Bluescreen Ursache Win 7 x64
Spock_Shocker
Dez. 2011
Hallo Zusammen,
habe heute zwei Bluescreen hintereinander bei verschiedenen Anwendungen gehabt und würde gerne wissen woran dies liegt. Hoffe mir kann hier geholfen werden.
Anbei die beiden Beschreibungen.
Vielen Dank im voraus!
Teil 1:
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 0000000000000008, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff800033163a2, address which referenced memory
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff80003517100
0000000000000008
CURRENT_IRQL: 2
FAULTING_IP:
nt!KxWaitForLockOwnerShip+12
fffff800`033163a2 48890a mov qword ptr [rdx],rcx
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0xA
PROCESS_NAME: System
TRAP_FRAME: fffff880009a9900 -- (.trap 0xfffff880009a9900)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000000 rbx=0000000000000000 rcx=fffff880009a9b20
rdx=0000000000000008 rsi=0000000000000000 rdi=0000000000000000
rip=fffff800033163a2 rsp=fffff880009a9a90 rbp=fffff880009a9b00
r8=0000000000000000 r9=0000000000000000 r10=fffffa8003c00278
r11=fffff8000351a4c0 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz na pe nc
nt!KxWaitForLockOwnerShip+0x12:
fffff800`033163a2 48890a mov qword ptr [rdx],rcx ds:01ca:00000000`00000008=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff800032e41e9 to fffff800032e4c40
STACK_TEXT:
fffff880`009a97b8 fffff800`032e41e9 : 00000000`0000000a 00000000`00000008 00000000`00000002 00000000`00000001 : nt!KeBugCheckEx
fffff880`009a97c0 fffff800`032e2e60 : 00000000`00000001 00000000`00000000 00000000`00000000 fffffa80`035612d0 : nt!KiBugCheckDispatch+0x69
fffff880`009a9900 fffff800`033163a2 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x260
fffff880`009a9a90 fffff800`032f526d : fffffa80`035612d0 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxWaitForLockOwnerShip+0x12
fffff880`009a9ac0 fffff800`032acd6e : fffffa80`035612d0 00000000`0011cb0f 00000000`00000002 00000000`000000af : nt!MiInsertPageInFreeOrZeroedList+0x55d
fffff880`009a9bd0 fffff800`0357ffee : fffffa80`03cd0b60 00000000`00000080 fffffa80`03cd0040 fffff800`032d65d9 : nt!MmZeroPageThread+0x8f5
fffff880`009a9d00 fffff800`032d65e6 : fffff800`0345ae80 fffffa80`03cd0b60 fffff800`03468cc0 78450079`00007473 : nt!PspSystemThreadStartup+0x5a
fffff880`009a9d40 00000000`00000000 : fffff880`009aa000 fffff880`009a4000 fffff880`009a9970 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: nt!KxWaitForLockOwnerShip+12
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 4e02aaa3
FAILURE_BUCKET_ID: X64_0xA_nt!KxWaitForLockOwnerShip+12
Followup: MachineOwner
Teil 2:
REFERENCE_BY_POINTER (18)
Arguments:
Arg1: 0000000000000000, Object type of the object whose reference count is being lowered
Arg2: fffffa8007bba1c0, Object whose reference count is being lowered
Arg3: 0000000000000002, Reserved
Arg4: ffffffffffffffff, Reserved
The reference count of an object is illegal for the current state of the object.
Each time a driver uses a pointer to an object the driver calls a kernel routine
to increment the reference count of the object. When the driver is done with the
pointer the driver calls another kernel routine to decrement the reference count.
Drivers must match calls to the increment and decrement routines. This bugcheck
can occur because an object's reference count goes to zero while there are still
open handles to the object, in which case the fourth parameter indicates the number
of opened handles. It may also occur when the object’s reference count drops below zero
whether or not there are open handles to the object, and in that case the fourth parameter
contains the actual value of the pointer references count.
