Catalyst 5.10 verfügbar
mäxchen
Mai 2004
Auch wenn es eh gleich bei CB auftaucht, hier etwas genauer: https://support.ati.com/ics/support/default.asp?deptID=894&task=knowledge&questionID=640 , die Release Notes finden sich dann auch dort.
Edit2: Ich merk grad das des mit den Links nicht so geht, wie ich will... Also ohne Deeplink auf die Release Notes. :) Den Link unten hatte ich probiert, geht nur solange die eigene Session auf dem Server läuft. Oder so...
Die Resolved Issuses:
Code:
ATI drivers are already optimized for your product from the initial installation.  Installing a new driver is only recommended if you are experiencing issues with your ATI product, including those mentioned below:
- Prince of Persia: Sands of Time: Attempting to launch the game under Windows with an ATI Radeon X800 XL installed no longer results in an error message being displayed
- The German language control panel text no longer appears truncated when using 96 DPI
- 3Dmark03: Setting the display resolution to 1024x768 32bbp and having Anti-Aliasing set to 6x no longer results in Windows crashing when running 3Dmark03 Mother Nature test
- Overlay Theater Mode no longer fails to be applied on the secondary display device when using extended desktop mode
- Catalyst Control Center: Entering the Adjustments page and deselecting the option to Let the Application Decide no longer results in the Hue value not changing when moving the slider bar
- Connecting two display devices to the ATI Radeon X300/X600 no longer results in the Overlay Theater Mode failing to be applied to the primary display device
- Attempting to toggle between the CRT and TV using ALT+F5 shortcut no longer fails
- The red/blue components are no longer intermittently swapped when rendering images with OpenGL based Java 2D pipeline
- Silent Hunter 3: Enabling all video options within the game and setting the particle density to 100, along with setting Anti-Aliasing to 6X and Anisotropic Filtering to 16x, no longer results in display corruption on the left portion of the display
- Pacific Fighters: Setting the display device to 1024x768 32bpp and enabling Anti-Aliasing to 6x no longer results in display corruption being noticed within the game
- IBM DFP BN68-30012B-06: Connecting the display device to an ATI Radeon X300/X600 no longer results in display corruption being noticed after the installation of the ATI display driver
- The ATI Radeon X850 Pro is now properly identified in the Display Properties
- Dungeon Siege 2: The cursor image is now displayed properly when playing the game under Windows XP with an ATI Radeon X800 series installed
- Stronghold 2: Attempting to launch the game under Windows XP Professional x64 edition no longer results in the game failing to load and the operating system rebooting itself
- Attempting to enabling clone mode under Windows XP MCE while watching TV in a windowed mode no longer results in the operating system crashing
- Using a PAL version of the Microsoft operating system (XP, or XP MCE) no longer results in the region being switched from PAL to NTSC when clicking the video list found in the tuner tab of the TV function of the ATI MMC
- Max Payne 2: Erratic mouse pointer behavior is no longer noticed within the game's menu after a short time period of game play
- The FM seek function found in the ATI MMC no longer operates the same as the tune function when using an ATI All-in-Wonder X800 (PAL) under the Windows XP MCE operating system
- Graphedit: Watching and listening to audio/video using the composite input found on the ATI Radeon X300/X600 no longer results in the left and right audio being swapped
Hallo
Der Omegatreiber ist wesentlich besser, da kann man einstellen, was beim Gamen angezeigt werden soll.
z.B. FPS und GPU Temperatur. Es erscheint dann oben rechts im Bild die Anzeige mit den aktuellen Daten, genial.
Ach ja, ist auch eine Lüftersteuerung für die Graka implantiert. Oc, wie Atitool natürlich auch dabei
Testet den mal
http://omegadrivers.net/ati/win2k_xp.php
cu
Ups, schon wieder ein Monat vorbei?
Tja, dann gleich mal holen. Wat mutt, dat mutt, nich wahr?
kruezas schrieb:
Hallo
Testet den mal
cu
Nur zur info:
Die Omega Treiber sind wirklich sehr gut.
Das mit dem "rechts oben erscheinenden fps daten" liegt an "ATI TRAY TOOLS" und den kann man sich auch ohnen das man die omega treiber braucht installieren :freaky:...
Danke an "mäxchen"!
Genau, deswegen Release Notes nicht verlinken, geht eh nicht. Es sei denn jemand findet 'ne andere Seite als die von ATI. :D
hab ihn jetzt auch drauf und schon bisschen gebencht..
bringt genau dieselbe leistung wie der 5.9 omega :mad:
ok dann so ^^ ich hoffe das mich kein mod dafür fertig macht
New Features
This section provides information on new features introduced in the Catalyst™ 5.10 software suite. New features include:
* CrossFire™ Support
* Default Screen Rotation Keystrokes
* Display Control Panel Extension Enhancements for Windows XP MCE
CrossFire™ Support
The Catalyst™ software suite 5.10 introduces support for ATI CrossFire™. ATI CrossFire™ allows for multiple Graphics Processing Units (GPUs) to be placed within a single PC, providing superior gaming performance.
