Bluescreen KernelPower Fehler 41
DrillSgtErnst
März 2013
Ich habe das Problem, dass der Rechner sporadisch Abstürtzt. Mal mit mal ohne BlueScreen.
Ga-Z77X UP5TH
Intel Xeon 1230v2
RAdeon HD 7870 OC
Be Quiet System Power 700W
Kingston Hyper X 1600 Mhz Low Voltage RAM
die Auswertung des Dumpfiles ergab:
Crash Dump Analysis provided by OSR Open Systems Resources, Inc. (http://www.osr.com)
Online Crash Dump Analysis Service
See http://www.osronline.com for more information
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.18113.amd64fre.win7sp1_gdr.130318-1533
Machine Name:
Kernel base = 0xfffff800`0324e000 PsLoadedModuleList = 0xfffff800`03491670
Debug session time: Thu Aug 1 16:40:27.582 2013 (UTC - 4:00)
System Uptime: 0 days 12:12:25.410
* Bugcheck Analysis *
Unknown bugcheck code (a0000001)
Unknown bugcheck description
Arguments:
Arg1: 0000000000000005
Arg2: 0000000000000000
Arg3: 0000000000000000
Arg4: 0000000000000000
Debugging Details:
TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\modclass.ini, error 2
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
BUGCHECK_STR: 0xA0000001
PROCESS_NAME: PnkBstrB.exe
CURRENT_IRQL: b
LAST_CONTROL_TRANSFER: from fffff88006884c5c to fffff800032c3c00
STACK_TEXT:
fffff880`0d01b738 fffff880`06884c5c : 00000000`a0000001 00000000`00000005 00000000`00000000 00000000`00000000 : nt!KeBugCheckEx
fffff880`0d01b740 00000000`a0000001 : 00000000`00000005 00000000`00000000 00000000`00000000 00000000`00000000 : atikmdag+0x23c5c
fffff880`0d01b748 00000000`00000005 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0xa0000001
fffff880`0d01b750 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 fffff880`0d01b7a0 : 0x5
STACK_COMMAND: kb
FOLLOWUP_IP:
atikmdag+23c5c
fffff880`06884c5c ?? ???
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: atikmdag+23c5c
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: atikmdag
IMAGE_NAME: atikmdag.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 5154fbf8
FAILURE_BUCKET_ID: X64_0xA0000001_atikmdag+23c5c
Followup: MachineOwner
Ich brauche dringend Hilfe das System ist erst ein paar Tage alt :(
Besorg dir mal Memtest und las das durchlaufen..
Das werd ich machen
Aber da der nigelnagelneu ist...
Gibts vllt ne andere Möglichkeit?
@Zergra: Ein wenig genauer...
Lass memtest 86+ mindestens 7 Stunden durchlaufen. Dazu musst du jeden Riegel einzeln testen. Jeden 7 Stunden.
moin
das sieht mir eher nach der grafikkarte aus.neuste treiber drauf? evt. alten treiber nehmen.
gruss darkdog
Memtest mach ich morgen.
Grafikkarte ist ja ne Radeon, habe den aktuellsten Treiber draufgehabt, habe jetzt den heute releasten Beta Treiber nachgeschoben, seitdem (1 Std vllt) keine Abstürze, aber das heißt nix.
Achja wenn ich den PC anmache passiert es ab und an, dass er nach wenigen Sekunden wieder ausgeht, das Spielchen 2-3 Mal.
Ich hab jetzt nicht soooo viel Ahnung v. Minidumps , aber beim beim überfliegen sprang mir das hier ins Auge :
CURRENT_IRQL: b
da steht doch TREIBER und der Punkbuster ist genannt , wie kommt ihr da auf Memtest und Graka ?
Ich würd mal da ansetzten .... bevor ich mich mit Memtest quäle :freak:
Ps. dein "nach n paar sek aus-bug" könnte durch dein BeQuiet ausgelöst werden ... ist das schon älter und aus der E-Serie?
Ähm wenn ich in den Energiesparmodus wechsel (per Mausklick) stürzt er ab ;)
Mit Bluescreen und TamTam
Aber beim starten heißt es Windows wird fortgesetzt
netzteil vielleicht?das spielchen hatte ich auch mit dem abschalten. bis es sich mit nem lauten knall von selbst verabschiedet hat.
gruss darkdog
Netzteil dachte ich auch kurz, aber der Bluescreen passt da nicht rein. Der PC müsste ja einfach ausgehen, wenn es das Netzteil wäre.
Habe mal die pbsvc exe ausgeführt ;)
Das soltle dan auch nimmer kommen ;)
NT ist wie gesagt 2 Tage alt... das darf jetzt nicht kaputt sein ^^
Aber auch da bekomme ich morgen eins zum testen ;)
.... oben gelesen? :
und der Kernel Power BS passt auch dazu , heisst ja nix anderes wie "plötzlich Strom wech" .... machmal ist halt noch genug Zeit n BS bzw n Minidump zu generieren ....
OK 2 Tage alt ...... gelesen ! Müsste eigentlich gehn (was aber nix heissen soll^^)
Oh ne edit ... sry nicht gesehen ;)
Nee das ist vor 3 Tagen vom Distributor angekommen.
System Power 7 700W
ich teste morgen ein anderes, altes, Strom weg ist aber nicht sooo das Prob :/
habe grad noch gelesen (Beitrag von SPY in anderem Therad) zu wenig VCore etc pp...
Der RAM ist natürlich XMP RAM Low Voltage und nen Xeon auf ner Z77X Platine...
Das kann es auch vllt sein
.... was ich sagen wollte , Kernel Power 41 kann viele Ursachen haben zb. zuwenig Vcore beim übertakten usw usw ....
Kernel Power 41 heisst einfach nur das der Strom plötzlich weg war ..... durch Netzteil , Notabschaltung , Stromausfall , und Mama hat den Stecker rausgezogen ...... gibt alles ne Kernel Power 41 Meldung in der Ereignissanzeige ....
:rolleyes:
:D
Nicht wirklich ..... tritt sehr oft mit (Teil)-defekten Netzteilen auf oder beim übertakten mit zuwenig Spannung ...
Da du einen Xeon hast nehme ich mal an du hast nicht versucht zu übertakten ....
Hast du zufällig speichervollbelegung auf deinem Board ? Dann kann es sein das du mehr Spannung auf den Speichercontroller geben musst , damit das läuft .....
Ich würde mal so ansetzten :
Bios defaults laden , grundeinstellungen machen (Bootreihenfolge , AHCI usw.)
Testen ....
Wenn nix , dann Spannung für die Speicher hoch , nehme an du hast 1,5 V .... dann auf 1,55 V setzten ....
ah ja , XMP ausschalten und die Werte händisch eingeben , XMP verändert auch Spannungen v. Board (ungefragt)
Testen ....
Wenn nix , dann etwas mehr Spannung auf VCCSA / IMC .... IMC bei Gigabyte glaub ich ...
aber nicht viel ....
Testen .....
Also ich habe mal alles mögliche probiert...
Es läuft bisher ohne ein Problem... wer weiß was es war.
Vielen Dank für eure Hilfe ;)