Debugging Details:
BUGCHECK_STR: 0x18
PROCESS_NAME: iw5mp.exe
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from fffff80003223944 to fffff80003282c40
STACK_TEXT:
fffff880`05bc8b08 fffff800`03223944 : 00000000`00000018 00000000`00000000 fffffa80`07bba1c0 00000000`00000002 : nt!KeBugCheckEx
fffff880`05bc8b10 fffff800`03579468 : fffff880`05bc8c60 fffffa80`07bba1c0 fffff880`05bc8bb8 fffff800`0327e800 : nt! ?? ::FNODOBFM::`string'+0x49d71
fffff880`05bc8b70 fffff800`03281ed3 : fffffa80`03f4db60 00000000`000005f0 fffff880`05bc8bb8 fffffa80`07aba1c0 : nt!NtWaitForSingleObject+0xf8
fffff880`05bc8be0 00000000`755b2e09 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0ff7f0f8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x755b2e09
STACK_COMMAND: kb
FOLLOWUP_IP:
nt! ?? ::FNODOBFM::`string'+49d71
fffff800`03223944 cc int 3
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: nt! ?? ::FNODOBFM::`string'+49d71
MODULE_NAME: nt
FAILURE_BUCKET_ID: X64_0x18_OVER_DEREFERENCE_nt!_??_::FNODOBFM::_string_+49d71
www.google.de
Und les dir doch mal das durch was du gepostet hast, da ist der Fehler doch erkennbar :D
Es ist ein Treiber Problem!!!
Um dir mehr helfen zu können bräuchte/n ich/wir genaue Details zu deiner verbauten Hardware!
Hast du überall aktuelle Treiber drauf? (Graka, Netzwerk, Mainboard, Sound usw)
Kann aber auch gern bei Überhitzung auftreten! Check Temp von Graka und CPU mit Programmen wie AIDA64, GPU-Z oder Speedfan.
Hallo chrizZo,
kann man hier Dateien hochladen?
--------[ EVEREST Ultimate Edition ]------------------------------------------------------------------------------------
Version EVEREST v5.50.2100/de
Benchmark Modul 2.5.292.0
Homepage http://www.lavalys.com/
Berichtsart Berichts-Assistent
Computer ADMIN-PC
Ersteller Admin
Betriebssystem Microsoft Windows 7 Ultimate 6.1.7601
Datum 2011-12-04
Zeit 19:47
--------[ Übersicht ]---------------------------------------------------------------------------------------------------
Computer:
Computertyp ACPI x64-based PC
OS Service Pack Service Pack 1
Internet Explorer 8.0.7601.17514
DirectX DirectX 11.0
Computername ADMIN-PC
Benutzername Admin
Domainanmeldung Admin-PC
Datum / Uhrzeit 2011-12-04 / 19:47
Motherboard:
CPU Typ QuadCore Intel Core 2 Quad Q9550, 3150 MHz (7.5 x 420)
Motherboard Name DFI LANParty UT X48-T2R (3 PCI, 1 PCI-E x1, 3 PCI-E x16, 4 DDR2 DIMM, Audio, Dual Gigabit LAN, IEEE-1394)
Motherboard Chipsatz Intel Beachwood X48
Arbeitsspeicher 4096 MB (DDR2-800 DDR2 SDRAM)
DIMM2: OCZ FlexXLC OCZ2FXT11502G 2 GB DDR2-800 DDR2 SDRAM (5-5-5-18 @ 400 MHz) (4-5-5-15 @ 333 MHz) (3-4-4-12 @ 266 MHz)
DIMM4: OCZ FlexXLC OCZ2FXT11502G 2 GB DDR2-800 DDR2 SDRAM (5-5-5-18 @ 400 MHz) (4-5-5-15 @ 333 MHz) (3-4-4-12 @ 266 MHz)
BIOS Typ Award (12/24/08)
Anschlüsse (COM und LPT) Kommunikationsanschluss (COM1)
Anzeige:
Grafikkarte NVIDIA GeForce GTX 480 (1536 MB)
