ich habe das Problem mit meinem Laptop, dass wenn ich in den Ruhezustand oder Energiesparmodus gehe, sich der Laptop nicht ausschaltet, sondern ein Bluescreen kommt.
Ich habe bereits die dmp-File mit dem Windows Debugger debuggt aber so richtig werde ich aus der Meldung aber nicht schlau.
Hat jemand eine Idee warum der Bluescreen kommt?
Maik
Code:
Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\Maik Otto\Desktop\053011-43337-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
DbsSplayTreeRangeMap::Add: ignoring zero-sized range at ?fffff800`00b9c500?
Symbol search path is: SRV*C:\Windows\Symbols*http://msdl.microsoft.com/download/symbols
Executable search path is: C:\Windows\System32
Unable to load image Unknown_Module_0000002c`00000000, Win32 error 0n2
*** WARNING: Unable to verify timestamp for Unknown_Module_0000002c`00000000
*** ERROR: Module load completed but symbols could not be loaded for Unknown_Module_0000002c`00000000
Debugger can not determine kernel base address
Windows 7 Kernel Version 7601 (Service Pack 1) MP (2 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.17592.amd64fre.win7sp1_gdr.110408-1631
Machine Name:
Kernel base = 0xfffff800`02e1c000 PsLoadedModuleList = 0xfffff800`03061650
Debug session time: Mon May 30 10:34:30.371 2011 (UTC + 2:00)
System Uptime: 0 days 0:59:38.915
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
...Missing image name, possible paged-out or corrupt data.
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 9F, {3, fffffa8004a96060, fffff80000b9c518, fffffa80093819d0}
***** Debugger could not find nt in module list, module list might be corrupt, error 0x80070057.
Probably caused by : Unknown_Image ( ANALYSIS_INCONCLUSIVE )
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_POWER_STATE_FAILURE (9f)
A driver is causing an inconsistent power state.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: fffffa8004a96060, Physical Device Object of the stack
Arg3: fffff80000b9c518, Functional Device Object of the stack
Arg4: fffffa80093819d0, The blocked IRP
Debugging Details:
DRVPOWERSTATE_SUBCODE: 3
IRP_ADDRESS: fffffa80093819d0
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x9F
CURRENT_IRQL: 0
STACK_TEXT:
fffff800`00b9c4c8 fffff800`02f089c2 : 00000000`0000009f 00000000`00000003 fffffa80`04a96060 fffff800`00b9c518 : 0xfffff800`02e9bd00
fffff800`00b9c4d0 00000000`0000009f : 00000000`00000003 fffffa80`04a96060 fffff800`00b9c518 fffffa80`093819d0 : 0xfffff800`02f089c2
fffff800`00b9c4d8 00000000`00000003 : fffffa80`04a96060 fffff800`00b9c518 fffffa80`093819d0 00000000`c00000bb : <Unloaded_Unknown_Module_00000000`00000000>+0x9f
fffff800`00b9c4e0 fffffa80`04a96060 : fffff800`00b9c518 fffffa80`093819d0 00000000`c00000bb 00000000`00000000 : <Unloaded_Unknown_Module_00000000`00000000>+0x3
fffff800`00b9c4e8 fffff800`00b9c518 : fffffa80`093819d0 00000000`c00000bb 00000000`00000000 fffff800`03043b00 : 0xfffffa80`04a96060
fffff800`00b9c4f0 fffffa80`093819d0 : 00000000`c00000bb 00000000`00000000 fffff800`03043b00 fffff800`00000002 : 0xfffff800`00b9c518
fffff800`00b9c4f8 00000000`c00000bb : 00000000`00000000 fffff800`03043b00 fffff800`00000002 00000000`00018000 : 0xfffffa80`093819d0
fffff800`00b9c500 00000000`00000000 : fffff800`03043b00 fffff800`00000002 00000000`00018000 fffff800`03043af0 : <Unloaded_Unknown_Module_00000000`00000000>+0xc00000bb
STACK_COMMAND: kb
SYMBOL_NAME: ANALYSIS_INCONCLUSIVE
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: Unknown_Module
IMAGE_NAME: Unknown_Image
DEBUG_FLR_IMAGE_TIMESTAMP: 0
BUCKET_ID: CORRUPT_MODULELIST
0: kd> lmvm Unknown_Module
start end module name
Maik
