ogilvie83
- Feb. 2008
auf der seite von techpowerup gibt es die neueste version 0.1.7 zum DL ^^
http://www.techpowerup.com/downloads/SysInfo/GPU-Z/
edit:
Revision History 0.1.7
-Corrected several GeForce 9600 GT readings
-Switched GPU and PCB temperature readings on ATI cards when using LM63 sensor
-Some fields on the main screen will now show grey "unknown" instead of "0" when value unknown
-Fixed HD 2900 GT ROP and shader count
-Added HD 3850 AGP detection
-Added 8400 GS detection
-Fixed shader count on modded/unmodded R420 cards
-Added Rage LT Pro detection
-Fixed RS300 vertex shader count
edit:
