Computer without screen
mako737
Cadet 1st Year
Aug. 2023
I have a computer with screen connected throught router to computer without screen ... can i see screen of this computer that is without screen somehow?
thank you. Still does not work becouse the remote connection is disabled i found out. Can i somehow activate it?
plug a monitor temporarily on this computer and activate it, then you can unplug it again.
but accessing this comuter right away without any user consent would be quite some security risk. ;-)
sure you can. you need to connect the screen to second computer firs to make the settings. then you can use Remotedesctop App from the first PC
