psu: bequiet P5 470W
board: a8n sli deluxe, bios 1008 (clean flash)
cpu: amd64 3800+ venice
gfx: ati 850xt pe
ram: 2x corsair twinx1024-3200xl -> 2x2x512mb, ddr400 2-2-2-5
bios settings: all default, no voltage adjustment, no oc, nothing, useless devices deactived.
jedes einzelne modul passed den memtest alleine im slot b1.
test:
1 module (b1) -> single channel, manual: ddr400 2-2-2-5-1:
memtest: ok
sisandra: 3065MB/s
2 modules (b1+b2) -> single channel, auto: ddr400 2.5-3-3-5-2:
memtest: ok
sisandra: 2735MB/s
2 modules (b1+b2) -> single channel, manual: ddr400 2-2-2-5-2:
memtest: ok
sisandra: 2694MB/s
2 modules (b1+b2) -> single channel, manual: ddr400 2-2-2-5-1:
memtest: crash at startup
sisandra: windows doesnt load either
2 modules (a1+b1) -> dual channel, auto: ddr400 2.5-3-3-5-2:
memtest: redscreen, errors after 6% (Test #8)
adjustment: ddr voltage -> 2.8V
memtest: redscreen, errors after 6% but only a few 100MB, not total 1024MB.
adjustment: ddr voltage -> 2.85V
memtest: redscreen + reboot after 6%
manual settings: 2-2-2-5-2
memtest: redscreen, errors after 6%, 70MB+ up all the way to 1024MB, 432'000 errors.
sisandra: bluescreen + reboot.
bios 1006 und 1012 bios und alle 4 module drin bringen keinen unterschied.
eigentlich dachte ich, das einzige problem mit dem ich leben muss wäre nur 2T cmd rate bei 4 dualsided modules, aber ich bring ja nicht mal ne stabile dualchannel config zu stande, egal mit welchen timings.
*hilfe*
bin für jeden tipp dankbar...
gfx: ati 850xt pe
test:
memtest: ok
sisandra: 3065MB/s
memtest: ok
sisandra: 2735MB/s
memtest: ok
sisandra: 2694MB/s
*hilfe*
