NVIDIA(G0): configuration option may not be set correctly. When the
[ 34.627] (II) NVIDIA(G0): ACPI event daemon is available, the NVIDIA X driver will
[ 34.627] (II) NVIDIA(G0): try to use it to receive ACPI event notifications. For
[ 34.627] (II) NVIDIA(G0): details, please see the "ConnectToAcpid" and
[ 34.627] (II) NVIDIA(G0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 34.627] (II) NVIDIA(G0): Config Options in the README.
[ 34.654] (II) NVIDIA(G0): Setting mode "NULL"
[ 34.702] (==) NVIDIA(G0): Disabling shared memory pixmaps
[ 34.702] (==) NVIDIA(G0): Backing store enabled
[ 34.702] (==) NVIDIA(G0): Silken mouse enabled
[ 34.702] (**) NVIDIA(G0): DPMS enabled
[ 34.703] (WW) NVIDIA(G0): Option "NoLogo" is not used
[ 34.703] (II) Loading sub module "dri2"
[ 34.703] (II) LoadModule: "dri2"
[ 34.703] (II) Module "dri2" already built-in
[ 34.703] (II) NVIDIA(G0): [DRI2] Setup complete
[ 34.703] (II) NVIDIA(G0): [DRI2] VDPAU driver: nvidia
[ 34.703] (II) Initializing extension Generic Event Extension
[ 34.703] (II) Initializing extension SHAPE
[ 34.703] (II) Initializing extension MIT-SHM
[ 34.703] (II) Initializing extension XInputExtension
[ 34.703] (II) Initializing extension XTEST
[ 34.703] (II) Initializing extension BIG-REQUESTS
[ 34.703] (II) Initializing extension SYNC
[ 34.704] (II) Initializing extension XKEYBOARD
[ 34.704] (II) Initializing extension XC-MISC
[ 34.704] (II) Initializing extension SECURITY
[ 34.704] (II) Initializing extension XFIXES
[ 34.704] (II) Initializing extension RENDER
[ 34.704] (II) Initializing extension RANDR
[ 34.704] (II) Initializing extension COMPOSITE
[ 34.704] (II) Initializing extension DAMAGE
[ 34.704] (II) Initializing extension MIT-SCREEN-SAVER
[ 34.704] (II) Initializing extension DOUBLE-BUFFER
[ 34.704] (II) Initializing extension RECORD
[ 34.705] (II) Initializing extension DPMS
[ 34.705] (II) Initializing extension Present
[ 34.705] (II) Initializing extension DRI3
[ 34.705] (II) Initializing extension X-Resource
[ 34.705] (II) Initializing extension XVideo
[ 34.705] (II) Initializing extension XVideo-MotionCompensation
[ 34.705] (II) Initializing extension GLX
[ 34.705] (II) Indirect GLX disabled.
[ 34.705] (II) AIGLX: Screen 0 is not DRI2 capable
[ 34.728] (II) IGLX: Loaded and initialized swrast
[ 34.728] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 34.728] (II) Initializing extension XFree86-VidModeExtension
[ 34.728] (II) Initializing extension XFree86-DGA
[ 34.728] (II) Initializing extension XFree86-DRI
[ 34.728] (II) Initializing extension DRI2
[ 34.728] (II) Initializing extension NV-GLX
[ 34.728] (II) Initializing extension NV-CONTROL
[ 34.730] (II) modeset(0): Damage tracking initialized
[ 34.730] (II) modeset(0): Setting screen physical size to 304 x 228
[ 34.803] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 34.803] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 34.804] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 34.804] (**) Power Button: Applying InputClass "system-keyboard"
[ 34.804] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 34.804] (II) LoadModule: "libinput"
[ 34.804] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 34.809] (II) Module libinput: vendor="X.Org Foundation"
[ 34.809] compiled for 1.21.1.13, module version = 1.5.0
[ 34.809] Module class: X.Org XInput Driver
[ 34.809] ABI class: X.Org XInput driver, version 24.4
[ 34.809] (II) Using input driver 'libinput' for 'Power Button'
[ 34.809] (**) Power Button: always reports core events
[ 34.809] (**) Option "Device" "/dev/input/event1"
[ 34.816] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 34.816] (II) event1 - Power Button: device is a keyboard
[ 34.817] (II) event1 - Power Button: device removed
[ 34.866] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 34.866] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 34.866] (**) Option "xkb_layout" "at"
[ 34.866] (WW) Option "xkb_variant" requires a string value
[ 34.866] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 34.893] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 34.893] (II) event1 - Power Button: device is a keyboard
[ 34.893] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 34.893] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 34.893] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 34.893] (**) Power Button: Applying InputClass "system-keyboard"
[ 34.893] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 34.893] (II) Using input driver 'libinput' for 'Power Button'
[ 34.893] (**) Power Button: always reports core events
[ 34.893] (**) Option "Device" "/dev/input/event0"
[ 34.894] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 34.894] (II) event0 - Power Button: device is a keyboard
[ 34.895] (II) event0 - Power Button: device removed
[ 34.946] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 34.946] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 34.946] (**) Option "xkb_layout" "at"
[ 34.946] (WW) Option "xkb_variant" requires a string value
[ 34.946] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 34.947] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 34.948] (II) event0 - Power Button: device is a keyboard
[ 34.949] (II) config/udev: Adding input device Winbond Electronics Corp Hermon USB hidmouse Device (/dev/input/event2)
[ 34.949] (**) Winbond Electronics Corp Hermon USB hidmouse Device: Applying InputClass "evdev pointer catchall"
[ 34.949] (**) Winbond Electronics Corp Hermon USB hidmouse Device: Applying InputClass "libinput pointer catchall"
[ 34.949] (II) Using input driver 'libinput' for 'Winbond Electronics Corp Hermon USB hidmouse Device'
[ 34.949] (**) Winbond Electronics Corp Hermon USB hidmouse Device: always reports core events
[ 34.949] (**) Option "Device" "/dev/input/event2"
[ 35.002] (II) event2 - Winbond Electronics Corp Hermon USB hidmouse Device: is tagged by udev as: Mouse
[ 35.003] (II) event2 - Winbond Electronics Corp Hermon USB hidmouse Device: device is a pointer
[ 35.003] (II) event2 - Winbond Electronics Corp Hermon USB hidmouse Device: device removed
[ 35.073] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:0557:2221.0001/input/input2/event2"
[ 35.073] (II) XINPUT: Adding extended input device "Winbond Electronics Corp Hermon USB hidmouse Device" (type: MOUSE, id 8)
[ 35.073] (**) Option "AccelerationScheme" "none"
[ 35.073] (**) Winbond Electronics Corp Hermon USB hidmouse Device: (accel) selected scheme none/0
[ 35.073] (**) Winbond Electronics Corp Hermon USB hidmouse Device: (accel) acceleration factor: 2.000
[ 35.073] (**) Winbond Electronics Corp Hermon USB hidmouse Device: (accel) acceleration threshold: 4
[ 35.130] (II) event2 - Winbond Electronics Corp Hermon USB hidmouse Device: is tagged by udev as: Mouse
[ 35.131] (II) event2 - Winbond Electronics Corp Hermon USB hidmouse Device: device is a pointer
[ 35.133] (II) config/udev: Adding input device Winbond Electronics Corp Hermon USB hidmouse Device (/dev/input/mouse0)
[ 35.133] (II) No input driver specified, ignoring this device.
[ 35.133] (II) This device may have been added with another device file.
[ 35.135] (II) config/udev: Adding input device Winbond Electronics Corp Hermon USB hidmouse Device (/dev/input/event3)
[ 35.135] (**) Winbond Electronics Corp Hermon USB hidmouse Device: Applying InputClass "evdev keyboard catchall"
[ 35.135] (**) Winbond Electronics Corp Hermon USB hidmouse Device: Applying InputClass "libinput keyboard catchall"
[ 35.135] (**) Winbond Electronics Corp Hermon USB hidmouse Device: Applying InputClass "system-keyboard"
[ 35.135] (**) Winbond Electronics Corp Hermon USB hidmouse Device: Applying InputClass "Keyboard Defaults"
[ 35.135] (II) Using input driver 'libinput' for 'Winbond Electronics Corp Hermon USB hidmouse Device'
[ 35.135] (**) Winbond Electronics Corp Hermon USB hidmouse Device: always reports core events
[ 35.135] (**) Option "Device" "/dev/input/event3"
[ 35.139] (II) event3 - Winbond Electronics Corp Hermon USB hidmouse Device: is tagged by udev as: Keyboard
[ 35.140] (II) event3 - Winbond Electronics Corp Hermon USB hidmouse Device: device is a keyboard
[ 35.140] (II) event3 - Winbond Electronics Corp Hermon USB hidmouse Device: device removed
[ 35.193] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:0557:2221.0002/input/input3/event3"
[ 35.193] (II) XINPUT: Adding extended input device "Winbond Electronics Corp Hermon USB hidmouse Device" (type: KEYBOARD, id 9)
[ 35.193] (**) Option "xkb_layout" "at"
[ 35.193] (WW) Option "xkb_variant" requires a string value
[ 35.193] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 35.197] (II) event3 - Winbond Electronics Corp Hermon USB hidmouse Device: is tagged by udev as: Keyboard
[ 35.198] (II) event3 - Winbond Electronics Corp Hermon USB hidmouse Device: device is a keyboard
[ 35.201] (II) config/udev: Adding input device ATEN DISPLAYPORT KVM (/dev/input/event4)
[ 35.201] (**) ATEN DISPLAYPORT KVM: Applying InputClass "evdev keyboard catchall"
[ 35.201] (**) ATEN DISPLAYPORT KVM: Applying InputClass "libinput keyboard catchall"
[ 35.201] (**) ATEN DISPLAYPORT KVM: Applying InputClass "system-keyboard"
[ 35.201] (**) ATEN DISPLAYPORT KVM: Applying InputClass "Keyboard Defaults"
[ 35.201] (II) Using input driver 'libinput' for 'ATEN DISPLAYPORT KVM'
[ 35.201] (**) ATEN DISPLAYPORT KVM: always reports core events
[ 35.201] (**) Option "Device" "/dev/input/event4"
[ 35.206] (II) event4 - ATEN DISPLAYPORT KVM: is tagged by udev as: Keyboard
[ 35.206] (II) event4 - ATEN DISPLAYPORT KVM: device is a keyboard
[ 35.207] (II) event4 - ATEN DISPLAYPORT KVM: device removed
[ 35.256] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1.2/2-1.1.2.3/2-1.1.2.3.1/2-1.1.2.3.1:1.0/0003:0557:2274.0003/input/input4/event4"
[ 35.256] (II) XINPUT: Adding extended input device "ATEN DISPLAYPORT KVM" (type: KEYBOARD, id 10)
[ 35.256] (**) Option "xkb_layout" "at"
[ 35.256] (WW) Option "xkb_variant" requires a string value
[ 35.256] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 35.262] (II) event4 - ATEN DISPLAYPORT KVM: is tagged by udev as: Keyboard
[ 35.262] (II) event4 - ATEN DISPLAYPORT KVM: device is a keyboard
[ 35.265] (II) config/udev: Adding input device ATEN DISPLAYPORT KVM (/dev/input/event5)
[ 35.265] (**) ATEN DISPLAYPORT KVM: Applying InputClass "evdev pointer catchall"
[ 35.265] (**) ATEN DISPLAYPORT KVM: Applying InputClass "libinput pointer catchall"
[ 35.265] (II) Using input driver 'libinput' for 'ATEN DISPLAYPORT KVM'
[ 35.266] (**) ATEN DISPLAYPORT KVM: always reports core events
[ 35.266] (**) Option "Device" "/dev/input/event5"
[ 35.324] (II) event5 - ATEN DISPLAYPORT KVM: is tagged by udev as: Mouse
[ 35.325] (II) event5 - ATEN DISPLAYPORT KVM: device is a pointer
[ 35.325] (II) event5 - ATEN DISPLAYPORT KVM: device removed
[ 35.380] (II) libinput: ATEN DISPLAYPORT KVM: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 35.380] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1.2/2-1.1.2.3/2-1.1.2.3.1/2-1.1.2.3.1:1.1/0003:0557:2274.0004/input/input5/event5"
[ 35.380] (II) XINPUT: Adding extended input device "ATEN DISPLAYPORT KVM" (type: MOUSE, id 11)
[ 35.380] (**) Option "AccelerationScheme" "none"
[ 35.380] (**) ATEN DISPLAYPORT KVM: (accel) selected scheme none/0
[ 35.380] (**) ATEN DISPLAYPORT KVM: (accel) acceleration factor: 2.000
[ 35.380] (**) ATEN DISPLAYPORT KVM: (accel) acceleration threshold: 4
[ 35.438] (II) event5 - ATEN DISPLAYPORT KVM: is tagged by udev as: Mouse
[ 35.438] (II) event5 - ATEN DISPLAYPORT KVM: device is a pointer
[ 35.441] (II) config/udev: Adding input device ATEN DISPLAYPORT KVM (/dev/input/mouse1)
[ 35.441] (II) No input driver specified, ignoring this device.
