Sony Vaio upgraden?
Hexe28
Juni 2018
ich hätte da folgendes Anliegen:
Ich habe dieses Notebook Sony VPCCW1S1E und würde das gerne aufrüsten.
Meine Idee ist jetzt, da der Rechner einfach zu wenig Power hat, den CPU auszutauschen
und meine Frage wäre ob ich den vorhandenen Intel Core 2 Duo P4750 / 2,13 GHZ einach so austauschen kann
und wenn ja welcher der geeigneste wäre.
Die technischen Daten sind:
Technische Daten
Operating System
Genuine Windows® 7 Home Premium (64-bit)
Instant-On
Quick Web Access
Architecture
Platform
Intel® Centrino® 2 Processor Technology
Chipset
Mobile Intel® PM45 Express Chipset
Colour
Cover colour
Black
CPU Section
Processor Name
Intel® Core™2 Duo Processor P7450
Processor Manufacturer
Intel®
Processor Speed (GHz)
2.13
L2 Cache (MB)
3
Frontside Bus (MHz)
1066
Number of Cores
2
Memory
Memory Size (GB)
4
Memory Speed (MHz)
1066
Memory Type
DDR3 SDRAM (2x2GB)
Max. Supported Memory (GB)
8
Max Memory Comment
In the case of 4GB or more, a portion of the system memory over 3GB might not be available to the 32bit operating system
Drives
Hard Drive Type
Serial ATA
Hard Drive Capacity (GB)
320
Hard Drive Speed (rpm)
5400
Optical Drive Type
DVD+-RW/+-R DL/RAM
Optical Drive Fitting
Built-in
Drives Speed
Write
CD-R x24, CD-RW x10, DVD-R DL x6, DVD-R x8, DVD-RW x6, DVD+R DL x6, DVD+R x8, DVD+RW x8, DVD-RAM x5
Read
CD x24, CD-R x24, CD-RW x24, DVD x8, DVD-R DL x8, DVD-R x8, DVD-RW x8, DVD+R DL x6, DVD+R x8, DVD+RW x8, DVD-RAM x5
Display
Screen Type
X-black LCD with LED technology
Diagonal Size (in)
14
Diagonal Size (cm)
35.6
Aspect Ratio
16:9
Resolution
1366 x 768
Resolution Type
WXGA
Graphics
Graphic Card Name
NVIDIA® GeForce® GT 230M GPU
Total Graphics Memory
Total available graphics memory of Approx. 2270MB* with dedicated GDDR3 Video Memory of 512MB
Comments
* Total Available Graphics Memory refers to the Windows® classification of graphics memory, which varies depending on the operating condition, version of device driver and system memory size.
Interfaces
4 Pin i.LINK™ (IEEE1394), 400 Mbps
1
DC in
1
Memory Stick™ Slot
1
Memory Stick™ Slot Type
Memory Stick™Duo, Memory Stick™ PRO HG Duo, high speed data transfer
SD Card Slot
1
Audio out
1
Audio out Type(s)
Stereo Headphones/Speakers Jack
Microphone Jack
1
RJ-45 Direct Port (Network)
1
HDMI Output
1
USB Port (quantity)
3
USB Version
2.0
USB Connector Type
A
VGA Connector for Monitor
1
Express Card Slot
1
Express Card Type
34mm
Connectivity
Integrated Wireless LAN
YES
Wireless LAN Max. Date Rate (Mbps)
300 (RX)/ 150 (TX)
Wireless LAN Range (m)
max. 100
Wireless LAN Type
IEEE 802.11a/b/g/Draft n
Ethernet network
10BASE-T/100BASE-TX/1000BASE-T
Integrated Bluetooth (Version)
2.1 + EDR
Bluetooth Range (m)
10
Multimedia
Intel® High Definition Audio compatible
YES
Built-in Stereo Speakers
YES
3D Surround
YES
Built-in Camera
Built-in 'Motion Eye' Digital Camera
YES
Frames per Second
Max. 30
Image Sensor (Mega Pixels)
0.3
Motion Picture Function
YES
Motion Pictures max. Resolution (pixels)
640x480 (VGA)
Keyboard Section
Touch Pad
1, Multi-touch
Features
Special Buttons
Power button, Wireless switch, VAIO button, WEB button, Display Off button
Auto Resolution
Plug and Display
Kensigton Lock
YES
Software
Solution Portal
VAIO Gate
Multimedia
Media Gallery, Picture Motion Browser,VAIO Movie Story
Home Network
VAIO Media Plus
CD-DVD Burning
Easy Media Creator 10, Click to Disc/Editor
Office Application
Adobe® Reader® 9, Microsoft® Office Home&Student (60 days Try & Buy)
Security & Other
McAfee® Internet Security Suite (with 60 days free virus update), VAIO Recovery Utility - HDD recovery (hidden partition), Google software package, Internet Explorer 8
Supplied Accessories
AC Adaptor
YES
Battery
YES
Power Cord
YES
Dimensions
Depth Main Unit (mm)
233.1
Height Main Unit (min – max in mm)
27.5 - 38.5
Width Main Unit (mm)
341.3
Weight with Supplied Battery and Supplied Drive (kg)
2.4
Battery
Battery Type
Lithium-Ion battery (VGP-BPS13/Q)
Battery Life (min)
240
Battery Charging Time (min)
160
Battery Life Disclaimer
Actual battery life will vary depending on your specific hardware and software configurations. Benchmark: MobileMark 2007
Selbst wenn es gehen würde, wäre es vollkommen unwirtschaftlich in so ein altes Notebook noch eine neue alte CPU einzubauen.
Da musst du wohl neu kaufen.
seheich genau so, selbst wenn du die beste CPU von damals reinpflanzt wird der leistungssprung sehr gering sein
Ganz so schwarz sehe ich die Lage nicht:
Anstatt der CPU könnte die HDD gegen eine SSD ausgetauscht werden, das sollte einen guten Schub bringen. Dann bei dieser Gelegenheit Windows ohne Bloatware neu installieren oder zu einem Linux Derivat wie Mint oder Lubuntu greifen und sich noch eine Weile am Laptop erfreuen.
Reaktionen: Blueztrixx
Und den RAM von 4 auf 8 GB erweitern.
Und auf Win10 upgraden, soll performanter laufen und kann mit dem vorhandenen Win7-Key aktiviert werden.
