Treiberupdate Audigy 2 und Audigy 2 ZS
Cannibal
Dez. 2002
EAX Profile funktionieren endlich wieder. Hier der Link: http://de.europe.creative.com/suppo...ory=2&os=10&driverlang=&prod=510&drivertype=1
Fixes
Resolves the issue of THX® Setup Console resetting to default values whenever it is launched.
Removes noise and distortion when THX Setup Console is used.
Synchronizes the settings between EAX® ADVANCED HD? and Creative Graphic Equalizer.
Enables MIDI device name display in Windows® Multimedia Device and SoundFont® Bank Manager.
Enables the activation of imported EAX effect presets.
Resolves the audio mute issue that is encountered when certain EAX effect presets are activated.
Resolves the system stall issue that is encountered when rewinding or fast-forwarding DTS®-encoded audio CDs, on external DVD players that are playing back through your audio card.
Enhances the performance of PC games that use native OpenAL API extensions.
Requirements
Microsoft® Windows XP SP1, Windows 2000 SP3, Windows Millennium Edition or Windows 98 Second Edition.
For Audigy 2 series audio cards:
The updated EAX 4.0 ADVANCED HD driver available on the web (released on 19 November 2003).
For Audigy 2 ZS series audio cards:
The original EAX 4.0 ADVANCED HD driver from the Installation and Applications CD; or
Notes
This update is for all Audigy 2 and Audigy 2 ZS series audio cards, which include the Platinum, Platinum eX, Platinum Pro, Digital Audio and Gamer versions.
This update is not meant for original Audigy series audio cards.
This update is not meant for USB Audigy 2 NX or other external Sound Blaster audio products.
If you later wish to install older or newer versions of Audigy 2 or Audigy 2 ZS drivers, you must first uninstall this update.
hmm die hab ich schon lange...die sind ja auch vom 29.03 !! *g*
Ich habe sie per Autoupdate downgeloadet :-)
Also ich hatte auch vorher keine probleme mit den EAX Profile funktionen ?
Naja trotzdem hat es immer noch en paar macken (vor allem zu leiser Bass *LFE*)
Gruss Hawk@RGVega
Naja 3 Tage alt. Gibt bestimmt noch mehr Leute die das, so wie ich vorher, noch nicht wussten. Wenn du Probleme mit zuwenig Bass hast und ne Audigy 2 hast, dann lade dir doch das Audigy 2 ZS Software Packet runter. Guckst du hier: http://www.mediaxplosion.biz/forum/viewtopic.php?t=48&postdays=0&postorder=asc&start=0
Da steht zwar "gefixt für SB Live". Aber das heisst nur, dass man die auch auf einer SB Live 5.1 installieren kann. Auf ner Audigy 2 funktioniert die Software auch. Musst halt nur nach der Installation, die Updates manuell für die ZS Software und Treiber runterladen und installieren. Sind ca. 7 Updates. Damit kannst du dann den MediaSourcePlayer 2, die THX Console, die Bassverstärkung etc. der Audigy 2ZS nutzen. Das einzige was nicht geht, ist der Equalizer. Aber der funktioniert normal ja auch nicht. Schade eigentlich. Bin schon am überlegen mir deswegen ne ZS zu holen.
EDIT:
Hast ne ZS, hab ich schon gesehen.
joa habe ne Audigy 2 ZS.....naja ich glaube das probier ich nicht...ist mir zu umständlich...und die Bassverstärkung ist nur mit funktion 4 Boxen möglich und verstärkt nur den Anteil des Basses dieser Boxen nicht die des LFE-Kanals !
Scheiss Creativ...man das nerft echt.....so wenig Bass.......:-(
trotzdem Danke
Du hast ja ne ZS, deswegen hättest du das auch nicht machen brauchen, weil du die Software ja schon hast. Wenn du nur ne Audigy2 hättest, dann wär das ne Möglichkeit.