[ 35.441] (II) This device may have been added with another device file.
[ 35.444] (II) config/udev: Adding input device ATEN DISPLAYPORT KVM (/dev/input/event6)
[ 35.444] (**) ATEN DISPLAYPORT KVM: Applying InputClass "evdev keyboard catchall"
[ 35.444] (**) ATEN DISPLAYPORT KVM: Applying InputClass "libinput keyboard catchall"
[ 35.444] (**) ATEN DISPLAYPORT KVM: Applying InputClass "system-keyboard"
[ 35.444] (**) ATEN DISPLAYPORT KVM: Applying InputClass "Keyboard Defaults"
[ 35.445] (II) Using input driver 'libinput' for 'ATEN DISPLAYPORT KVM'
[ 35.445] (**) ATEN DISPLAYPORT KVM: always reports core events
[ 35.445] (**) Option "Device" "/dev/input/event6"
[ 35.450] (II) event6 - ATEN DISPLAYPORT KVM: is tagged by udev as: Keyboard
[ 35.450] (II) event6 - ATEN DISPLAYPORT KVM: device is a keyboard
[ 35.450] (II) event6 - ATEN DISPLAYPORT KVM: device removed
[ 35.503] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1.3/2-1.1.3.3/2-1.1.3.3.1/2-1.1.3.3.1:1.0/0003:0557:2274.0005/input/input6/event6"
[ 35.503] (II) XINPUT: Adding extended input device "ATEN DISPLAYPORT KVM" (type: KEYBOARD, id 12)
[ 35.503] (**) Option "xkb_layout" "at"
[ 35.503] (WW) Option "xkb_variant" requires a string value
[ 35.503] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 35.508] (II) event6 - ATEN DISPLAYPORT KVM: is tagged by udev as: Keyboard
[ 35.509] (II) event6 - ATEN DISPLAYPORT KVM: device is a keyboard
[ 35.512] (II) config/udev: Adding input device ATEN DISPLAYPORT KVM (/dev/input/event7)
[ 35.512] (**) ATEN DISPLAYPORT KVM: Applying InputClass "evdev pointer catchall"
[ 35.512] (**) ATEN DISPLAYPORT KVM: Applying InputClass "libinput pointer catchall"
[ 35.512] (II) Using input driver 'libinput' for 'ATEN DISPLAYPORT KVM'
[ 35.512] (**) ATEN DISPLAYPORT KVM: always reports core events
[ 35.512] (**) Option "Device" "/dev/input/event7"
[ 35.567] (II) event7 - ATEN DISPLAYPORT KVM: is tagged by udev as: Mouse
[ 35.568] (II) event7 - ATEN DISPLAYPORT KVM: device is a pointer
[ 35.569] (II) event7 - ATEN DISPLAYPORT KVM: device removed
[ 35.636] (II) libinput: ATEN DISPLAYPORT KVM: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 35.636] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1.3/2-1.1.3.3/2-1.1.3.3.1/2-1.1.3.3.1:1.1/0003:0557:2274.0006/input/input7/event7"
[ 35.636] (II) XINPUT: Adding extended input device "ATEN DISPLAYPORT KVM" (type: MOUSE, id 13)
[ 35.637] (**) Option "AccelerationScheme" "none"
[ 35.637] (**) ATEN DISPLAYPORT KVM: (accel) selected scheme none/0
[ 35.637] (**) ATEN DISPLAYPORT KVM: (accel) acceleration factor: 2.000
[ 35.637] (**) ATEN DISPLAYPORT KVM: (accel) acceleration threshold: 4
[ 35.694] (II) event7 - ATEN DISPLAYPORT KVM: is tagged by udev as: Mouse
[ 35.695] (II) event7 - ATEN DISPLAYPORT KVM: device is a pointer
[ 35.698] (II) config/udev: Adding input device ATEN DISPLAYPORT KVM (/dev/input/mouse2)
[ 35.698] (II) No input driver specified, ignoring this device.