3D-Beschleuniger nVIDIA GeForce GTX 480
Monitor Eizo Nanao FlexScan S2401W (Digital) [24" LCD] (31015068)
Monitor PnP-Monitor (Standard) [NoDB] (190116843009)
Multimedia:
Soundkarte nVIDIA Unknown @ nVIDIA GF100 - High Definition Audio Controller
Soundkarte Realtek ALC889A @ Intel 82801IB ICH9 - High Definition Audio Controller [A-2]
Datenträger:
Massenspeicher Controller A0I0ZCSS IDE Controller
Massenspeicher Controller Intel(R) ICH8R/ICH9R/ICH10R/DO/5 Series/3400 Series SATA RAID Controller
Festplatte CORSAIR CMFSSD-128GBG2D (119 GB, IDE)
Festplatte RAID (1863 GB, IDE)
Festplatte WD Ext HDD 1021 USB Device (1863 GB, USB)
Optisches Laufwerk TSSTcorp CD/DVDW SH-S183A (DVD+R9:8x, DVD-R9:8x, DVD+RW:18x/8x, DVD-RW:18x/6x, DVD-RAM:12x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW/DVD-RAM)
Optisches Laufwerk ZIJ PIV4TMBK SCSI CdRom Device
S.M.A.R.T. Festplatten-Status OK
Partitionen:
C: (NTFS) 119.1 GB (38.0 GB frei)
D: (NTFS) 1862.9 GB (693.8 GB frei)
G: (NTFS) 1863.0 GB (1477.8 GB frei)
Speicherkapazität 3845.1 GB (2209.6 GB frei)
Eingabegeräte:
Tastatur HID-Tastatur
Maus Logitech HID-compliant G9x Laser Mouse
Netzwerk:
Primäre IP-Adresse 192.168.2.100
Primäre MAC-Adresse 00-01-29-A4-7D-4D
Netzwerkkarte Marvell Yukon 88E8052 PCI-E-ASF-Gigabit-Ethernet-Controller (192.168.2.100)
Peripheriegeräte:
Drucker Adobe PDF
Drucker Fax
Drucker HP6FE6E2 (HP Officejet Pro 8500 A909a)
Drucker Microsoft XPS Document Writer
FireWire Controller VIA VT6307 Fire IIM IEEE1394 Host Controller (PHY: VIA VT6307)
USB1 Controller Intel 82801IB ICH9 - USB Universal Host Controller [A-2]
USB2 Controller Intel 82801IB ICH9 - USB2 Enhanced Host Controller [A-2]
USB-Geräte Cinema - Microsoft LifeCam.
USB-Geräte Microsoft LifeCam Cinema
USB-Geräte USB-Eingabegerät
USB-Geräte USB-Massenspeichergerät
USB-Geräte USB-Verbundgerät
DMI:
DMI BIOS Anbieter Phoenix Technologies, LTD
DMI BIOS Version 6.00 PG
DMI Systemhersteller OEM
DMI Systemprodukt OEM
DMI Systemversion OEM
DMI Systemseriennummer OEM
DMI Motherboardhersteller DFI Inc.
DMI Motherboardprodukt LP UT X48
DMI Motherboardversion 1.0
DMI Motherboardseriennummer
DMI Gehäusehersteller OEM
DMI Gehäuseversion OEM
DMI Gehäuseseriennummer
DMI Gehäusekennzeichnung
DMI Gehäusetyp Desktop Case
DMI gesamte / freie Speichersockel 4 / 2
--------[ DMI ]---------------------------------------------------------------------------------------------------------
[ BIOS ]
BIOS Eigenschaften:
Version 6.00 PG
Freigabedatum 12/24/2008
Größe 1024 KB
Bootunterstützung Floppy Disk, Hard Disk, CD-ROM
Fähigkeiten Flash BIOS, Shadow BIOS, Selectable Boot, EDD, BBS
Unterstützte Standards DMI, APM, ACPI, PnP
Erweiterungen ISA, PCI, USB
[ System ]
System Eigenschaften:
Hersteller OEM
Produkt OEM
Version OEM
Seriennummer OEM
Startauslöser Netzschalter
[ Motherboard ]
Motherboard Eigenschaften:
Hersteller DFI Inc.
