Zalman GS1000 SE
Fussel_2000
Okt. 2009
Hallo, kann mir einer sagen was der Unterschied ist zwischen ein Zalman GS1000 SE und ein Zalman GS1000 ist. :rolleyes:
Och keiner weiss das. :confused_alt:
"Zalman GS1000 SE is identical to GS1000, but made entirely in steel instead of being a hybrid aluminum/steel like the original GS1000 - thus being more affordable. The only feature that was removed on GS1000 SE was the hot swap connectors from the three lower hard disk drive bays. All other features are the same: four 5,25" bays and six 3,5" bays for hard disk drives on the front of the case. The covers from the hard disk drive compartments are still made in aluminum. Of course the change in material made a huge impact in weight, which increased from 26.4 Lbs (12 Kg) to 38.4 Lbs (17.4 kg)."
Es ist also komplett in Stahl und nicht wie das "normale" GS1000 eine Mischung aus Alu und Stahl. Außerdem wurde der Hot Swap Connector für Festplatten entfernt. ;)
Black Friday