[ 35.698] (II) This device may have been added with another device file.
[ 35.700] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event10)
[ 35.700] (II) No input driver specified, ignoring this device.
[ 35.700] (II) This device may have been added with another device file.
[ 35.701] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event11)
[ 35.701] (II) No input driver specified, ignoring this device.
[ 35.701] (II) This device may have been added with another device file.
[ 35.702] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event12)
[ 35.702] (II) No input driver specified, ignoring this device.
[ 35.702] (II) This device may have been added with another device file.
[ 35.703] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event9)
[ 35.703] (II) No input driver specified, ignoring this device.
[ 35.703] (II) This device may have been added with another device file.
[ 35.704] (II) config/udev: Adding input device PC Speaker (/dev/input/event8)
[ 35.704] (II) No input driver specified, ignoring this device.
[ 35.704] (II) This device may have been added with another device file.
[ 84.085] (II) event1 - Power Button: device removed
[ 84.106] (II) event0 - Power Button: device removed
[ 84.140] (II) event2 - Winbond Electronics Corp Hermon USB hidmouse Device: device removed
[ 84.186] (II) event3 - Winbond Electronics Corp Hermon USB hidmouse Device: device removed
[ 84.213] (II) event4 - ATEN DISPLAYPORT KVM: device removed
[ 84.240] (II) event5 - ATEN DISPLAYPORT KVM: device removed
[ 84.293] (II) event6 - ATEN DISPLAYPORT KVM: device removed
[ 84.320] (II) event7 - ATEN DISPLAYPORT KVM: device removed
[ 156.124] (II) config/udev: Adding input device Burr-Brown from TI USB Audio CODEC (/dev/input/event13)
[ 156.124] (**) Burr-Brown from TI USB Audio CODEC : Applying InputClass "evdev keyboard catchall"
[ 156.124] (**) Burr-Brown from TI USB Audio CODEC : Applying InputClass "libinput keyboard catchall"
[ 156.124] (**) Burr-Brown from TI USB Audio CODEC : Applying InputClass "system-keyboard"
[ 156.124] (**) Burr-Brown from TI USB Audio CODEC : Applying InputClass "Keyboard Defaults"
[ 156.124] (II) Using input driver 'libinput' for 'Burr-Brown from TI USB Audio CODEC '
[ 156.124] (**) Burr-Brown from TI USB Audio CODEC : always reports core events
[ 156.124] (**) Option "Device" "/dev/input/event13"
[ 156.127] (II) event13 - Burr-Brown from TI USB Audio CODEC : is tagged by udev as: Keyboard
[ 156.127] (II) event13 - Burr-Brown from TI USB Audio CODEC : device is a keyboard
[ 156.127] (II) event13 - Burr-Brown from TI USB Audio CODEC : device removed
[ 156.156] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1.1/2-1.1.1.2/2-1.1.1.2.2/2-1.1.1.2.2:1.3/0003:08BB:29B0.0008/input/input13/event13"
[ 156.156] (II) XINPUT: Adding extended input device "Burr-Brown from TI USB Audio CODEC " (type: KEYBOARD, id 14)
[ 156.156] (**) Option "xkb_layout" "at"
[ 156.156] (WW) Option "xkb_variant" requires a string value
[ 156.156] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 156.435] (II) config/udev: Adding input device Ducky Ducky One 3 RGB (/dev/input/mouse3)
[ 156.435] (II) No input driver specified, ignoring this device.
[ 156.435] (II) This device may have been added with another device file.
[ 156.438] (II) config/udev: Adding input device Logitech G502 X (/dev/input/mouse4)
[ 156.438] (II) No input driver specified, ignoring this device.
[ 156.438] (II) This device may have been added with another device file.
[ 156.496] (II) config/udev: Adding input device Ducky Ducky One 3 RGB (/dev/input/event14)
[ 156.496] (**) Ducky Ducky One 3 RGB: Applying InputClass "evdev keyboard catchall"
[ 156.496] (**) Ducky Ducky One 3 RGB: Applying InputClass "libinput keyboard catchall"
[ 156.496] (**) Ducky Ducky One 3 RGB: Applying InputClass "system-keyboard"
[ 156.496] (**) Ducky Ducky One 3 RGB: Applying InputClass "Keyboard Defaults"
[ 156.496] (II) Using input driver 'libinput' for 'Ducky Ducky One 3 RGB'
[ 156.496] (**) Ducky Ducky One 3 RGB: always reports core events
[ 156.496] (**) Option "Device" "/dev/input/event14"
[ 156.498] (II) event14 - Ducky Ducky One 3 RGB: is tagged by udev as: Keyboard
[ 156.498] (II) event14 - Ducky Ducky One 3 RGB: device is a keyboard
[ 156.498] (II) event14 - Ducky Ducky One 3 RGB: device removed
[ 156.546] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1.1/2-1.1.1.1/2-1.1.1.1.1/2-1.1.1.1.1:1.1/0003:3233:1311.000A/input/input14/event14"
[ 156.546] (II) XINPUT: Adding extended input device "Ducky Ducky One 3 RGB" (type: KEYBOARD, id 15)
[ 156.546] (**) Option "xkb_layout" "at"
[ 156.546] (WW) Option "xkb_variant" requires a string value
[ 156.546] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 156.548] (II) config/udev: Adding input device Ducky Ducky One 3 RGB (/dev/input/event17)
[ 156.548] (**) Ducky Ducky One 3 RGB: Applying InputClass "evdev keyboard catchall"
[ 156.548] (**) Ducky Ducky One 3 RGB: Applying InputClass "libinput keyboard catchall"
[ 156.548] (**) Ducky Ducky One 3 RGB: Applying InputClass "system-keyboard"
[ 156.548] (**) Ducky Ducky One 3 RGB: Applying InputClass "Keyboard Defaults"
[ 156.548] (II) Using input driver 'libinput' for 'Ducky Ducky One 3 RGB'
[ 156.548] (**) Ducky Ducky One 3 RGB: always reports core events
[ 156.548] (**) Option "Device" "/dev/input/event17"
[ 156.550] (II) event17 - Ducky Ducky One 3 RGB: is tagged by udev as: Keyboard
[ 156.550] (II) event17 - Ducky Ducky One 3 RGB: device is a keyboard
[ 156.550] (II) event17 - Ducky Ducky One 3 RGB: device removed
[ 156.603] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1.1/2-1.1.1.1/2-1.1.1.1.1/2-1.1.1.1.1:1.4/0003:3233:1311.000D/input/input17/event17"
[ 156.603] (II) XINPUT: Adding extended input device "Ducky Ducky One 3 RGB" (type: KEYBOARD, id 16)
[ 156.603] (**) Option "xkb_layout" "at"
[ 156.603] (WW) Option "xkb_variant" requires a string value
[ 156.603] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 156.604] (II) config/udev: Adding input device Ducky Ducky One 3 RGB (/dev/input/event16)
[ 156.604] (**) Ducky Ducky One 3 RGB: Applying InputClass "evdev keyboard catchall"
[ 156.604] (**) Ducky Ducky One 3 RGB: Applying InputClass "libinput keyboard catchall"
[ 156.604] (**) Ducky Ducky One 3 RGB: Applying InputClass "system-keyboard"
[ 156.604] (**) Ducky Ducky One 3 RGB: Applying InputClass "Keyboard Defaults"
[ 156.604] (II) Using input driver 'libinput' for 'Ducky Ducky One 3 RGB'
[ 156.604] (**) Ducky Ducky One 3 RGB: always reports core events
[ 156.604] (**) Option "Device" "/dev/input/event16"
