So hier nun nochmal eine genauere beschreibung von meinem System:
Motherboard:
ASUS - MB (AMD/AM2) M2N32 SLI DELUXE
CPU
Support AMD® Socket AM2 Athlon 64 X2/Athlon 64 FX/Athlon 64/Sempron
AMD Cool 'n' Quiet™ Technology
AMD64 architecture enables simultaneous 32-bit and 64-bit computing
AMD Live!™ Ready
Chipsatz
NVIDIA nForce® 590 SLI™ MCP
NVIDIA LinkBoost™ Technology
Memory
Dual channel memory architecture
4 x DIMM, max. 8GB, DDR2-800/667/533, ECC and non-ECC, un-buffered memory
Expansion Slots
2 x PCI Express x16 slot with NVIDIA® SLI™ technology support, at full x16, x16 speed
1 x PCI Express x4
1 x PCI Express x1
2 x PCI 2.2
SLI
Support two identical NVIDIA SLI-Ready graphics cards (both at x16 mode)
ASUS two-slot thermal design
ASUS PEG Link
Storage
NVIDIA nForce® 590 SLI™ MCP supports:
* 1 x Ultra DMA 133/100/66/33
* 6 x Serial ATA 3.0Gb/s
* NVIDIA MediaShield™ RAID supports RAID 0, 1, 0+1, 5 and JBOD span cross
Serial ATA drives
Silicon Image® 3132 SATA controller supports
* 1 x Internal Serial ATA 3.0Gb/s
* 1 x External Serial ATA 3.0Gb/s port on back I/O (SATA On-the-Go)
* Support RAID 0, 1, and JBOD
LAN
Dual Gigabit LAN controllers support NVIDIA DualNet® technology
NVIDIA nForce® 590 SLI™ MCP built-in dual Gigabit MAC with external Marvell PHY
* Support Teaming and fail-over functions
* Support TCP/IP Acceleration
Audio
ADI 1988B 8-channel High Definition Audio CODEC
Support Jack-Sensing, Enumeration, Multi-streaming and Jack-Retasking
Coaxial, Optical S/PDIF out on back I/O port
Support DTS® Connect function
Wireless LAN
WiFi-AP Solo™ USB wireless module supports IEEE802.11b/g
IEEE 1394a
TI 1394 controller supports 2 x 1394a ports
USB
Wireless Edition: max. 8 USB2.0/1.1 ports
Special Features
ASUS EZ DIY:
* Q-Connector
* ASUS CrashFree BIOS3
* ASUS EZ Flash2
ASUS Music Alarm
ASUS MyLogo3
Back Panel I/O Ports
1 x PS/2 Keyboard port
1 x PS/2 Mouses
1 x Optical + 1 x Coaxial S/PDIF Output
1 x External SATA
2 x LAN (RJ45) port
4 x USB 2.0/1.1 ports
1 x IEEE 1394a port
1 x WiFi-g™ antenna jack (Wireless Edition only)
1 x COM port
8-channel Audio ports
BIOS
8Mb Flash ROM, AWARD BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3CIe
CPU:
AMD - AM2 X2 6000+2x1024KB 2x3000MHz BOX
Taktfrequenz: 2x 3000 MHz
Level 1 Cache: 2x 128 KB
Level 2 Cache: 2x 1024 KB
Befehlssätze: MMX, SSE, SSE2, SSE3, AMD64, Cool´n´Quiet, NX-Bit, Pacifica, Presidio
Bustakt: 2000 MT/s (HyperTransport)
Prozessorkern: Windsor
Bemerkung: 90nm, "Windsor" - AMD64 Dual Core CPU
max. Leistungsaufnahme: 125 Watt
Core Spannung: 1,4 Volt
I/O Spannung: 3,3 Volt
Arbeitsspeicher:
CORSAIR - PC-800 DDR2 4096MB DHX TW.4
XMS2 - 6400 / 2048 - 800 MHZ
4 - 4 - 4 - 12
Grafikkarte:
Grafikkarte GeForce 8800 GTX BFG 8800GTX OC 768 MB GDDR3 PCIe
(Abbildung kann vom Original abweichen)
technische Daten:
Anschlussart: PCIe x16
Stromversorgung: Anschluss 2 x 6-pin
max. Verbrauch: ca. 155 Watt (bei Volllast)
Grafikchip Bezeichnung: NVIDIA GeForce 8800 GTX
Taktfrequenz: 600 MHz
Shader Model: 4.0
Full Screen Anti Aliasing: 8
Anisotropisches filtering: 16
DirectX Version: 10
OpenGL Versionv 2.0
Speicher Kapazität: 768 MB vorhanden
Typ: GDDR3
Taktfrequenz: 1800 MHz
Speicheranbindung: 384 Bit
RAMDAC: 1. RAMDAC 400 MHz
2. RAMDAC 400 MHz
Auflösungen: 1024x768x32Bit 200 Hz
1280x1024x32Bit 170 Hz
1600x1200x32Bit 120 Hz
2048x1536x32Bit 85 Hz
2560x1600x32Bit 60 Hz (Dual Link)
MPEG2 Wiedergabe: Ja
Encoding: Nein
Direkte Anschlüsse: 2 x DVI-I Ausgang
davon 2 x mit HDCP
davon 2 x Dual Link
1 x S-Video Ausgang
Anschlüsse über Adapter: 2 x VGA Ausgang
1 x Komponenten Ausgang (3x Cinch)
Kompatibel zu: Windows 2000, Windows XP, Windows Vista
Zubehör: Anleitung, Treiber CD, 2x DVI auf VGA Adapter, 2x Stromadapter
Abmessungen: (BxHxT) 110 mm x 40 mm x 280 mm
Besonderheiten: belegt 2 Slots, SLI Support
Bemerkung: mit Kühlkörper und Lüfter inkl. Speicherkühlung
Derzeitiges Betriebssystem Windows XP
Bilder vom Programm RMClock
CPU 0:
CPU 1:
Zur Info: Kein Spiel rennt ausser Battlefield 2
Der Flugsimulator X ist unspielbar
Unreal Turnament 3 läuft teilweise mit enormen rucklern
Need For Speed Pro Street kommt garnicht klar...
Ich kann euch ansonsten noch mehr Infos über Everest geben wenn ihr wollt.
Müsst Ihr mir nur sagen was Ihr alles braucht um mir helfen zu können.
Vielen Dank an alle!
