Pingschwankungen (dLAN)
SamSoNight
🎅Rätsel-Elite ’24
Okt. 2008
seit einigen Tagen habe ich starke Pingschwankungen. Ich benutze ein dLAN um einen Router, der ca. 15m entfernt steht zu erreichen. Wohnung im ersten Stock, Haus Baujahr 1997/1998.
Die Schwankungen gab es vorher nicht. Hier mal ein paar Pingtests:
Code:
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Users\Sam>ping www.heise.de
Pinging www.heise.de [193.99.144.85] with 32 bytes of data:
Reply from 193.99.144.85: bytes=32 time=47ms TTL=246
Reply from 193.99.144.85: bytes=32 time=107ms TTL=246
Reply from 193.99.144.85: bytes=32 time=122ms TTL=246
Reply from 193.99.144.85: bytes=32 time=82ms TTL=246
Ping statistics for 193.99.144.85:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 47ms, Maximum = 122ms, Average = 89ms
Reply from 193.99.144.85: bytes=32 time=16ms TTL=246
Reply from 193.99.144.85: bytes=32 time=17ms TTL=246
Reply from 193.99.144.85: bytes=32 time=14ms TTL=246
Reply from 193.99.144.85: bytes=32 time=12ms TTL=246
    Minimum = 12ms, Maximum = 17ms, Average = 14ms
Reply from 193.99.144.85: bytes=32 time=22ms TTL=246
Reply from 193.99.144.85: bytes=32 time=15ms TTL=246
    Minimum = 14ms, Maximum = 22ms, Average = 17ms
Reply from 193.99.144.85: bytes=32 time=29ms TTL=246
Reply from 193.99.144.85: bytes=32 time=28ms TTL=246
Reply from 193.99.144.85: bytes=32 time=35ms TTL=246
Reply from 193.99.144.85: bytes=32 time=51ms TTL=246
    Minimum = 28ms, Maximum = 51ms, Average = 35ms
Reply from 193.99.144.85: bytes=32 time=77ms TTL=246
Reply from 193.99.144.85: bytes=32 time=115ms TTL=246
Reply from 193.99.144.85: bytes=32 time=21ms TTL=246
    Minimum = 21ms, Maximum = 115ms, Average = 58ms
Reply from 193.99.144.85: bytes=32 time=65ms TTL=246
Reply from 193.99.144.85: bytes=32 time=117ms TTL=246
Reply from 193.99.144.85: bytes=32 time=94ms TTL=246
    Minimum = 51ms, Maximum = 117ms, Average = 81ms
Reply from 193.99.144.85: bytes=32 time=79ms TTL=246
Reply from 193.99.144.85: bytes=32 time=20ms TTL=246
Reply from 193.99.144.85: bytes=32 time=26ms TTL=246
    Minimum = 17ms, Maximum = 79ms, Average = 35ms
C:\Users\Sam>
Wie man sieht, der Ping schwankt von 12ms bis 122ms. In Onlinespielen (League of Legends) ist es noch viel schlimmer.
Der PC, der direkt über ein LAN Kabel dranhängt, hat die Schwankungen nicht...Den Laptop, den ich auch mal am Adapter angeschlossen hab', hat die Schwankungen ebenfalls.
Sind die Adapter hinüber?
Diese "Anfälligkeit" für die Powerlan Adapter besteht ja grundsätzlich. Kaputt sind die nicht.
Es kann jedes beliebige Gerät sein, dass nun auch am Stromnetz hängt. Da niemand dauerhaft eine Mikrowelle oder einen Staubsauger laufen lässt, hat vielleicht ein Amateurfunker losgelegt, oder du hast Übersprechen aus einer anderen Phase o.ä.
Hängen die Adapter wenigstens direkt in den Steckdosen drin, oder sind Verteilerdosen dazwischen? Tödlich wäre z.B. eine Verteilerdose mit Überspannungsschutz, oder ein langes Kabel. Dann könnte man diese Problemstellen zumindest mal rauszüchten.
Sind beide direkt an der Wand angebracht. Und wie gesagt, die Schwankungen fingen wirklich erst vor ein paar Tagen an. Dass jemand auf einmal massenhaft "dazwischenfunkt" kann ich mir nicht vorstellen.
Aussagekräftiger wäre ein Ping auf den Router. Übrigens, mit "ping -t" werden die Pings dauerhaft gesendet.
Wie dylan schon sagt, das Stromnetz ist kein ideales Übertragungsmedium (Und stört ausserdem Kurzwellenbenuzter). Die kleinsten Hochfrequenzstörungen wirken sich direkt auf die Übertragungsqualität vom dlan aus.
So, hab' mal den Router mit ping -t angepingt...
Code:
C:\Users\Sam>ping -t 192.168.0.1
Pinging 192.168.0.1 with 32 bytes of data:
Reply from 192.168.0.1: bytes=32 time=3ms TTL=64
Reply from 192.168.0.1: bytes=32 time=2ms TTL=64
Reply from 192.168.0.1: bytes=32 time=4ms TTL=64
Reply from 192.168.0.1: bytes=32 time=7ms TTL=64
Reply from 192.168.0.1: bytes=32 time=5ms TTL=64
Reply from 192.168.0.1: bytes=32 time=6ms TTL=64
Ping statistics for 192.168.0.1:
    Packets: Sent = 53, Received = 53, Lost = 0 (0% loss),
    Minimum = 2ms, Maximum = 7ms, Average = 3ms
Control-C
^C
C:\Users\Sam>
Schwankt zwischen 2ms und 7ms, durchschnitt = 3ms...Normal oder nicht?
Das liegt im normalen Rahmen. Die pings auf heise.de weisen ein wenig Jitter auf, aber das kann alles mögliche zwischen deinem Heimnetzwerk und heise.de sein. Auf jeden Fall scheint das dlan nicht die Ursache zu sein.
Vielleicht musst du deinen Router auch über einen längeren Zeitraum anpingen um eine Störung zu erfassen, sofern es daran liegt.
1. sind neue geräte ans stromnetz gesteckt worden, oder wurden geräte entfernt oder das strom-kabel kurz gezogen worden?
2. bestehen die pingschwankungen auch OHNE DLAN adapter?
3. sind andere pc‘s noch im gleichen netzwerk, die gleichzeitig ins internet gehen?
Hier bei uns in der Wohnung kann man das ebenfalls beobachten:
Sobald der Fön (oder auch Kühlschrank) i.B. geht sinkt die Verbindungsqualität drastisch!
eremit007 schrieb:
Das liegt im normalen Rahmen. Die pings auf heise.de weisen ein wenig Jitter auf, ...
Jitter!? Wo zur Hölle willst Du beim Ping den Jitter rauslesen können!?
An dem Stromnetz deiner Wohnung hängst nicht nur du. Auch wenn du einen eigenen Sicherungskasten und Zähler hast, ist dies keine 100%ige Grenze.
Die Veränderung im Ping, kann also auf Änderungen außerhalb deiner Wohnung zurück zu führen sein.
Evtl. hat nun einfach ein Nachbar auch einen dLNA-Adapter und dies stört die ganze Sache.