[ 156.606] (II) event16 - Ducky Ducky One 3 RGB: is tagged by udev as: Keyboard
[ 156.606] (II) event16 - Ducky Ducky One 3 RGB: device is a keyboard
[ 156.606] (II) event16 - Ducky Ducky One 3 RGB: device removed
[ 156.646] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1.1/2-1.1.1.1/2-1.1.1.1.1/2-1.1.1.1.1:1.3/0003:3233:1311.000C/input/input16/event16"
[ 156.646] (II) XINPUT: Adding extended input device "Ducky Ducky One 3 RGB" (type: KEYBOARD, id 17)
[ 156.646] (**) Option "xkb_layout" "at"
[ 156.646] (WW) Option "xkb_variant" requires a string value
[ 156.646] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 156.647] (II) config/udev: Adding input device Logitech G502 X Keyboard (/dev/input/event19)
[ 156.647] (**) Logitech G502 X Keyboard: Applying InputClass "evdev keyboard catchall"
[ 156.647] (**) Logitech G502 X Keyboard: Applying InputClass "libinput keyboard catchall"
[ 156.647] (**) Logitech G502 X Keyboard: Applying InputClass "system-keyboard"
[ 156.647] (**) Logitech G502 X Keyboard: Applying InputClass "Keyboard Defaults"
[ 156.647] (II) Using input driver 'libinput' for 'Logitech G502 X Keyboard'
[ 156.647] (**) Logitech G502 X Keyboard: always reports core events
[ 156.647] (**) Option "Device" "/dev/input/event19"
[ 156.650] (II) event19 - Logitech G502 X Keyboard: is tagged by udev as: Keyboard
[ 156.650] (II) event19 - Logitech G502 X Keyboard: device is a keyboard
[ 156.650] (II) event19 - Logitech G502 X Keyboard: device removed
[ 156.683] (II) libinput: Logitech G502 X Keyboard: needs a virtual subdevice
[ 156.683] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1.1/2-1.1.1.1/2-1.1.1.1.2/2-1.1.1.1.2:1.1/0003:046D:C099.000F/input/input19/event19"
[ 156.683] (II) XINPUT: Adding extended input device "Logitech G502 X Keyboard" (type: MOUSE, id 18)
[ 156.683] (**) Option "AccelerationScheme" "none"
[ 156.683] (**) Logitech G502 X Keyboard: (accel) selected scheme none/0
[ 156.683] (**) Logitech G502 X Keyboard: (accel) acceleration factor: 2.000
[ 156.683] (**) Logitech G502 X Keyboard: (accel) acceleration threshold: 4
[ 156.683] (**) Logitech G502 X Keyboard: Applying InputClass "evdev keyboard catchall"
[ 156.683] (**) Logitech G502 X Keyboard: Applying InputClass "libinput keyboard catchall"
[ 156.683] (**) Logitech G502 X Keyboard: Applying InputClass "system-keyboard"
[ 156.683] (**) Logitech G502 X Keyboard: Applying InputClass "Keyboard Defaults"
[ 156.683] (II) Using input driver 'libinput' for 'Logitech G502 X Keyboard'
[ 156.683] (**) Logitech G502 X Keyboard: always reports core events
[ 156.683] (**) Option "Device" "/dev/input/event19"
[ 156.683] (II) libinput: Logitech G502 X Keyboard: is a virtual subdevice
[ 156.683] (EE) libinput: Logitech G502 X Keyboard: Parent device not available
[ 156.685] (II) event19 - Logitech G502 X Keyboard: is tagged by udev as: Keyboard
[ 156.686] (II) event19 - Logitech G502 X Keyboard: device is a keyboard
[ 156.686] (II) event19 - Logitech G502 X Keyboard: device removed
[ 156.710] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1.1/2-1.1.1.1/2-1.1.1.1.2/2-1.1.1.1.2:1.1/0003:046D:C099.000F/input/input19/event19"
[ 156.710] (II) XINPUT: Adding extended input device "Logitech G502 X Keyboard" (type: KEYBOARD, id 19)
[ 156.710] (**) Option "xkb_layout" "at"
[ 156.710] (WW) Option "xkb_variant" requires a string value