Produkt LP UT X48
Version 1.0
[ Gehäuse ]
Gehäuse Eigenschaften:
Hersteller OEM
Version OEM
Gehäusetyp Desktopgehäuse
[ Speichercontroller ]
Speichercontroller Eigenschaften:
Fehlerkorrekturmethode 8-bit Parity
Fehlerkorrektur Keine
Unterstützter Speicher Interleave 1-Way
Aktueller Speicher Interleave 1-Way
Unterstützte Speichertypen DIMM
Unterstützte Speicherspannung 5V
Maximale Speichermodulgröße 2048 MB
Speichersteckplätze 4
[ Prozessoren / Intel(R) Core(TM)2 Quad ]
Prozessor Eigenschaften:
Hersteller Intel
Version Intel(R) Core(TM)2 Quad
Externer Takt 420 MHz
Maximaler Takt 4000 MHz
Aktueller Takt 3150 MHz
Typ Central Processor
Spannung 1.3 V
Status Aktiviert
Aufrüstung ZIF
Sockelbezeichnung Socket 423
HTT / CMP Einheiten 1 / 4
[ Cache / Internal Cache ]
Cache Eigenschaften:
Typ Intern
Status Aktiviert
Betriebmodus Write-Back
Maximale Größe 32 KB
Installierte Größe 32 KB
Unterstützter SRAM Typ Synchronous
Aktueller SRAM Typ Synchronous
Sockelbezeichnung Interner Cache
[ Cache / External Cache ]
Typ Extern
Status Aktiviert
Maximale Größe 3072 KB
Installierte Größe 3072 KB
Sockelbezeichnung Externer Cache
[ Speichermodule / A0 ]
Arbeitsspeicher Eigenschaften:
Sockelbezeichnung A0
Installierte Größe Nicht installiert
Aktivierte Größe Nicht installiert
[ Speichermodule / A1 ]
Sockelbezeichnung A1
Typ DIMM
Installierte Größe 2048 MB
Aktivierte Größe 2048 MB
[ Speichermodule / A2 ]
Sockelbezeichnung A2
[ Speichermodule / A3 ]
Sockelbezeichnung A3
Typ DIMM
[ Speichergeräte / A0 ]
Speicher Eigenschaften:
Bauform (Form Factor) DIMM
Geräteort A0
Bankort Bank0/1
Hersteller Keine
Seriennummer Keine
Etikett Keine
Teilenummer Keine
[ Speichergeräte / A1 ]
Typ DDR2
Details Synchronous
Größe 2048 MB
Geschwindigkeit 1033 MHz
Datenbreite 64 Bit
Geräteort A1
Bankort Bank2/3
Hersteller Keine
Seriennummer Keine
Etikett Keine
Teilenummer Keine
[ Speichergeräte / A2 ]
Geräteort A2
Bankort Bank4/5
Hersteller Keine
Seriennummer Keine
Etikett Keine
Teilenummer Keine
[ Speichergeräte / A3 ]
Typ DDR2
Details Synchronous
Größe 2048 MB
Datenbreite 64 Bit
Geräteort A3
Bankort Bank6/7
Hersteller Keine
Seriennummer Keine
Etikett Keine
Teilenummer Keine
[ Steckplätze / PCI0 ]
Steckplatz-Eigenschaften:
Steckplatzbezeichnung PCI0
Typ PCI
Status Frei
Datenbusbreite 32-bit
Länge Lang
[ Steckplätze / PCI1 ]
Steckplatzbezeichnung PCI1
Typ PCI
Status Frei
Länge Lang
[ Steckplätze / PCI2 ]
Steckplatzbezeichnung PCI2
Typ PCI
Status Frei
Länge Lang
[ Steckplätze / PCI3 ]
Steckplatzbezeichnung PCI3
Typ PCI
Status Belegt
Länge Lang
[ Steckplätze / PCI4 ]
Steckplatzbezeichnung PCI4
Typ PCI
Status Frei
Länge Lang
[ Steckplätze / PCI5 ]
Steckplatzbezeichnung PCI5
Typ PCI
Status Frei
Länge Lang
[ Steckplätze / PCI6 ]
Steckplatzbezeichnung PCI6
Typ PCI
Status Frei
Länge Lang
[ Steckplätze / PCI7 ]
Steckplatzbezeichnung PCI7
Typ PCI
Status Frei
Länge Lang
[ Steckplätze / _DMI.BIN ]
Steckplatzbezeichnung _DMI.BIN
Typ PCI
Status Frei
Länge Lang
[ Steckplätze / System Slot #10 ]
Typ PCI-E x1
Status Belegt
Länge Lang
[ Anschlüsse / PRIMARY IDE ]
Portanschluss Eigenschaften:
Bezeichnung intern PRIMARY IDE
Anschlusstyp intern On-Board IDE
Anschlusstyp extern Keine
[ Anschlüsse / SECONDARY IDE ]
Bezeichnung intern SECONDARY IDE
[ Anschlüsse / FDD ]
Portart 8251 FIFO Compatible
Bezeichnung intern FDD
