Seit der vergangener Nacht ist mit der Version 10.4.10 ein Update für Mac OS X Tiger verfügbar. Damit schickt Apple die wohl letzte größere Aktualisierung des OS vor dem Start von Mac OS X 10.5 Leopard auf den Schirm.
The following improvements apply to both Intel- and PowerPC-based Macs unless otherwise noted:
Bluetooth
Addresses an issue in which a Bluetooth headset may show up as an available device for sound output in the Sound preference pane after it had been removed from Bluetooth preferences.
Third-party
Adds RAW image decoding support for the following cameras: Panasonic DMC-LX1, Panasonic DMC-LX2, Leica M8, Leica D-LUX 2, Leica D-LUX 3, Fuji S5 Pro, Nikon D40x, and Canon EOS 1D Mk III.
Resolves an issue in which some DNG images may appear tinted or distorted.
Improves compatibility of Mathematica 6 with 64-bit Macs.
USB
Improves reliability when using the IR remote control after waking from sleep.
Improves reliability when mounting external USB hard drives.
Resolves an issue in which a TomTom GO 910 may not be recognized when connected via USB to an Intel-based Mac.
Other
Improves responsiveness when using the Control-Eject key combination to display a shutdown dialog.
Addresses a specific issue in which users importing video from a DV camera may experience dropped frames.
Includes recent Apple security updates.
Addresses issues with calendar calculations in certain applications.
Addresses issues when rounding decimal numbers for display in certain applications.
For Motion, addresses an issue in which some texture corruption could appear in Motion if VRAM is full.
@5
Nein, zu Grabe sicherlich nicht. Immerhin wird mein MacBook Pro auch noch mit diesem System zu mir kommen, aber da die neue (und stark verbesserte Version) in besagten 4 1/2 Monaten kommt, werden höchstens noch ein/zwei Updates kommen (also in diesem Umfang).
@5: *lol* Tiger hat die längste Produktlaufzeit aller OS X Versionen. Also schon etwas "zu" lang. Kaum eine Vorgängerversion erlebte den zweiten Geburtstag bevor der Nachfolger erschien.
Bei dem Artikel oben hat wirklich jemand gepennt. Die Werte von 74 bzw. 293 MB gelten nur für Intel-Macs. Die Updates für PPC-Macs sind hingegen 25 bzw. 165 MB groß. (NOCH sind die PPC-Mac in der Überzahl!)
Ich weiß nicht so recht. Irgendwie sehe ich noch nicht so die "starken Verbesserungen" bei Leopard. Von den neuen Features interessiert mich eigentlich nur Quicklook.
Timemachine, Spaces, transparente Menüleisten usw. sind eigentlich kein Kaufgrund. Vielleicht das verbesserte Front Row... mal schaun.
Aber wie auch immer, so stabil wie das jetzige 10.4.10 wird das neue 10.5.0 sicherlich nicht gleich zum Launch sein.
Viele Verbesserungen "sieht" man nicht. Z.b die durchgehende 64-Bit'igkeit, die (angeblich) massive Beschleunigung des schon schnellen Finders, den effektiveren Scheduler, Core Animation (wird sicher grossflächig eingesetzt) und andere Verbesserungen der Architektur.
(Bitte Forenregeln lesen!)