[ 156.710] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 156.711] (II) config/udev: Adding input device Logitech G502 X (/dev/input/event18)
[ 156.711] (**) Logitech G502 X: Applying InputClass "evdev pointer catchall"
[ 156.711] (**) Logitech G502 X: Applying InputClass "libinput pointer catchall"
[ 156.711] (II) Using input driver 'libinput' for 'Logitech G502 X'
[ 156.711] (**) Logitech G502 X: always reports core events
[ 156.711] (**) Option "Device" "/dev/input/event18"
[ 156.713] (II) event18 - Logitech G502 X: is tagged by udev as: Mouse
[ 156.713] (II) event18 - Logitech G502 X: device set to 1600 DPI
[ 156.713] (II) event18 - Logitech G502 X: device is a pointer
[ 156.713] (II) event18 - Logitech G502 X: device removed
[ 156.756] (II) libinput: Logitech G502 X: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 156.756] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1.1/2-1.1.1.1/2-1.1.1.1.2/2-1.1.1.1.2:1.0/0003:046D:C099.000E/input/input18/event18"
[ 156.756] (II) XINPUT: Adding extended input device "Logitech G502 X" (type: MOUSE, id 20)
[ 156.757] (**) Option "AccelerationScheme" "none"
[ 156.757] (**) Logitech G502 X: (accel) selected scheme none/0
[ 156.757] (**) Logitech G502 X: (accel) acceleration factor: 2.000
[ 156.757] (**) Logitech G502 X: (accel) acceleration threshold: 4
[ 156.757] (II) config/udev: Adding input device Ducky Ducky One 3 RGB (/dev/input/event15)
[ 156.757] (**) Ducky Ducky One 3 RGB: Applying InputClass "evdev pointer catchall"
[ 156.757] (**) Ducky Ducky One 3 RGB: Applying InputClass "libinput pointer catchall"
[ 156.757] (II) Using input driver 'libinput' for 'Ducky Ducky One 3 RGB'
[ 156.757] (**) Ducky Ducky One 3 RGB: always reports core events
[ 156.757] (**) Option "Device" "/dev/input/event15"
[ 156.759] (II) event15 - Ducky Ducky One 3 RGB: is tagged by udev as: Mouse
[ 156.760] (II) event15 - Ducky Ducky One 3 RGB: device is a pointer
[ 156.760] (II) event15 - Ducky Ducky One 3 RGB: device removed
[ 156.803] (II) libinput: Ducky Ducky One 3 RGB: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 156.803] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1.1/2-1.1.1.1/2-1.1.1.1.1/2-1.1.1.1.1:1.2/0003:3233:1311.000B/input/input15/event15"
[ 156.803] (II) XINPUT: Adding extended input device "Ducky Ducky One 3 RGB" (type: MOUSE, id 21)
[ 156.803] (**) Option "AccelerationScheme" "none"
[ 156.803] (**) Ducky Ducky One 3 RGB: (accel) selected scheme none/0
[ 156.803] (**) Ducky Ducky One 3 RGB: (accel) acceleration factor: 2.000
[ 156.803] (**) Ducky Ducky One 3 RGB: (accel) acceleration threshold: 4
[ 164.877] (II) config/udev: removing device Ducky Ducky One 3 RGB
[ 164.877] (II) UnloadModule: "libinput"
[ 164.929] (II) config/udev: removing device Ducky Ducky One 3 RGB
[ 164.929] (II) UnloadModule: "libinput"
[ 165.120] (II) config/udev: removing device Ducky Ducky One 3 RGB
[ 165.120] (II) UnloadModule: "libinput"
[ 165.193] (II) config/udev: removing device Ducky Ducky One 3 RGB
[ 165.193] (II) UnloadModule: "libinput"
[ 165.237] (II) config/udev: removing device Logitech G502 X
[ 165.237] (II) UnloadModule: "libinput"
[ 165.384] (II) config/udev: removing device Logitech G502 X Keyboard
[ 165.384] (II) UnloadModule: "libinput"
[ 165.465] (II) config/udev: removing device Burr-Brown from TI USB Audio CODEC
[ 165.466] (II) UnloadModule: "libinput"