The Catalyst™ software suite 5.10 introduces default screen rotation keystrokes. The following default hotkeys will be assigned for rotating the display:
CTRL-ALT-Up Arrow
0 degrees rotation (Normal landscape mode)
CTRL-ALT-Left Arrow
Rotate 90 degrees left (Portrait mode)
CTRL-ALT-Right Arrow
Rotate 90 degrees right
CTRL-ALT-Down Arrow
Rotate 180 degrees
The Catalyst™ software suite 5.10 introduces enhancements for the display control panel extensions for Windows XP MCE. Enhancements include the following:
* Placing the ATI Setting within the Windows XP MCE main menu
* A display resolution slider bar with preset display resolutions of 480p, 720p, 1080i, and 1080p
* Adjust picture to fit your desktop display
* Ability to force display with current settings for display devices with incomplete or with an inaccurate EDID
Issues Resolved in Catalyst™ Software Suite 5.10
The following section provides a summary of the issues that have been resolved in the latest version of Catalyst™. These include:
* 3Dmark03: Setting the display resolution to 1024x768 32bbp and having Anti-Aliasing set to 6x no longer results in Windows crashing when running 3Dmark03 Mother Nature test
* Dungeon Siege 2: The cursor image is now displayed properly when playing the game under Windows XP with an ATI Radeon® X800 series installed
* Graphedit: Watching and listening to audio/video using the composite input found on the ATI Radeon® X300/X600 no longer results in the left and right audio being swapped
* Max Payne 2: Erratic mouse pointer behavior is no longer noticed within the game's menu after a short time period of game play
* Pacific Fighters: Setting the display device to 1024x768 32bpp and enabling Anti-Aliasing to 6x no longer results in display corruption being noticed within the game
* Prince of Persia: Sands of Time: Attempting to launch the game under Windows with an ATI Radeon® X800 XL installed no longer results in an error message being displayed
* Silent Hunter 3: Enabling all video options within the game and setting the particle density to 100, along with setting Anti-Aliasing to 6X and Anisotropic Filtering to 16x, no longer results in display corruption on the left portion of the display
* Stronghold 2: Attempting to launch the game under Windows XP Professional x64 edition no longer results in the game failing to load and the operating system rebooting itself
* The German language control panel text no longer appears truncated when using 96 DPI
* Overlay Theater Mode no longer fails to be applied on the secondary display device when using extended desktop mode
* Catalyst™ Control Center: Entering the Adjustments page and deselecting the option to Let the Application Decide no longer results in the Hue value not changing when moving the slider bar
* Connecting two display devices to the ATI Radeon® X300/X600 no longer results in the Overlay Theater Mode failing to be applied to the primary display device
* Attempting to toggle between the CRT and TV using ALT+F5 shortcut no longer fails
* The red/blue components are no longer intermittently swapped when rendering images with OpenGL based Java 2D pipeline
* IBM DFP BN68-30012B-06: Connecting the display device to an ATI Radeon® X300/X600 no longer results in display corruption being noticed after the installation of the ATI display driver
* The ATI Radeon® X850 Pro is now properly identified in the Display Properties
* Attempting to enabling clone mode under Windows XP MCE while watching TV in a windowed mode no longer results in the operating system crashing
* Using a PAL version of the Microsoft operating system (XP, or XP MCE) no longer results in the region being switched from PAL to NTSC when clicking the video list found in the tuner tab of the TV function of the ATI MMC
* The FM seek function found in the ATI MMC no longer operates the same as the tune function when using an ATI All-in-Wonder X800 (PAL) under the Windows XP MCE operating system
Known Issues for Catalyst™ Software Suite 5.10
The following section provides a summary of open issues in the latest version of Catalyst™. These include
* City of Heroes: Playing the game under Windows XP Media Center Edition may results in display corruption being notice when attempting to task-switch between the game and the desktop. Further details can be found in topic number 737-19792
* Beyond Good or Evil: Flickering artifacts are noticed on the game characters after approximately 15 minutes of game play. Further details can be found in topic number 737-20795
* Dark Age of Camelot: The game exits to the desktop immediately after launching, or may play for up to 15 minutes followed by a VPU Recover error message being displayed. Further details can be found in topic number 737-20794
* Medal of Honor Allied Assaults: The game does not launch with Spearhead or Breakthrough expansion packs installed under Windows XP. Further details can be found in topic number. 737-20793