Anschlusstyp intern On-Board Floppy
[ Anschlüsse / COM1 ]
Portart Serial Port 16450 Compatible
Bezeichnung intern COM1
Anschlusstyp intern 9 Pin Dual Inline (pin 10 cut)
Anschlusstyp extern DB-9 pin male
[ Anschlüsse / COM2 ]
Bezeichnung intern COM2
[ Anschlüsse / LPT1 ]
Portart Parallel Port ECP/EPP
Bezeichnung intern LPT1
Anschlusstyp intern DB-25 pin female
Anschlusstyp extern DB-25 pin female
[ Anschlüsse / Keyboard ]
Portart Keyboard Port
Bezeichnung intern Tastatur
Anschlusstyp intern PS/2
Anschlusstyp extern PS/2
[ Anschlüsse / PS/2 Mouse ]
Portart Mouse Port
Bezeichnung intern PS/2 Mouse
[ Anschlüsse / USB0 ]
Portart USB
Anschlusstyp intern Keine
Bezeichnung extern USB0
[ Anschlüsse / USB1 ]
Portart USB
Bezeichnung extern USB1
--------[ Overclock ]---------------------------------------------------------------------------------------------------
CPU-Eigenschaften:
CPU Bezeichnung Yorkfield
CPU stepping E0
Engineering Sample Nein
CPUID CPU Name Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz
CPUID Revision 0001067Ah
CPU VID 1.2000 V
CPU Geschwindigkeit:
CPU Takt 3150.0 MHz (Original: 2833 MHz, overclock: 11%)
CPU Multiplikator 7.5x
CPU FSB 420.0 MHz (Original: 333 MHz, overclock: 26%)
Speicherbus 560.0 MHz
DRAM:FSB Verhältnis 16:12
CPU Cache:
L1 Code Cache 32 KB per core
L1 Datencache 32 KB per core
L2 Cache 2x 6 MB (On-Die, ECC, ASC, Full-Speed)
Motherboard ID 12/24/2008-Bigby-8A79PD4CC-00
Chipsatz Eigenschaften:
Speicher Timings 5-5-5-18 (CL-RCD-RP-RAS)
Command Rate (CR) 2T
BIOS Eigenschaften:
Datum System BIOS 12/24/08
Datum Video BIOS 04/14/10
Award BIOS Typ Phoenix - AwardBIOS v6.00PG
Award BIOS Nachricht (X48CDC24) EVALUATION ROM - NOT FOR SALE
Grafikprozessor Eigenschaften:
Grafikkarte nVIDIA GeForce GTX 480
GPU Codename GF100 (PCI Express 2.0 x16 10DE / 06C0, Rev A3)
Was spuckt WinDbg aus wenn du beim 0x18 REFERENCE_BY_POINTER !object fffffa8007bba1c0 eingibst
(die Adresse aus Parameter 2)?
Dann gibt er folgendes aus:
3: kd> !object fffffa8007bba1c0
GetUlongFromAddress: unable to read from fffff800034b5010
Could not read ObjectType address
Hätt mich auch gewundert (grummel), auch beim 0xA kommt ja
Möglicherweise ein Problem des Arbeitsspeicher.
Lade die CPU-Z herunter und mach Screenshots der Reiter Mainboard, Memory und SPD (hier von jedem Riegel extra, links oben einstellbar). https://www.computerbase.de/downloads/systemtools/cpu-z/
Lade dir Memtest86+ herunter, entpacke die zip Datei, brenn die ISO auf CD, boote von dieser und laß den Test mindestens 7 vollständige Durchgänge laufen, das dauert einige Stunden, hier könntest du den PC für dich arbeiten laßen, während du schläfst.
https://www.computerbase.de/downloads/systemtools/memtest86-plus/
Hast du mal Temperaturen gecheckt auch unter Last / Volllast? Neuste Treiber drauf?
ich habe Memtest durchlafen lassen ohne Fehler
Treiber sind aktuell, die fürs Mainboard hat Win 7 automatisch gehabt.
Gerätemanager ohne Ausrufezeichen alle Geräte erkannt.
Temperaturen unter Last:
CPU < 60°C
Chipsatz < 40°C
Graka < 80°C
Weiter Ideen?
Das sind die OCZ Flex RAM mit 1150mhz!? Richtig?
Lies mal die genauen Timings und den Spannungsbereich ab, der auf dem Heatspreader des RAM steht und stell das im Bios manuell ein. Wenn das nicht stabil läuft, nimm die RAM Frequenz zurück. Evtl. hat auch das Board damit etwas Probleme.