* Neverwinter Nights: Installing the 1.66 patch along with Shadows of Undertide and Hordes add-ons result in features of the game being missing when using an ATI Radeon® 9600 SE. Further details can be found in topic number. 737-20792
* Catalyst™ Control Center: The SmartShader™ effect is not removed from the 3D preview when attempting to restore the default values in the Catalyst™ Control Center. Further details can be found in topic number 737-20846
* The Apply button in the Custom settings of the Advanced mode found under the Catalyst™ Control Center Video standard settings is grayed out when playing a media file. Further details can be found in topic number 737-497
* Connecting an HDTV to an ATI Radeon® X700 series may result in the HDTV being detected as a CRT or TV under the Windows XP operating system. Further details can be found in topic number 737-20783
* Attempting to install the integrated WDM driver under Windows XP may result in an error message being displayed indicating that the hardware is not installed because the install Wizard cannot find the necessary software. Further details can be found in topic number. 737-20784
* Connecting a CRT and a TV may result in the TV not being automatically detected under Windows XP MCE when using an ATI Radeon® 9550/9600/9650 series. Further details can be found in topic number 737-20785
* Using the Custom option when installing the software driver results in the Theater 550 software driver not being present. Further details can be found in topic number 737-20786
* Catalyst™ Control Center: The menu items in the Deinterlacing aspect page of the Catalyst™ Control Center maybe missing when selecting Simplified Chinese as the supported language. Further details can be found in topic number 737-20787
* Catalyst™ Control Center: Enabling East Asian language support may result in the Apply, Discard and Defaults buttons being invisible. Further details can be found in topic number 737-20788
* Vertical striping corruption maybe noticed when running the Windows XP MCE TV when using an ATI All-in-Wonder™ X600 series. Further details can be found in topic number 737-20789
* Connecting a DVD player to the ATI All-in-Wonder™ X600 may result in the left and right audio channels being reversed when using the Windows XP MCE operating system. Further details can be found in topic number 737-20790
* Enabling CrossFire support on a system using three display device may result in corruption remaining on the secondary or third display devices when disabling the displays. Further details can be found in topic number 737-20791
For further information and general help on driver or software installation, game issues, and more, visit ATI Customer Care.
Weil ihr ja den Omega hochlobt: Keiner für WinXP64?
(Die Tempanzeige macht mich neugierig)
Kamikatze schrieb:
Bin enttäuscht... gar keine Black & White 2 Optimierungen!
Woher auch? Die wird es vielleicht im nächsten geben. Das Spiel ist ja nun noch keine Wochen auf dem Markt ;).
Ansonsten interessant, dass die X1X00 Karten noch nicht unterstützt werden. ATI ist wohl der Überzeugung, dass vor Mitte November, wenn der 5.11 erscheint, eh keiner so eine Karte käuflich erwerben konnte :D.
@N3Ro
natürlich ist es schön, wenn ein neuer Treiber so zusagen umsonst ein bisschen mehr leistung bietet, nur kann man das doch auch nicht von jedem neuen treiber erwarten, die wichtigste Aufgabe/Sinn/Zweck von neuen Treibern ist doch vorhandene Probleme bei Spielen etc. zu beseitigen und wenns Performance Probleme mit einigen Spielen gibt, werden die dann auch beseitigt. Nur kann man doch nicht sauer sein, wenn der alte Treiber genauso schnell ist wie der alte, wenn jedes Monat der Treiber 5% mehr Leistung bringt, braucht man ja keine neue Grafikkarte mehr, wär natürlich schön ist aber völlig unrealistisch. Vorallem bei neuen Grafikchips wie der 7800GTX oder der X1800 X1600 usw. sind rel. große Leistungschübe bei neuen Treibern drin, einfach weil da der Treiber noch für die Grafikkarte optimiert werden kann, bei älteren ist der Treiber einfach schon ausgereizt. Außerdem kannst du nicht immer nach Benchmarkprogrammen gehen, die sind doch eh sinnlos, was nützen dir 13.000Punkte bei 3DMark05, wenn die richtigen Spiele nicht ordentlich funktionieren, außerdem wird bei solchen Benchmarkprogrammen auch sehr viel geschöhnt.
Das ist normal. Performancemäßig sind die Treiber bei ATI und Nvidia ausgequetscht. Es sitzen da ja keine Deppen in der Entwicklungsabteilung. Wo Reserven liegen ist bei neuen Chips. Da kann es durchaus sein, dass anfangs noch nicht alle Möglichkeiten ausgereizt sind. Für ältere Generationen wie dem R3XX oder R4XX bei ATI sind in Sachen Performance alle Messen gesungen. Trotzdem lohnt ein Update der Bugfixes wegen.
In irgendwelchen Treibern hab ich aber schon irgendetwas ähnliches wie Beta-Unterstützung für B&W 2 gesehen.
